OceanBase DatabaseOceanBase AI DatabaseOceanBase Cloud OceanBase Best Practices
V4.6.3
    • Core features
    • Get started with OceanBase AI Database
    • Choose an appropriate deployment plan
      • Configure Servers
      • Prepare object storage
      • OCP deployment overview
    • Deploy OceanBase AI Database
      • Create an object storage configuration
      • Deploy a LogService cluster by using OCP
      • Deploy an OceanBase AI Database cluster using OCP
    • (Optional) Deploy OBProxy
    • Deploy Java SDK
    • Recommended configurations
  • Connect
    • Overview of connection methods
    • Clients
      • MySQL client
      • OBClient
    • GUI tools
      • DBeaver
      • Navicat
    • Drivers and ORMs
      • Connect via driver or ORM framework
        • C#
          • MySQL Connector/C
          • Connector/J
          • Spring JDBC
          • SpringBoot
          • SpringBatch
          • SpringDataJPA
          • TestContainers
        • PHP
          • EXT
          • MySQLi
          • PDO
          • MySQL-connector-python
          • SQLAlchemy
          • Django
          • peewee
    • Connection pool
      • C3P0
      • JDBC
    • Connect to OceanBase AI Database by using SDK
  • Design Database Schema
    • Overview of database schema design
    • Table design
    • Logical table
      • Logical table overview
      • Agent hybrid search scenario
        • Collection and namespace management
        • Search data
        • Indexes and embedding functions
        • Monitoring and maintenance
        • API reference
      • Flash application scenario
        • Limitations and constraints
        • Connect
        • Collection and app management
        • Data operations
  • Data Pipeline
    • Data ingestion
      • Data migration
        • Data migration overview
        • Use mydumper and myloader to migrate data from a MySQL database
        • Use DBCAT to migrate table structures from a MySQL database
        • Use DataX to migrate table data from a MySQL database
        • Use DBCAT to migrate table structures from an Oracle database
        • Use DataX to migrate table data from an Oracle database
        • Use DBCAT to migrate table structures from a DB2 LUW database
        • Migrate from CSV files
          • Use DataX
          • Use LOAD DATA
        • Migrate by using SQL statements
          • Export data using the OUTFILE statement
      • Data import
        • Data import overview
        • INSERT INTO SELECT
          • Use the INSERT INTO SELECT FROM FILES statement for direct load
          • Import data from external tables using INSERT INTO SELECT
        • Import data via direct load using the CREATE TABLE AS SELECT statement
        • Import data by using obloader
    • Data delivery
      • Data lake
        • Data lake overview
        • Data lake integration
          • Access Hive tables through HMS Catalog
          • Load an Iceberg table through Catalog
          • Read Paimon tables by using plugins
          • ODPS Catalog and external tables
          • Catalogs and external tables
          • File external tables
        • External tables via URL
    • Data sharing
      • Automatic catalog data synchronization
      • Manual catalog data synchronization
  • Data Processing
    • Structured data processing
      • In-database processing
      • Materialized views
      • Data processing tools
    • Unstructured data processing
      • Vector embedding
        • Overview of Vector Embedding Technology
        • Use the AI_EMBED function
        • Use external embedding models
  • Data Branching
    • Overview of Fork
    • Fork Table
    • Fork Database
  • AI Search
    • Vector search
      • Vector search overview
      • Perform vector search using SQL
      • Vector data types overview
      • Store vector data
      • Vector index
        • Overview of vector indexes
        • Vector index memory management
        • Dense index
          • Overview of dense indexes
          • Index type selection
          • HNSW series indexes
          • IVF series indexes
        • Sparse index
          • In-memory sparse vector index
        • Monitor and maintain indexes
        • Index performance optimization
      • Search index
      • Use SQL functions
      • Vector nearest neighbor search
      • FAQ on AI scenarios
    • Semantic search
    • Full-text search
    • Hybrid search
    • Rerank search
  • Query Acceleration
    • Statistics
    • Choose the query parallelism
    • Accelerate queries with materialized views
    • Log in to an user tenant
      • Cluster overview
      • Compute service management
          • Reset cluster parameters
          • Update object storage access credentials
          • Data load balancing overview
          • Transfer a partition
          • Cancel a balance job
          • Stop and resume a balance job
          • Table group weight management
            • Aggregation of user tables under a database
            • Set table group weights
            • Clear a table group's weight
            • Application scenarios of table group weight balancing
          • Partition weight management
            • Set partition weights
            • Clear partition weights
          • Partition balance management
            • Configure a scheduled partition balancing task
            • Manually trigger partition balancing
            • View the configurations of a scheduled partition balancing task
            • View the trigger history of scheduled partition balancing tasks
            • View background partition balancing tasks
            • View the history of background partition balancing tasks
          • GTS exclusive application case
      • Object storage management
        • Object storage overview
        • Update object storage information
        • Object storage-related views and parameters
        • FAQ on object storage
      • LogService management
        • LogService parameters
        • LogService operations
          • View a LogService node
          • Add a LogService node
          • Delete a LogService node
          • Replace a LogService node
          • Rotate LogService access credentials
          • View LogService parameters
          • Modify LogService parameters
        • LogService load balancing
          • LogService load balancing overview
          • View the load balancing status
          • Configure the load balancing strategy
          • Resource isolation overview
          • Configure cgroup
          • Calibrate disk performance
          • Resource isolation configuration examples for background tasks
        • View tenant system variables
        • Modify tenant system variables
          • Introduction to tenant scaling
          • Resource planning for tenant scaling
          • Tenant pre-scaling
          • Scale tenants by adjusting resource specifications
          • Scale tenants by adjusting the unit number
          • Scale tenants by adjusting the primary zone
          • Smooth scaling application scenarios
        • Modify tenant attributes
          • View resource pools
          • Merge and split a resource pool
        • Manage resource specifications
          • View resource specifications
          • Modify a unit config
          • Drop a unit config
    • Manage log streams
      • Create a log stream
      • Modify a log stream
      • Replicas
          • Reduce replicas
          • Replica migration
          • Modify the quorum size of a log stream
          • Cancel a replica task
        • High availability at the proxy layer
        • High availability at the database layer
        • Disaster recovery deployment solutions
        • Overview of the recycle bin
        • View recycle bin objects
        • Clean up the recycle bin
      • Flashback query
      • Overview of security permissions
          • Handle login failures
        • Overview of access control
          • User and permission overview
          • Permissions
            • Permission classification
            • Grant privileges directly
            • Role management
              • Role management overview
              • Add privileges to a role
              • Grant roles to users or other roles
              • Revoke roles from a user or role
            • Indirect authorization
        • Row-level security
      • Data encryption
        • Data encryption overview
          • Overview of data transmission encryption
          • Transport encryption for OBServer
        • Tenant master key management
          • Overview of tenant master keys
          • Generate tenant master key
          • Overview of database transparent encryption
          • Set up transparent data encryption for a newly created table
          • Enable transparent data encryption for an existing table
        • Column encryption
          • Column encryption overview
          • Create a column encryption rule
          • Column encryption privilege management
          • FAQ on column encryption
        • Security audit overview
          • Enable security auditing
          • Set an auditing rule
          • View auditing records
          • Disable security auditing
      • Physical backup and restore with a minimal experience
        • Overview of log archiving
        • Enable archiving mode
        • Disable archiving mode
        • View piece information
        • View archiving progress
        • View archive parameters
        • Change the archive destination
        • Clear the archive path configuration
        • Introduction to log archiving views
        • Data backup overview
        • Prepare for backup
        • Initiate a full data backup
        • Back up parameters
        • Stop a backup
        • View data backup results
        • View data backup parameters
        • Introduction to data backup-related views
      • Update object storage key information
        • Automatic backup cleanup
          • Automatically clean up expired backups
          • Delete a cleanup policy
        • Manual backup cleanup
          • Manually trigger expired backup cleanup
          • Manually clean up specified backup or archive data
          • Manually clear a backup or archive path
        • Cancel a cleanup task
        • View backup cleanup progress
        • View backup cleanup results
        • Introduction to backup cleanup parameters
        • Introduction to cleanup-related views
        • Preparations before restore
        • Perform physical restore
        • Restore from a specified path
        • View the result of physical restore
        • Segment-based log replay for a standby tenant
        • Convert a standby tenant into a primary tenant
        • Upgrade a tenant after restore is complete
        • Introduction to physical restore parameters
        • Introduction to views related to physical restore
      • Backup and restore performance tuning
      • Appendix: S3 path format
      • Monitoring overview
          • Overview of system monitoring metrics
          • SYSSTAT metrics
          • Lock events
          • Overview of SQL monitoring
      • Root service events
      • Log overview
      • Log interpretation
      • Log control methods
      • Log monitoring metrics
      • Alert logs
  • Performance Test
    • TPC-DS
      • OceanBase AI Database TPC-DS test
      • OceanBase AI Database TPC-DS test report
    • TPC-H
      • OceanBase AI Database TPC-H test
      • OceanBase AI Database TPC-H test report
        • Introduction to Configuration Management
          • Overview of minor compaction
          • Automatic minor compaction
          • Manually trigger a minor compaction
          • Overview of major compaction management
          • Schedule daily tenant major compactions
          • Window compaction
          • Adaptive compaction
          • Manually trigger a major compaction
          • Modify major compaction configuration
          • Data compression overview
          • Use data encoding and compression
        • Use the TTL feature
        • Custom hot and cold data storage policies
          • Overview of custom hot/cold storage policies
          • Create a table-level hot/cold storage policy
          • Create a partition-level hot/cold storage policy
          • Modify a table-level hot/cold storage policy
          • Modify a partition-level hot/cold storage policy
          • O&M guide for custom hot/cold storage policies
        • Memory management overview
        • Set the maximum memory for a database
        • Internal system memory management
        • Memory management within a tenant
        • Plan cache memory management
        • View memory usage information
        • Common memory issues
        • Overview of OceanBase AI Database threads
        • Multi-tenant threads
        • View thread status
        • Background threads of OceanBase AI Database
        • Configure dynamic expansion of disk data files
        • View disk space usage of a tenant or table
      • Overview of database object management
        • About tables
        • Column Skip Index attribute
        • View tables
        • Change the attribute of a replicated table
        • Truncate a table
          • External tables and external files
          • Create and query external tables
          • Create a partitioned external table
          • Data type mappings
        • Partitioning overview
        • Partition splitting
          • Overview of partition splitting
          • Manually split a partition
          • Automatic partition splitting
          • Recommended configurations for automatic partitioning
        • Dynamic partitioning
          • Overview of dynamic partitioning
          • Create a dynamic partitioned table
          • View a dynamic partitioned table
          • Modify a dynamic partitioned table
          • Dynamic partition management tasks
        • Drop a partition
        • Truncate partitions
        • Query data from a specified partition
          • Index overview
          • Local index
          • Global index
        • Partition exchange
        • About table groups
        • View table group information
        • Manage tables within a table group
        • Delete a table group
        • About indexes
        • View indexes
        • List of system functions supported for function-based indexes
        • List of system functions not supported for function-based indexes
        • Manage regular views
        • Manage materialized views
          • Overview of materialized views
          • Materialized view logs
          • Create a materialized view
          • Refresh a materialized view
          • Query rewrite using materialized views
          • Query materialized views
          • Modify materialized view attributes
          • Drop a materialized view
          • Materialized view resource isolation
        • View sequences
        • View trigger information
        • View created DBLinks
        • Access data in a remote database through DBLink
      • Create and manage catalogs
        • Overview of Catalog
        • Create a catalog
        • View catalogs
        • Drop a catalog
    • Write and read data
        • Single-table query
          • INNER JOIN
          • FULL JOIN
          • LEFT JOIN
          • RIGHT JOIN
          • Use numeric functions in queries
          • Use time functions in queries
          • Lock query results with SELECT FOR UPDATE
          • Lock in share mode
          • Use regular expressions in queries
        • Query using DBLink
      • Transaction management overview
    • AI Function service
      • Overview of AI Function Service
      • Get started with AI Function Service
      • AI Function Service Permissions
      • Register an AI model
      • Interaction with AI models (Batch File)
      • Syntax and examples of AI functions
      • View AI model information
          • Overview of management commands
            • ADD REPLICA
            • ADD RESTORE SOURCE
            • BACKUP CLUSTER PARAMETERS
            • BALANCE JOB
            • CANCEL REPLICA TASK
            • CREATE LS
            • CLEAR RESTORE SOURCE
            • DELETE BACKUP ALL
            • DELETE BACKUPSET/ARCHIVELOG_PIECE
            • DELETE OBSOLETE BACKUP
            • LOAD MODULE DATA
            • MAJOR AND MINOR
            • MIGRATE REPLICA
            • MODIFY LS
            • MODIFY PAXOS_REPLICA_NUM
            • MODIFY REPLICA
            • FLUSH SEQUENCE CACHE
            • FLUSH LOCAL_CACHE
            • FLASHBACK STANDBY LOG
            • REMOVE REPLICA
            • RESTORE PREVIEW
            • SERVICE_NAME
            • TTL
          • SHOW RESTORE PREVIEW
        • User tenants
            • ROWID Pseudo-Column
              • Overview of data types
                • Overview of numeric types
                • Integer types
                • Fixed-point types
                • Floating-point types
                • BIT-Value type
                • Overview of date and time types
                • DATE, DATETIME and TIMESTAMP types
                • Character type overview
                • Overview of LOB and text types
                • BLOB type
                • TEXT type
                • STRING type
                • LOB types
                • LOB_WRITEAPPEND
              • Enumeration types
              • Collection types
                • Overview of the JSON data type
                • JSON data type conversion
                • Update partial data in a JSON document
                • Semi-structured encoding
                • Overview of spatial data types
                • Spatial Reference System (SRS)
                • Create a spatial column
                • Create a spatial index
              • Roaring bitmap types
                • Overview of Efficient Compression for Bitmap Data Types
                • Create an efficient compressed bitmap column
              • Array data types
                • Overview of Array Element Types
                • Create an array column
              • Map data types
                • Overview of mapped data types
                • Create a mapped column
              • Overview of Expressions
              • Syntax of Expressions
              • Simple Expressions
              • Compound Expressions
              • Conditional Expressions
              • Column Expressions
              • Date and time expressions
              • Function Expressions
              • Interval Expressions
              • List of Expressions
              • Collation
              • Column-level character set and collation
              • Character expression character sets and collations
              • Character set and collation of client connections
              • Overview of Literals
              • String text
              • Numbers
              • Date and time values
              • Bit value
              • NULL values
            • Schema object name
                • Overview of hints
                • Control query optimization using the Query Block Name and QB_NAME hint
                  • Global hints
                    • Optimizer Stats Hint under Global Hint Types
                    • Transform hint under global hints
                    • Other hints under global hints
                    • Access path hints under the Optimized hint type
                    • Join Order Hint under Optimized Hint Type
                    • Join Operation Hint under Optimized Hint Type
                    • Subquery hint under Optimized hint type
                    • Group by hint under optimized hint type
                    • DISTINCT hint under Optimized hint type
                    • Set hint under Optimized hint type
                    • Distributed DML Hints under Optimized Hint Type
                    • Vector Index Hint under Optimized Hint Type
                  • Transform hints
                    • Stmt Transform Hint under the Transform Hint Type
                    • Cost Based Transform Hint under the Transform Hint Type
                    • Transform Hints of the Heuristics Type
                    • Other hints under the Transform hint type
                  • Outline-related hint
            • Operator overview
            • Assignment operators
            • Character concatenation operators
            • BINARY conversion operator
            • CASE Conditional Operator
            • Function overview
                • DATE_TRUNC
                • MONTHS_ADD
                • FORMATDATETIME
                • TOUNIXTIMESTAMP
                • parseDateTime
                • KEYVALUE
                • MAX_PT
                • MD5_CONCAT_WS
                • SPLIT_PART
                • URL_DECODE
                • URL_ENCODE
                • EDITDISTANCE
                • DECODE_TRACE_ID
              • ARG_MAX
              • ARG_MIN
              • STRING_AGG
              • AVG_WEIGHTED
              • ARBITRARY
              • ANY
              • GROUPCONCAT
              • STDDEVSAMP
              • UNIQ
              • VARSAMP
              • LAGINFRAME
              • LEADINFRAME
              • ENHANCED_AES_ENCRYPT
              • ENHANCED_AES_DECRYPT
              • PASSWORD
              • SM3
              • SM4_ENCRYPT
              • SM4_DECRYPT
              • CATALOG
              • LAST_INSERT_ID Behavior Description
              • OB_TRANSACTION_ID
              • Overview of JSON functions
              • JSON_TABLE function
              • Overview of XML functions
            • Table functions
              • Overview of TABLE FUNCTIONS
              • FILES table function
              • Overview of Spatial Functions
              • Create a geometric value function
              • Spatial operators
              • Spatial relationship functions
              • Geometric property functions
              • Spatial Constructors
              • Geometric Processing Functions
              • _ST_GeoHash
              • Overview of Lock Functions
              • RELEASE_ALL_LOCKS()
            • Bitmap functions
              • Overview of bitmap functions
              • Bitmap Constructor
              • Bitmap cardinality functions
              • Bitmap arithmetic functions
              • Bitmap predicate functions
              • Bitmap output functions
              • Bitmap aggregate functions
            • Array functions
              • Overview of array functions
              • Array constructor
              • Array comparison functions
              • Array output functions
              • Array functions
            • Text processing functions
              • TOKENIZE
            • Audit functions
              • Overview of audit functions
              • AUDIT_LOG_FILTER_SET_FILTER
              • AUDIT_LOG_FILTER_SET_USER
            • Map functions
              • Overview of mapping functions
              • Constructor of Map
              • Mapping judgment function
              • Mapping functions
              • MATCH AGAINST
              • ISNAN
            • Subquery
            • Connections
            • Full-text query
            • Generalized Table Expressions
            • ALTER COMPILE
            • ALTER LOCATION
            • ALTER MATERIALIZED VIEW
            • ALTER MATERIALIZED VIEW LOG
            • ALTER SENSITIVE RULE
            • ALTER POLICY
            • ALTER SYSTEM FLUSH SEQUENCE CACHE
            • MAJOR AND MINOR
            • STORAGE_CACHE_POLICY_EXECUTOR
            • ALTER TABLESPACE
            • ALTER INSTANCE ROTATE INNODB MASTER KEY
            • ALTER EVENT
            • CACHE INDEX
            • CREATE CONCURRENT_LIMITING_RULE
            • CREATE EXTERNAL CATALOG
            • CREATE LOCATION
            • CREATE MATERIALIZED VIEW
            • CREATE POLICY
            • CREATE FORMAT OUTLINE
            • CREATE SENSITIVE RULE
            • CHECKSUM TABLE
            • CREATE EVENT
            • DROP CATALOG
            • DROP CONCURRENT_LIMITING_RULE
            • DROP EVENT
            • DROP LOCATION
            • DROP MATERIALIZED VIEW
            • DROP MATERIALIZED VIEW LOG
            • DROP SENSITIVE RULE
            • DROP POLICY
            • FLUSH TABLE
            • LOAD_FILE
            • LOAD INDEX INTO CACHE
            • REPAIR TABLE
              • WINDOW clause
              • HYBRID_SEARCH
              • PARTITION TIER
            • SET CATALOG
            • SUBMIT JOB
            • SHOW JOB STATUS
            • CANCEL JOB
            • UNLOCK TABLES
            • XA TRANSACTION
            • Overview of DDL features
            • Online DDL and Offline DDL Operations
            • Generate columns
            • Number type conversion rules
            • Overview of PseudoColumns
            • PARTITIONID Pseudo Column
            • Sequence Pseudocolumns
            • Overview of SQL Conditions
            • Condition priorities
            • Pattern matching conditions
            • Null value conditions
            • IN Condition
            • JSON Member Conditions
            • Boolean test conditions
        • SQL Writing Restrictions
          • SELECT statement writing specifications
          • DML statement writing guidelines
          • DDL statement writing guidelines
          • Multi-table association guidelines
          • Table scan method specifications
          • Transaction specifications
          • Usage guidelines for cache
          • Guidelines for Using HINTS
          • Other related specifications
          • Implicit type conversion related
          • Suggestions on using JOIN tables
          • Weak-consistency read
          • Paginated query
      • Reserved keywords
      • Data type conversion behavior in strict mode
        • PL Overview
        • Key features of PL
        • Architecture of PL
      • PL syntax structure
        • Overview of stored programs
        • Variables of stored programs
        • Stored procedure
        • Stored Procedures and Privilege Management
        • External storage functions
        • Trigger
        • EVENT
        • SQL Transpiler
        • PL asynchronous commit optimization
        • Cursor overview
        • Limitations on server-side cursors
        • Overview of exception handling
        • Scope of handlers
        • Diagnostic section
        • Exception Handling and OUT/INOUT Parameters
        • Overview of system packages
        • DBMS_AI_SERVICE
          • Overview of DBMS_AI_SERVICE
          • CREATE_AI_MODEL
          • DROP_AI_MODEL
          • CREATE_AI_MODEL_ENDPOINT
          • ALTER_AI_MODEL_ENDPOINT
          • DROP_AI_MODEL_ENDPOINT
          • REGISTER_PROVIDER
          • ALTER_PROVIDER
          • UNREGISTER_PROVIDER
          • ALTER_MODEL_PROFILE
          • DROP_MODEL_PROFILE
          • CREATE_AI_GATEWAY
          • ALTER_AI_GATEWAY
          • DROP_AI_GATEWAY
        • DBMS_ASYNC_INDEX
          • Overview of DBMS_ASYNC_INDEX
          • FORCEMERGE
        • DBMS_DAILY_MAINTENANCE
          • Overview of DBMS_DAILY_MAINTENANCE
          • TRIGGER_WINDOW_COMPACTION_PROC
          • SET_THREAD_COUNT
        • DBMS_HYBRID_SEARCH
          • Overview of DBMS_HYBRID_SEARCH
          • SEARCH
          • GET_SQL
        • DBMS_MVIEW
          • Overview of DBMS_MVIEW
          • PURGE_LOG
          • KILL_REFRESH
          • REFRESH_REPORT
        • DBMS_MVIEW_STATS
          • Overview of DBMS_MVIEW_STATS
          • PURGE_REFRESH_STATS
          • SET_MVREF_STATS_PARAMS
          • SET_SYSTEM_DEFAULT
        • DBMS_PARTITION
          • Overview of DBMS_PARTITION
          • MANAGE_DYNAMIC_PARTITION
          • Overview of DBMS_RESOURCE_MANAGER
          • COPY_PLAN
          • System Packages
          • Overview of DBMS_STATS
          • DELETE_CATALOG_GLOBAL_PREFS
          • DELETE_CATALOG_TABLE_PREFS
          • GATHER_CATALOG_TABLE_STATS
          • GET_CATALOG_GLOBAL_PREFS
          • GET_CATALOG_PREFS
          • LOCK_CATALOG_PARTITION_STAT
          • LOCK_CATALOG_TABLE_STAT
          • SET_CATALOG_GLOBAL_PREFS
          • SET_CATALOG_TABLE_PREFS
          • UNLOCK_CATALOG_PARTITION_STAT
          • UNLOCK_CATALOG_TABLE_STAT
          • CANCEL_GATHER_STATS
          • Overview of DBMS_TRUSTED_CERTIFICATE_MANAGER
          • ADD_TRUSTED_CERTIFICATE
          • DELETE_TRUSTED_CERTIFICATE
          • UPDATE_TRUSTED_CERTIFICATE
          • Overview of DBMS_UDR
        • DBMS_VECTOR
          • Overview of DBMS_VECTOR
          • REBUILD_INDEX
          • INDEX_VECTOR_MEMORY_ESTIMATE
          • INDEX_VECTOR_MEMORY_ADVISOR
          • FLUSH_INDEX
          • COMPACT_INDEX
          • TRIGGER_ASYNC_TASK
          • ALTER_INDEX_PARAMS
          • Overview of DBMS_WORKLOAD_REPOSITORY
          • Overview of DBMS_SESSION
          • Overview of DBMS_APPLICATION_INFO
          • Overview of DBMS_XPLAN
        • DBMS_XPROFILE
          • Overview of DBMS_XPROFILE
          • DISPLAY_PROFILE
        • DBMS_BALANCE
          • Overview of DBMS_BALANCE
          • SET_BALANCE_WEIGHT
          • CLEAR_BALANCE_WEIGHT
          • TRIGGER_PARTITION_BALANCE
          • SET_TABLEGROUP_BALANCE_WEIGHT
          • CLEAR_TABLEGROUP_BALANCE_WEIGHT
        • DBMS_OB_LIMIT_CALCULATOR
          • Overview of DBMS_OB_LIMIT_CALCULATOR
        • DBMS_EXTERNAL_TABLE
          • Overview of DBMS_EXTERNAL_TABLE
          • AUTO_REFRESH_EXTERNAL_TABLE
        • DBMS_JAVA
          • Overview of DBMS_JAVA
          • LOADJAVA
          • DROPJAVA
          • GRANT_PERMISSION
          • RESTRICT_PERMISSION
          • REVOKE_PERMISSION
          • DISABLE_PERMISSION
          • ENABLE_PERMISSION
          • DELETE_PERMISSION
        • DBMS_PYTHON
          • Overview of DBMS_PYTHON
          • DROPPYTHON
          • LOADPYTHON
        • DBMS_DATA_DICT
          • DBMS_DATA_DICT
      • Reserved and Non-Reserved PL Keywords
          • information_schema.events
          • information_schema.TRIGGERS
          • oceanbase.CDB_OB_SHARED_MACRO_BLOCK_GC_STAT
          • CDB_INDEX_USAGE
          • CDB_MVIEW_LOGS
          • oceanbase.CDB_MVIEW_RUNNING_JOBS
          • CDB_MVIEWS
          • CDB_MVREF_CHANGE_STATS
          • CDB_MVREF_RUN_STATS
          • CDB_MVREF_STATS
          • CDB_MVREF_STATS_PARAMS
          • CDB_MVREF_STMT_STATS
          • oceanbase.CDB_OB_AI_BATCH_TASK_HISTORY
          • oceanbase.CDB_OB_AI_BATCH_TASKS
          • oceanbase.CDB_OB_AI_GATEWAY_ENDPOINTS
          • oceanbase.CDB_OB_AI_GATEWAYS
          • oceanbase.CDB_OB_AI_MODEL_ENDPOINTS
          • oceanbase.CDB_OB_AI_MODEL_PROFILES
          • oceanbase.CDB_OB_AI_MODEL_PROVIDERS
          • oceanbase.CDB_OB_AI_MODELS
          • oceanbase.CDB_OB_AGENT_DB_BACKGROUND_TASKS
          • oceanbase.CDB_OB_AGENT_DB_BACKGROUND_TASK_HISTORY
          • oceanbase.CDB_OB_CCL_RULES
          • oceanbase.CDB_OB_CS_REPLICA_STATS
          • oceanbase.CDB_OB_DYNAMIC_PARTITION_TABLES
          • oceanbase.CDB_OB_LOB_CHECK_EXCEPTION_RESULT
          • oceanbase.CDB_OB_LOB_CHECK_TASKS
          • oceanbase.CDB_OB_LS_REPLICA_TASK_HISTORY
          • oceanbase.CDB_OB_OBJECT_BALANCE_WEIGHT
          • oceanbase.CDB_OB_SERVICES
          • oceanbase.CDB_OB_RSRC_DIRECTIVES
          • oceanbase.CDB_OB_SENSITIVE_COLUMNS
          • oceanbase.CDB_OB_SENSITIVE_RULE_PLAINACCESS_USERS
          • oceanbase.CDB_OB_SENSITIVE_RULES
          • oceanbase.CDB_OB_SERVER_SPACE_USAGE
          • oceanbase.CDB_OB_SPACE_USAGE
          • oceanbase.CDB_OB_STORAGE_SPACE_USAGE
          • oceanbase.CDB_OB_STORAGE_IO_USAGE
          • oceanbase.CDB_OB_SPM_EVO_RESULT
          • oceanbase.CDB_OB_TABLE_SPACE_USAGE
          • oceanbase.CDB_OB_TEMP_FILES
          • oceanbase.CDB_OB_TENANT_FLASHBACK_LOG_SCN
          • oceanbase.CDB_OB_TTL_TASKS
          • oceanbase.CDB_OB_TTL_TASK_HISTORY
          • oceanbase.CDB_OB_VECTOR_INDEX_TASKS
          • oceanbase.CDB_OB_VECTOR_INDEX_TASK_HISTORY
          • oceanbase.CDB_WR_RES_MGR_SYSSTAT
          • oceanbase.CDB_WR_SQL_PLAN
          • oceanbase.CDB_OB_EXTERNAL_RESOURCES
          • oceanbase.DBA_INDEX_USAGE
          • oceanbase.DBA_MVIEW_DEPS
          • oceanbase.DBA_MVIEW_LOGS
          • oceanbase.DBA_MVIEW_RUNNING_JOBS
          • oceanbase.DBA_MVIEWS
          • oceanbase.DBA_MVREF_CHANGE_STATS
          • oceanbase.DBA_MVREF_RUN_STATS
          • oceanbase.DBA_MVREF_STATS
          • oceanbase.DBA_MVREF_STATS_PARAMS
          • oceanbase.DBA_MVREF_STATS_SYS_DEFAULTS
          • oceanbase.DBA_MVREF_STMT_STATS
          • oceanbase.DBA_OB_AI_BATCH_TASK_HISTORY
          • oceanbase.DBA_OB_AI_BATCH_TASKS
          • oceanbase.DBA_OB_AI_GATEWAY_ENDPOINTS
          • oceanbase.DBA_OB_AI_GATEWAYS
          • oceanbase.DBA_OB_AI_MODEL_ENDPOINTS
          • oceanbase.DBA_OB_AI_MODEL_PROFILES
          • oceanbase.DBA_OB_AI_MODEL_PROVIDERS
          • oceanbase.DBA_OB_AI_MODELS
          • oceanbase.DBA_OB_AGENT_DB_BACKGROUND_TASKS
          • oceanbase.DBA_OB_AGENT_DB_BACKGROUND_TASK_HISTORY
          • oceanbase.DBA_OB_CCL_RULES
          • oceanbase.DBA_OB_CS_REPLICA_STATS
          • oceanbase.DBA_OB_DYNAMIC_PARTITION_TABLES
          • oceanbase.DBA_OB_EXTERNAL_PART_COL_STATISTICS
          • oceanbase.DBA_OB_EXTERNAL_TAB_COL_STATISTICS
          • oceanbase.DBA_OB_EXTERNAL_TAB_STATISTICS
          • oceanbase.DBA_OB_EXTERNAL_RESOURCES
          • DBA_OB_FORMAT_OUTLINES
          • oceanbase.DBA_OB_LOB_CHECK_EXCEPTION_RESULT
          • oceanbase.DBA_OB_LOB_CHECK_TASKS
          • oceanbase.DBA_OB_SERVICES
          • oceanbase.DBA_OB_RSRC_DIRECTIVES
          • oceanbase.DBA_OB_STORAGE_SPACE_USAGE
          • oceanbase.DBA_OB_STORAGE_IO_USAGE
          • oceanbase.DBA_OB_SHARED_MACRO_BLOCK_GC_STAT
          • oceanbase.DBA_OB_SPM_EVO_RESULT
          • oceanbase.DBA_OB_TEMP_FILES
          • oceanbase.DBA_OB_TENANT_FLASHBACK_LOG_SCN
          • oceanbase.DBA_OB_TTL_TASKS
          • oceanbase.DBA_OB_TTL_TASK_HISTORY
          • oceanbase.DBA_OB_VECTOR_INDEX_TASKS
          • oceanbase.DBA_OB_VECTOR_INDEX_TASK_HISTORY
          • oceanbase.DBA_OB_ZONE_STORAGE
          • oceanbase.DBA_RECYCLEBIN
          • oceanbase.DBA_TABLES
          • oceanbase.DBA_WR_RES_MGR_SYSSTAT
          • oceanbase.DBA_WR_SQL_PLAN
          • GV$OB_CGROUP_CONFIG
          • GV$OB_EXTERNAL_CATALOG_CLIENT_POOL_STAT
          • GV$OB_FUNCTION_IO_STAT
          • GV$OB_GROUP_IO_STAT
          • GV$OB_HMS_CLIENT_POOL_STAT
          • GV$OB_HNSW_INDEX_INFO
          • GV$OB_HNSW_INDEX_SEGMENT_INFO
          • GV$OB_IVF_INDEX_INFO
          • GV$OB_KV_CONNECTIONS
          • GV$OB_LS_SNAPSHOTS
          • GV$OB_NIC_INFO
          • GV$OB_PLUGINS
          • GV$OB_RES_MGR_SYSSTAT
          • GV$OB_SERVER_STORAGE
          • GV$OB_SESSION_PS_INFO
          • GV$OB_SHARED_STORAGE_QUOTA
          • GV$OB_SINDI_INDEX_INFO
          • GV$OB_SQL_CCL_STATUS
          • GV$OB_LOCAL_CACHE
          • GV$OB_LOCAL_CACHE_DIAGNOSE
          • GV$OB_OBJECT_TYPE_IO_STAT
          • GV$OB_STORAGE_CACHE_TASKS
          • GV$OB_TABLET_LOCAL_CACHE
          • GV$OB_TABLET_REPLICA_INFO
          • GV$OB_TENANT_RESOURCE_LIMIT
          • GV$OB_VECTOR_MEMORY
          • GV$OB_KV_CLIENT_INFO
          • V$OB_COMPATIBILITY_CONTROL
          • V$OB_CGROUP_CONFIG
          • V$OB_DYNAMIC_PARTITION_TABLES
          • V$OB_EXTERNAL_CATALOG_CLIENT_POOL_STAT
          • V$OB_FUNCTION_IO_STAT
          • V$OB_GROUP_IO_STAT
          • V$OB_HMS_CLIENT_POOL_STAT
          • V$OB_HNSW_INDEX_SEGMENT_INFO
          • V$OB_HNSW_INDEX_INFO
          • V$OB_IVF_INDEX_INFO
          • V$OB_KV_CLIENT_INFO
          • V$OB_KV_GROUP_COMMIT_STATUS
          • V$OB_KV_CONNECTIONS
          • V$OB_LS_SNAPSHOTS
          • V$OB_NIC_INFO
          • V$OB_PLUGINS
          • V$OB_RES_MGR_SYSSTAT
          • V$OB_SERVER_STORAGE
          • V$OB_SESSION_PS_INFO
          • V$OB_SHARED_STORAGE_QUOTA
          • V$OB_SINDI_INDEX_INFO
          • V$OB_SQL_CCL_STATUS
          • V$OB_SHARED_SSTABLES
          • V$OB_LOCAL_CACHE
          • V$OB_LOCAL_CACHE_DIAGNOSE
          • V$OB_OBJECT_TYPE_IO_STAT
          • V$OB_STORAGE_CACHE_TASKS
          • V$OB_TABLET_LOCAL_CACHE
          • V$OB_TABLET_REPLICA_INFO
          • V$OB_TENANT_RESOURCE_LIMIT
          • V$OB_TRANSACTION_SCHEDULERS
          • V$OB_VECTOR_MEMORY
      • User tenant views
          • mysql.audit_log_filter
          • mysql.audit_log_user
          • oceanbase.DBA_JAVA_POLICY
          • oceanbase.DBA_OB_OBJECT_BALANCE_WEIGHT
          • oceanbase.DBA_OB_SENSITIVE_COLUMNS
          • oceanbase.DBA_OB_SENSITIVE_RULE_PLAINACCESS_USERS
          • oceanbase.DBA_OB_SENSITIVE_RULES
          • oceanbase.DBA_OB_TABLE_SPACE_USAGE
          • oceanbase.DBA_RLS_POLICIES
          • oceanbase.USER_JAVA_POLICY
          • GV$OB_NIC_INFO
          • GV$OB_LOCAL_CACHE
          • GV$OB_TABLET_MACRO_CACHE_STAT
          • V$OB_LS_SNAPSHOTS
          • V$OB_NIC_INFO
          • V$OB_LOCAL_CACHE
          • V$OB_TABLET_MACRO_CACHE_STAT
          • V$RESTORE_POINT
      • Overview of Metrics
      • Common wait events
      • Overview of parameters and system variables
        • Parameter overview
          • alert_log_level
          • async_ps_cursor_max_count
          • system_protected_sys_variables
          • system-protected-tenant-parameters
          • clog_io_isolation_mode
          • enable_logservice
          • enable_ob_error_msg_style
          • ext_plugin_config
          • global_background_cpu_quota
          • io_scheduler_thread_count
          • logservice_access_point
          • log_storage_warning_trigger_percentage
          • ob_python_home
          • ob_enable_java_env
          • ob_java_home
          • ob_java_connector_path
          • ob_java_opts
          • ob_enable_java_udf_sandbox
          • ob_enable_utl_http
          • plugins_load
          • rest_oauth2_credential_refresh_interval
          • rest_oauth2_credential_evict_time
          • sync_io_thread_count
          • sys_ckpt_thread_score
          • unit_gc_wait_time
          • agent_db_background_delete_thread_score
          • agent_db_hot_namespace_ttl
          • approx_count_distinct_precision
          • audit_log_buffer_size
          • audit_log_compression
          • attach_shared_sstable_thread_score
          • audit_log_enable
          • audit_log_format
          • audit_log_max_size
          • audit_log_path
          • audit_log_prune_seconds
          • audit_log_query_sql
          • audit_log_rotate_on_size
          • audit_log_strategy
          • auto_split_tablet_size
          • catalog_sync_target
          • default_delta_format
          • default_load_mode
          • default_micro_block_format_version
          • default_skip_index_level
          • default_storage_cache_policy
          • default_table_merge_engine
          • default_table_organization
          • default_table_store_format
          • direct_load_allow_fallback
          • ddl_high_thread_score
          • document_ai_file_max_size
          • dtl_compress_func
          • enable_agent_db_background_task
          • enable_adaptive_plan_cache
          • enable_auto_split
          • enable_database_sharding_none
          • enable_hbase_rowkey_ttl
          • enable_pl_rich_error_msg
          • enable_gts_standalone
          • enable_kv_group_commit
          • enable_lake_table_parallel_resolving
          • enable_lock_priority
          • enable_manual_storage_cache_policy
          • enable_mlog_auto_maintenance
          • enable_mv_binlog_minimal_mode
          • enable_ls_leader_balance
          • enable_ttl
          • enable_window_compaction
          • enable_ps_parameterize
          • external_table_io_hole_size
          • external_table_io_range_size
          • external_table_csv_max_buffer_size
          • ob_vector_search_strategy
          • global_index_auto_split_policy
          • inc_sstable_upload_thread_score
          • shared_gc_executor_thread_score
          • shared_gc_generator_thread_score
          • json_document_max_depth
          • kv_group_commit_batch_size
          • kv_group_commit_rw_mode
          • kv_hbase_client_scanner_timeout_period
          • kv_ttl_delete_max_ops
          • kv_transport_compress_threshold
          • lake_table_pruning_thread_count
          • load_data_diagnosis_log_compression
          • load_data_diagnosis_log_max_size
          • load_vector_index_on_follower
          • ls_scale_out_factor
          • mds_compaction_high_thread_score
          • mds_compaction_mid_thread_score
          • mds_minor_compact_trigger
          • mlog_trim_interval
          • model_max_retries
          • model_request_timeout
          • mv_refresh_concurrency
          • ob_encoding_granularity
          • ob_enable_python_udf
          • ob_vector_index_active_segment_max_size
          • ob_vector_index_merge_trigger_percentage
          • ob_vector_memory_limit_percentage
          • px_node_policy
          • package_state_sync_max_size
          • px_target_high_watermark
          • px_target_low_watermark
          • px_target_workers_per_cpu
          • recover_table_concurrency
          • recover_table_dop
          • result_cache_max_size
          • result_cache_max_result
          • ob_result_cache_evict_percentage
          • shared_log_retention
          • shared_storage_data_check_thread_score
          • spill_compression_codec
          • sql_func_extension_mode
          • storage_rowsets_size
          • sts_credential
          • suspend_storage_cache_task
          • kv_transport_compress_func
          • ttl_duty_time
          • vector_index_memory_saving_mode
          • vector_index_optimization_concurrency
          • vector_index_optimize_duty_time
          • vector_task_thread_limit_percent
          • zone_deploy_mode
          • ap_query_cost_threshold
          • ap_query_route_policy
          • ap_query_replica_fallback
          • default_authentication_plugin
          • enable_optimizer_rowgoal
          • innodb_stats_persistent
          • long_query_time
          • mview_refresh_dop
          • ob_compatibility_control
          • ob_compatibility_version
          • ob_enable_ps_parameter_anonymous_block
          • ob_enable_pl_async_commit
          • ob_enable_rich_error_msg
          • ob_table_access_policy
          • ob_security_version
          • partition_index_dive_limit
          • pid_file
          • plsql_can_transform_sql_to_assign
          • port
          • query_rewrite_enabled
          • query_rewrite_integrity
          • socket
          • range_index_dive_limit
          • sql_transpiler
        • Session variables
          • enable_sql_plan_monitor
          • ob_hnsw_ef_search
          • ob_ivf_nprobes
          • ob_sparse_drop_ratio_search
      • Overview of error messages
      • 0001 ~ 3999
      • 4000 ~ 4499
      • 4500 ~ 4999
      • 5000 ~ 5999
      • 6000 ~ 6999
      • 7000 ~ 7999
      • 8000 ~ 8999
      • 9000 ~ 9499
      • 9500 ~ 9999
      • 10000 ~ 12000
      • 22998, 30926, 38104, 38105
    • LogService reference
      • LogService commands
        • Overview of LS-CTRL
        • LS-CTRL commands
          • bootstrap
          • show az
          • show ln
          • show meta
          • show ap
          • show parameter
          • show v-table
          • add ln
          • delete ln
          • set param
          • check
          • upgrade
          • fetch
          • migrate replica
          • rotate-ak
          • param-version-status
        • Overview of Log Service parameters
          • min_oblogservice_version
          • node_permanent_offline_time_sec
          • stream_replica_task_history_retention_sec
          • object_store_url
          • log_local_target_retention_sec
          • retained_remote_log_blocks
          • log_local_disk_utilization_threshold
          • load_balance_policy
          • rebalance_interval_sec
          • metric_sample_save_interval_sec
          • max_utilization_threshold
          • min_utilization_threshold
          • rebuild_log_lag_threshold
        • Server parameters
          • region
          • az
          • io_worker_count
          • http_port
          • status_thread_pool_size
          • enable_heap_profile
          • log_level
          • max_syslog_file_size
          • disk_max_iops
          • disk_max_bandwidth
          • upload_block_concurrency
          • log_cache_memory_percentage
          • log_cache_evict_scan_budget
          • log_cache_enable_write
          • log_cache_enable_read
          • log_cache_metrics_dump_interval_sec
          • ln_id
          • local_storage_dir
      • LogService views
        • Overview of LogService views
        • List of LogService views
        • Virtual views
          • node_load
          • az_load
          • stream_replica_io
          • t_stream_upload_mapping
          • t_resource_event
    • OBKV
      • OBKV overview
      • OBKV architecture
      • OBKV-Table
        • OBKV-Table overview
          • Core features of OBKV-Table
          • OBKV-Table deployment overview
        • Quick start with simple key-value storage (Java)
        • Use the OBKV-Table client
          • Java development guide for OBKV-Table
          • Prepare for development with OBKV-Table
          • Connect to a cluster by using the OBKV-Table Java client
          • OBKV-Table examples
            • Write data to OBKV-Table
            • Query data in OBKV-Table
            • Update data in OBKV-Table
            • Delete data from OBKV-Table
          • Set parameters for the OBKV-Table Java client
        • OBKV-Table management
          • OBKV-Table management overview
          • High availability of OBKV-Table
          • Security permissions of OBKV-Table
          • OBKV-Table monitoring metrics
        • OBKV-Table reference
          • Data model of OBKV-Table
          • OBKV-Table operations
          • Data types supported by OBKV-Table
          • Full-text indexes in OBKV-Table
          • Scope of use and examples of global indexes in OBKV-Table
          • Delete expired data from OBKV-Table
          • Group commit in OBKV-Table
          • Weak-consistency reads and near reads in OBKV-Table
          • OBKV-Table related views
        • OBKV-Table FAQ
      • OBKV-HBase
        • Overview of OBKV-HBase
        • Core features of OBKV-HBase
        • OBKV-HBase deployment
        • OBKV-HBase development
          • Overview of OBKV-HBase application development
          • Connect to a cluster by using the OBKV-HBase Java client
          • Migrate HBase business code to OBKV-HBase
          • Data operation examples
        • OBKV-HBase migration guide
        • OBKV-HBase management
          • Overview of OBKV-HBase management
          • High availability of OBKV-HBase
          • Security and permissions in OBKV-HBase
          • OBKV-HBase monitoring metrics
        • Query optimization in OBKV-HBase
        • Performance testing of OBKV-HBase
        • OBKV-HBase reference
          • OBKV-HBase data model
          • HBase-compatible interfaces
          • HBase-compatible filters
          • Automatic partition splitting in OBKV-HBase
          • Delete expired data in OBKV-HBase
          • OBKV-HBase weak-consistency reads and near reads
          • OBKV-HBase views
        • OBKV-HBase integrations
          • Flink integration
            • Synchronize data to OBKV-HBase by using the Flink connector
            • Access OBKV-HBase by using native Flink
          • Access OBKV-HBase by using Hive
          • Access OBKV-HBase by using Spark
          • Top general purpose tool
          • tenant dump info
          • trace log
        • Operating system parameter tuning
          • CPU-related parameters
          • Node routing parameters
        • Monitor and diagnose cluster performance
        • Monitor OBProxy performance
          • Overview of WR
        • Diagnostic practice: Use TRACE_ID to diagnose materialized view refresh performance issues
          • Introduction to ASH
          • Generate an ASH report
          • Analyze an ASH report
          • ASH best practices
          • Execution plan operators
            • JOIN
            • WINDOW FUNCTION
            • SUBPLAN FILTER
            • DISTINCT
            • SEQUENCE
            • MATERIAL
            • SORT
            • LIMIT
            • FOR UPDATE
            • SUBPLAN SCAN
            • UNION
            • INTERSECT
            • EXCEPT/MINUS
            • EXCHANGE
            • GI
          • Distributed plan generation
          • Distributed execution plan scheduling
          • Distributed execution plan management
          • Execution of parallel queries
          • Parallel DDL
        • Parallel execution plans
          • Set concurrent execution
            • Set the degree of parallelism for parallel execution
          • Diagnose parallel execution issues
          • Tips for parallel execution tuning
          • Quick start of parallel execution
          • Overview of SQL tuning
          • Basic SQL tuning process
              • Analyze wait events in queries by using SQL Audit
              • Overview of statistics collection methods
              • Introduction to histograms
              • Collect statistics manually
              • Dynamic sampling by the optimizer
              • Overview of statistics management
              • Manage statistics collection strategies (Prefs)
            • Partitioned table statistics collection and update strategy
            • Comprehensive example
            • Rule-based query rewriting
            • Cost-based query rewriting
            • Optimizer hint
            • Execution plan management
        • Related terms
        • FAQ on SQL tuning
      • Database connection and routing overview
      • OceanBase Database Proxy (ODP)
        • ODP management overview
          • Manage parameters of an OBProxy cluster
          • Manage OceanBase AI Database clusters connected to OBProxy
          • Monitor the performance of an OBProxy cluster
          • Start OBProxy
          • Refresh OBProxy configuration
          • Stop OBProxy
          • Restart OBProxy
          • Upgrade OBProxy
        • OBProxy parameters
        • Query the statistics of a session
          • Read/write splitting
      • OceanBase Call Interface (OBCI)
      • OceanBase Migration Assessment (OMA)
      • OceanBase Migration Service (OMS)
      • OceanBase Cloud Platform (OCP)
      • OceanBase Developer Center (ODC)
      • OceanBase Admin Toolkit (OAT)
        • obloader/obdumper
          • Overview of obcdc
            • Sample configuration file
            • Common obcdc parameters
          • Throttling
          • obcdc supports incremental direct load
          • obcdc supports synchronizing from a standby database
          • Data dictionary support in obcdc
    • OceanBase AI Database plugins
      • Overview of OceanBase AI Database plugins
      • Tokenizer plugin
      • MySQL external table plugin
    • Version number guidelines
    • OceanBase AI Database V4.6.3
    • OceanBase AI Database V4.6.2
  2. OceanBase AI Database
  3. V4.6.3
Last Updated:2026-11-16 14:00:06
Overview
Privilege requirements
Attributes
Configuration example
Overview
connection_control_max_connection_delay specifies the maximum duration for which a login attempt will be locked after exceeding the threshold number of failed login attempts.
  • Query parameters
    Both the sys tenant and all user tenants can query this parameter using the SHOW PARAMETERS statement or the GV$OB_PARAMETERS view.
    This parameter can be modified by both the sys tenant and user tenants.
Attributes
Parameter type Int
Default Value 2147483647, in milliseconds
Value range [1000,2147483647]
Modifiable Yes, you can use theALTER SYSTEM SETStatement modification.
Whether to restart the OBServer node for the change to take effect No, the setting takes effect immediately.
After the number of failed login attempts exceeds the threshold, the maximum duration for locking an account after failed login attempts is 2,147,483,647 milliseconds.
obclient> ALTER SYSTEM SET connection_control_max_connection_delay = 2147483647;
connection_control_failed_connections_threshold
Overview
Attributes
