V3.4.0Enterprise Edition
  • What's New
    • What's New
    • What is ODC?
    • Benefits
    • Install ODC
    • Create a private connection
    • Tips on the SQL Console
    • Create a connection
    • Debug a stored procedure
  • User Guide (Web ODC)
    • Log on to ODC
    • ODC homepage
    • Connect to a database
      • Manage private connections
    • Public resource management
      • Resource permissions
        • Manage public connections
        • Manage resource groups
      • Task process management
      • Manage operation records
      • System settings
    • Use the workspace
      • SQL window
      • Anonymous block window
      • Command-line window
      • Stored scripts
      • Snippet
    • Use tools
      • Data export and import
        • Export and import formats
        • Batch export and import
      • Data mocking
      • Database changes
    • View operation records
      • Import tasks
      • Export tasks
      • Data mocking tasks
      • Database change tasks
    • Session management
      • Table objects
        • Table list
        • Manage table attributes
        • Manage table data
      • View objects
      • Function objects
        • Manage functions
      • Stored procedure objects
        • Manage stored procedures
      • Sequence objects
      • Package objects
      • Trigger objects
      • Type objects
        • Create a type
        • Manage types
      • Synonym objects
    • Help center
  • User Guide (Client ODC)
    • Install ODC
    • ODC homepage
      • Establish a connection
      • Manage connections
    • Use the workspace
      • SQL window
      • Stored scripts
      • Snippet
    • Use tools
      • Data mocking
      • Asynchronous execution
      • Import tasks
      • Export tasks
      • Database Change
      • Table objects
        • Table list
        • Manage table data
      • View objects
      • Function objects
        • Manage functions
      • Sequence objects
      • Package objects
      • Trigger objects
      • Type objects
        • Create a type
        • Manage types
      • Synonym objects
    • Help center
    • Deploy a single ODC node
      • Load and run an ODC image
      • Deploy SSL certificate
      • Deploy the NGINX proxy
      • Configure certificate trust
    • Deployment verification
  • Upgrade Guide
    • Preparations before upgrade
    • Upgrade single-node ODC
      • Upgrade process
    • Upgrade high-availability
      • Upgrade process
      • Upgrade NGINX image
    • Upgrade verification
  2. OceanBase Developer Center
  3. V3.4.0
System settings
Last Updated:2026-09-04 08:15:22
The administrator can configure global settings on the System Settings page. Other users can configure the same features on the Personal Settings page. The personal settings have a higher priority than the system settings configured by the administrator.
Log on to ODC as the administrator, and go to the Public Resource Console page. In the left-side navigation pane, click the System Settings to display the System Settings page on the right.
Image 874
In the upper-right corner of the page, click Edit to edit the settings. The following table shows settings that you can configure.
Field
Session Mode for SQL Window Set the session mode of the SQL window.
Delimiter Settings Set the default delimiter for executing PL statements in the SQL window. Five types of delimiters are supported: semi-colons ( ; ), slashes ( / ), double slashes ( // ), dollar signs ( $ ), and double dollar signs ( $$ ).
Transaction Commit Mode in Oracle Mode Set the default transaction commit mode in Oracle mode. Valid values: Manual and Automatic.
Transaction Commit Mode in MySQL Mode Set the default transaction commit mode in MySQL mode. Valid values: Manual and Automatic.
Maximum Number of Rows in Result Set Set the default number of rows returned for an SQL statement executed in the SQL window.
Type of Statements Generated by Dragging and Dropping Object Set the default type of statements generated when you drag and drop table or view objects.
Data desensitization management
Overview
