Overview
connection_control_max_connection_delay specifies the maximum duration for which a login attempt will be locked after exceeding the threshold number of failed login attempts.
Privilege requirements
Query parameters
Both the
systenant and all user tenants can query this parameter using theSHOW PARAMETERSstatement or theGV$OB_PARAMETERSview.Modify parameters
This parameter can be modified by both the
systenant and user tenants.
Attributes
Attribute |
Description |
| Parameter type | Int |
| Default Value | 2147483647, in milliseconds |
| Value range | [1000,2147483647] |
| Modifiable | Yes, you can use theALTER SYSTEM SETStatement modification. |
| Whether to restart the OBServer node for the change to take effect | No, the setting takes effect immediately. |
Configuration example
After the number of failed login attempts exceeds the threshold, the maximum duration for locking an account after failed login attempts is 2,147,483,647 milliseconds.
obclient> ALTER SYSTEM SET connection_control_max_connection_delay = 2147483647;
