V3.4.0Enterprise Edition
  • What's New
    • What's New
    • What is ODC?
    • Benefits
    • Install ODC
    • Create a private connection
    • Tips on the SQL Console
    • Create a connection
    • Debug a stored procedure
  • User Guide (Web ODC)
    • Log on to ODC
    • ODC homepage
    • Connect to a database
      • Manage private connections
    • Public resource management
      • Resource permissions
        • Manage public connections
        • Manage resource groups
      • Task process management
      • Manage operation records
      • System settings
    • Use the workspace
      • SQL window
      • Anonymous block window
      • Command-line window
      • Stored scripts
      • Snippet
    • Use tools
      • Data export and import
        • Export and import formats
        • Batch export and import
      • Data mocking
      • Database changes
    • View operation records
      • Import tasks
      • Export tasks
      • Data mocking tasks
      • Database change tasks
    • Session management
      • Table objects
        • Table list
        • Manage table attributes
        • Manage table data
      • View objects
      • Function objects
        • Manage functions
      • Stored procedure objects
        • Manage stored procedures
      • Sequence objects
      • Package objects
      • Trigger objects
      • Type objects
        • Create a type
        • Manage types
      • Synonym objects
    • Help center
  • User Guide (Client ODC)
    • Install ODC
    • ODC homepage
      • Establish a connection
      • Manage connections
    • Use the workspace
      • SQL window
      • Stored scripts
      • Snippet
    • Use tools
      • Data mocking
      • Asynchronous execution
      • Import tasks
      • Export tasks
      • Database Change
      • Table objects
        • Table list
        • Manage table data
      • View objects
      • Function objects
        • Manage functions
      • Sequence objects
      • Package objects
      • Trigger objects
      • Type objects
        • Create a type
        • Manage types
      • Synonym objects
    • Help center
    • Deploy a single ODC node
      • Load and run an ODC image
      • Deploy SSL certificate
      • Deploy the NGINX proxy
      • Configure certificate trust
    • Deployment verification
  • Upgrade Guide
    • Preparations before upgrade
    • Upgrade single-node ODC
      • Upgrade process
    • Upgrade high-availability
      • Upgrade process
      • Upgrade NGINX image
    • Upgrade verification
  2. OceanBase Developer Center
  3. V3.4.0
Last Updated:2026-09-04 08:15:22
Load the image
Run the image
When you upgrade OceanBase Developer Center (ODC) deployed in single-node mode, you need to obtain and run the ODC image again after you update the MetaDB and stop the ODC container of the earlier version.
Load the image
To obtain the ODC image on the host, select the required image from the following list and click Download .
  • Image for X86: Download
  • Image for ARM: Download
After you obtain the image, run the following command in the command-line tool to load it:
gunzip -c obodc-{$version}.tar.gz  docker load
Run the image
Execute the following sample statement in the command-line tool to run the image:
#!/usr/bin/env bash
docker run --volume   /var/log/odc:/opt/odc/log \
-d -i --net host --cpu-period 100000 --cpu-quota 400000 --memory 8G --name "obodc" \
-e "DATABASE_HOST=100.00.00.00" \
-e "DATABASE_PORT=60805" \
-e "DATABASE_USERNAME=db_user@tenant_name#cluster_name" \
-e "DATABASE_PASSWORD=******" \
-e "DATABASE_NAME=odc_metadb" \
-e "ODC_PROFILE_MODE=alipay" \
reg.docker.alibaba-inc.com/oceanbase/odc-server:{image_tag}
You can run the docker images command to view the {image_tag} parameter on the host after you load the image. The following table describes other parameters used in the preceding sample statement.
Parameter
--volume Maps the /var/log/odc directory of the host to the /opt/odc/log directory in the ODC container. If the /var/log/odc directory does not exist on the host, run the mkdir -p /var/log/odc command to create one.
--net The network configuration of the Docker container. If you set this parameter to host, the host network is directly used. You can also use the --publish (-p) parameter to configure port mapping. However, the Docker container may fail to start in some circumstances due to incorrect DNS resolution in the Docker container. In this case, run the --net host command to start the Docker container.
--cpu-period --cpu-quota * The ---cpu-period parameter specifies the interval at which the CPU cores of the Docker container are reallocated. Unit: microseconds. * The ---cpu-quota parameter specifies the maximum time for running the current Docker container in this interval. Unit: microseconds. You can use these two parameters in combination to specify the number of CPU cores that the Docker container uses. The value is calculated by dividing cpu-quota by cpu-period. In the preceding sample statement, the values of cpu-quota and cpu-period are respectively 400000 and 100000, indicating that the Docker container can use at most four CPU cores.
--memory The maximum memory size for the Docker container.
--name The name of the container.
DATABASE_HOST The IP address of the MetaDB.
DATABASE_PORT The port number of the MetaDB.
DATABASE_USERNAME The username of the MetaDB. In OceanBase Database, the username is given in the db_user@tenant_name#cluster_name format.
DATABASE_PASSWORD The password for connecting to the database.
DATABASE_NAME The name of the MetaDB.
ODC_PROFILE_MODE The mode. Default value: alipay.
In addition to the preceding parameters, you can also use the following parameters when running the image.
Parameter
ODC_LOG_DIR The log directory. Default value: /opt/odc/log.
OBCLIENT_WORK_DIR The working directory of OBClient. Default value: /opt/odc/data.
ODC_JAR_FILE The directory of JAR files. Default value: /opt/odc/lib/odc-web-starter-*.jar.
ODC_WORK_DIR The working directory of ODC. Default value: /opt/odc/script.
ODC_JVM_HEAP_OPTIONS The JVM stack memory. The default maximum value of the parameter -Xmx is 60% of available physical memory size. ODC checks whether the available memory in the current environment reaches 2048 MB before it starts a script. Assume that this parameter is set to 60%, the available memory must be at least 3.4 GB to start the script. If the available memory of the host or Docker container is less than 3.4 GB, you can skip memory check by setting the ODC_JVM_HEAP_OPTIONS parameter. For example, you can set it to "-Xmx2048m -Xms2048m".
ODC_JVM_GC_OPTIONS The garbage collection (GC) strategy for JVM. Default value: -XX:+UseG1GC -XX:+PrintAdaptiveSizePolicy -XX:+PrintGCDetails -XX:+PrintGCTimeStamps -XX:+PrintGCDateStamps -Xloggc:/opt/odc/log/gc.log -XX:+UseGCLogFileRotation -XX:GCLogFileSize=50M -XX:NumberOfGCLogFiles=5.
ODC_JVM_OOM_OPTIONS The OutOfMemory strategy for JVM. Default value: -XX:+ExitOnOutOfMemoryError.
ODC_JVM_EXTRA_OPTIONS Other JVM parameters. By default, no parameter is specified.
ODC_SERVER_PORT The HTTP listening port for ODC-Server. Default value: 8989.
ODC_HOST The IP address of ODC, which can be used as the destination IP address for remote procedure calls in high-availability deployment scenarios.
ODC_RPC_PORT The port number of ODC, which can be used as the destination port number for remote procedure calls in high-availability deployment scenarios.
This parameter is independent of the ODC_SERVER_PORT parameter. It is required only for initiating remote procedure calls.
ODC_APP_EXTRA_ARGS Other App parameters need to be specified.
For example, --server.servlet.session.timeout=10m, indicating that the Session period is 10 minutes. The default value is empty.
ODC_SERVER_RPC_PORT The internal RPC listening port for ODC-Server. Default value: 8990.
Stop ODC of the earlier version
Upgrade process
Load the image
Run the image
