SQL - V4.4.2
  • What's New
    • Feature differences between the Enterprise Edition and Community Edition
      • Overview of Compatibility with Oracle
    • Learn OceanBase SQL
      • Before you begin
      • Basic SQL operations (MySQL-compatible mode)
      • Basic SQL operations (Oracle-compatible mode)
    • Build a sample application (MySQL-compatible mode)
      • Build a Python application
      • Build a Java application
      • Build a C application
      • Build a Go application
    • Build a sample application (Oracle-compatible mode)
      • Scalable OLTP
        • Experience the hot row update capability of OceanBase Database
      • Try out operational OLAP
    • Develop applications (MySQL-compatible mode)
          • Connection pool configuration
          • JDBC
          • Spring JDBC
          • Connector/J
          • TestContainers
          • MySQL-connector-python
          • SQLAlchemy
          • Django
          • peewee
          • MySQL Connector/C
        • PHP
          • EXT
          • MySQLi
          • PDO
        • Rust
          • Connect to OceanBase Database by using Rust
          • Connect to OceanBase Database by using SeaORM
        • Ruby
          • ActiveRecord
          • mysql2
          • Sequel
        • Create an external table
          • Lock query results with SELECT FOR UPDATE
          • Use regular expressions in queries
        • Transaction management overview
          • Error code introduction
    • Develop applications (Oracle-compatible mode)
        • Overview of connection methods
        • Connect to OceanBase Database using DBeaver (Oracle-compatible mode)
        • Connect to OceanBase Database by using Navicat (Oracle-compatible mode)
          • Database Connection Pool Configuration
          • Python Driver Oracle Mode
        • Pagination
        • Configure servers
          • OCP deployment instructions
          • Initialize OBServer nodes by using oatcli
      • Deploy the Java SDK environment for OceanBase Database
      • Deployment overview of OceanBase Database Community Edition
        • Hardware and software requirements
        • Deploy OceanBase Database in a container environment
      • Deploy OceanBase Desktop
    • Clean up an OceanBase cluster
    • Recommended configurations
  • Upgrade
      • Upgrade overview
      • Check upgrade results
    • Data migration Overview
      • Use OMS to migrate data from a MySQL database to a MySQL-compatible tenant of OceanBase Database
      • DTS
      • Huawei Cloud CDM
      • Huawei DRS
      • Use OMS to migrate data from a MySQL-compatible tenant of OceanBase Database to a MySQL database
      • Use OMS to migrate incremental data from an Oracle-compatible tenant of OceanBase Database to a MySQL database
      • Use OMS to migrate data from an Oracle database to a MySQL-compatible tenant of OceanBase Database
      • Use OMS to migrate data from an Oracle database to an Oracle-compatible tenant of OceanBase Database
      • Use OMS to migrate data from an Oracle-compatible tenant of OceanBase Database to an Oracle database
      • Use OMS to migrate data from a DB2 LUW database to a MySQL-compatible tenant of OceanBase Database
      • Use OMS to migrate data from a DB2 LUW database to an Oracle-compatible tenant of OceanBase Database
      • Use OMS to migrate data from a MySQL-compatible tenant of OceanBase Database to a DB2 LUW database
      • Use OMS to migrate data from an Oracle-compatible tenant of OceanBase Database to a DB2 LUW database
      • Use OMS to migrate data from a TiDB database to a MySQL-compatible tenant of OceanBase Database
      • Use OMS to migrate data from a PostgreSQL database to a MySQL-compatible tenant of OceanBase Database
      • Use OMS to create an active-active disaster recovery project for OceanBase Database tenants of the same type
      • Use obloader & obdumper to migrate data between MySQL-compatible tenants in OceanBase Database
      • Use obloader & obdumper to migrate data from a MySQL-compatible tenant to an Oracle-compatible tenant in OceanBase Database
      • Use obloader & obdumper to migrate data between Oracle-compatible tenants in OceanBase Database
      • Use obloader & obdumper to migrate data from an Oracle-compatible tenant to a MySQL-compatible tenant in OceanBase Database
      • Export data using the OUTFILE statement
    • Overview of direct load
      • Cluster introduction
        • Reset cluster parameters
          • Overview of resource isolation
          • Manage resource isolation (Oracle-compatible mode)
            • Configure cgroups
          • Manage resource isolation (MySQL-compatible mode)
            • Configure cgroups
            • Update resource management plan directive
          • Example configuration for resource isolation of background tasks
          • Introduction to scaling in and out
          • Resource planning for tenant scale-in and scale-out
          • Tenant pre-scaling
          • Adjust the unit number for tenant scaling in and out
          • Example of smooth scaling in and out
          • View resource pools
          • Query resource specifications (unit configs)
          • Modify resource specification (unit config)
          • Delete resource specification (unit config)
        • Manage services
          • Create a service
          • Query the service status
          • Start a service
          • Stop a service
    • Manage log streams
      • Create a log stream
      • Modify a log stream
      • Replica introduction
        • Locality overview
          • Add replicas
          • Reduce replicas
          • Change the replica type
          • Adjust replica distribution
          • Migrate replicas
          • Cancel a replica task
      • Overview of data load balancing
      • Transfer partitions
      • Cancel a "Transfer Partition" task
      • Cancel a load balancing job
      • Pause and resume a load balancing job
      • Table group weight management
        • Aggregation of user tables in a database
        • Set table group weights
        • Clear table group weights
        • Application scenarios of table group weight balancing
      • Partition weight management
        • Set partition weights
        • Clear partition weights
      • Partition balancing
        • Configure a scheduled partition balancing task
        • Manually trigger partition balancing
        • View the configuration of the scheduled partition balancing task
        • View the trigger history of the scheduled partition balancing task
        • View the partition balancing tasks in the background
        • View the history of partition balancing tasks in the background
      • Isolating GTS for high availability: a practical example
        • Proxy layer high availability
        • Physical standby database overview
          • Preparations before creating standby tenants
          • Log transmission service overview
            • Set a log restore source
            • Configure standby database delay
        • Protection mode
          • Protection mode overview
          • Protection mode and protection level
          • Set the strongly synchronized downstream
          • Set the protection mode
          • Primary/standby switchover and protection modes
        • Delete a primary or standby tenant
        • Delayed standby application cases
        • Arbitration service overview
        • Query log stream upgrade and downgrade information
        • Recycle bin overview
      • Overview of security and privileges
        • MySQL-compatible mode
          • Login failure processing
          • Dual password management
        • Oracle-compatible mode
          • Password rollover
        • Access control overview
          • Overview of users and privileges
            • Privilege types in MySQL-compatible mode
            • Role management
              • Grant privileges to a role
            • Privilege types in Oracle-compatible mode
              • Role management overview
            • Use a proxy user
      • Data encryption
        • Data encryption overview
        • Data transfer encryption
          • Data transmission encryption overview
        • Tenant master key management
          • Overview of tenant master keys
          • Generate a tenant master key (MySQL-compatible mode)
          • Generate a tenant master key (Oracle-compatible mode)
        • Transparent data encryption
          • Database transparent encryption overview
          • Transparent data encryption (MySQL-compatible mode)
            • Enable TDE for new tables
            • Enable transparent data encryption for an existing table
          • Transparent data encryption (Oracle-compatible mode)
        • Column encryption
          • Overview of column encryption
          • Column encryption (MySQL-compatible mode)
            • Create a column encryption rule
            • Column encryption privilege management
          • Column encryption (Oracle-compatible mode)
          • Frequently asked questions about column encryption
        • Security audit overview
          • Enable security auditing
          • Set auditing rules
          • View auditing records
          • Disable security auditing
          • Appendix: Complete SQL types supported by general_sql_command
          • Set and view auditing rules
          • Audit user logins
      • Physical backup and restore
        • Overview of log archiving
        • Change the archive destination
        • Clear the archive path configuration
        • Prepare for backup
        • Back up to a specified directory
        • Back up parameters
        • View parameters related to data backup
        • Modify the source-side backup path configuration
      • Update `access_id` and `access_key` information for the backup or archive path
        • Automatically clear backup data
          • Automatically clean up expired backups
          • Delete a cleanup policy
        • Manually clear backup data
          • Manually trigger the cleanup of expired backups
          • Manually clean up specified backup or archive data
          • Manually clear the backup path or archive path
        • Cancel a cleanup task
        • View the results of backup cleanup
      • Backup validation
        • Backup validation overview
        • Validate the entire backup and archive path
        • Validate a specified backup set or log archive piece
        • Validate backup sets or log archive pieces in a specified path
        • Cancel backup validation
        • View backup validation progress
        • View backup validation results
        • Prepare before restore
        • Perform physical restore
        • Restore from a specified path
        • Overview of table-level restore
        • Preparations before table-level restore
        • Perform table-level restore
        • Schema restore after table-level restore
        • Cancel table-level restore
        • Check the progress of table-level restore
        • Check the results of table-level restore
        • Parameters related to table-level restore
        • Views related to table-level restore
      • Backup and restore performance tuning
      • Example of configuring the source backup and archive paths
      • Appendix: S3 path format
      • Monitoring overview
          • System monitoring metrics overview
          • SYSSTAT metrics
          • SQL monitoring overview
      • Arbitration Service Monitoring
      • Log overview
      • Log interpretation
      • Alert logs
    • Routine inspection
      • Routine inspection overview
      • Check host information
      • Check tenant resource usage
      • Check OBServer status
      • Check the log synchronization and replay status of primary and standby tenants
        • End-to-end tracing overview
        • End-to-end tracing process
        • End-to-end tracing methods
      • Performance tuning overview
          • OBServer performance issues overview
            • Plan optimality for account size skew
          • Hard parsing issues
            • Overview of statistics and row estimation mechanism
              • Row estimation based on selectivity
            • Plan cache overview
            • Drawbacks of plan caching and solutions
            • Index selection overview
          • Join
              • Hash Join
              • Merge join
            • Overview of order by and limit optimization
          • Schema specifications
        • Typical SQL tuning scenarios and cases
      • Error handling fundamentals
      • Bootstrap
        • Dump and major compaction
        • Memory-related issues
        • Migration, replication, and rebuild
        • No leader
        • Transaction issues
        • Long transaction
        • Hung transaction
        • Idle transaction
        • Diagnose physical standby database log synchronization and replay exceptions
        • Other issues
      • FAQ about manual operations on log streams
      • Materialized view exception diagnosis
      • Application exceptions -- error messages without OceanBase error codes
      • Application exceptions -- error messages with OceanBase error codes
      • Troubleshoot application disconnection issues
      • External table common issue troubleshooting guide
      • Troubleshooting with ASH
        • General approach to troubleshooting using ASH
        • Troubleshoot CPU resource imbalance
        • Troubleshoot I/O bottlenecks
      • Frequently used SQL for troubleshooting
        • Query tenant_id and table_id
        • Information about the table
        • Query the primary table of an index
        • Query table fragmentation
        • View indexes with abnormal status
        • Query deadlocks
        • Query the partition name
        • Query the number of temporary tables
        • Query row locks
          • Network jitter
          • SQL query exceptions
  • OceanBase AP
    • AP Version Update History
    • Overview of OceanBase AP
    • Core features of OceanBase AP
    • Quick start with OceanBase Database AP
      • Overview of OceanBase AP Deployment
      • Parameter configuration recommendations for AP scenarios
      • Deploy and use columnstore replicas
    • Data table design
      • Overview of tables
      • Use columnstore and hybrid rowstore-columnstore formats
        • Dynamic partitioning
      • Data design best practices
        • Primary key design practices in AP scenarios
        • Practices for JSON multi-valued indexes and full-text indexes
        • Table partition design practices in AP scenarios
        • Best practices for columnstore tables and indexes
    • 250.data-migration
      • Migrate data from a heterogeneous data source to OceanBase Database
      • Homogeneous data migration
      • Migrate data from the big data ecosystem
    • 300.obap-data-collection
      • Data subscription
      • 300.obap-import-data
        • 20.bypass-import
          • Full direct load
          • Incremental direct load
          • Import data in direct load mode by using obloader
          • Efficient data loading with full direct load and partition exchange
        • Import data to an external table
        • Data import strategies and best practices
    • Data transfer
      • Data transfer overview
      • Data migration
        • Data migration overview
        • Migrate data by using tools
        • Best practices for migrating data from mainstream AP databases to OceanBase
        • data-import
        • INSERT INTO SELECT
          • INSERT INTO SELECT FROM FILES
          • Import data by using the INSERT INTO SELECT statement on external tables
        • CREATE TABLE AS SELECT
        • Import data by using obloader
      • Data subscription and synchronization
        • Data synchronization
        • Data subscription
      • Data processing in OceanBase
      • Data processing tools
      • Materialized view query acceleration
        • Accelerate queries with materialized views
        • Practice scenarios of materialized views
    • Data lake
      • Data lake overview
      • Data lake integration
        • Hive
          • Load a Hive table through a catalog
          • Hive tables (HMS)
        • Catalog and external tables
        • Load an Iceberg table through a catalog
        • ODPS
          • ODPS Catalog
          • ODPS external table
        • File external tables
      • URL external tables
    • Query acceleration
      • Overview of query acceleration
      • Statistics
    • Data visualization
    • Ecosystem integration
      • AP tutorial
      • Accelerate offline queries in OceanBase by using the HMS catalog
      • Query and read/write MaxCompute (ODPS) data in OceanBase Database
    • AP FAQ
  • OceanBase AI
      • Overview of vector search
      • Core features of vector search
      • AI application workflow using OceanBase vector search
      • Quick start: vector search with SQL
      • Quick start: vector search with Python
    • Vector embedding technology
    • Store vector data
    • Vector index
      • Vector index memory management
      • Dense vector index
        • Index type selection
        • HNSW index
        • IVF index series
      • Monitor and maintain indexes
      • Optimize the performance of vector search
    • SQL functions
    • Vector similarity search
    • Hybrid search
      • Full-text and vector hybrid search
    • AI function service
      • AI function service quick start
      • AI function service permissions
      • AI model registration
      • AI function syntax and examples
    • Migrate to OceanBase Database from a vector database
      • Vector search tutorial overview
      • Build an intelligent Q&A chatbot with OceanBase
      • Build a cultural tourism assistant with OceanBase multi-model integration
    • AI integrations
      • Overview of AI integration
      • OpenAI
      • Qwen
      • LangChain
      • LlamaIndex
      • Dify
      • n8n
      • Spring AI
      • Cline
      • Cursor
      • Continue
    • VectorDBBench benchmark testing
    • References
      • Overview of vector data types
      • Compatibility
      • Supported clients and languages
        • Supported clients and languages for vector search
        • pyobvector Python SDK interface
        • Java SDK interface
    • Vector search FAQ
  • Integrations
    • Integration overview
    • ORM frameworks
        • SpringBatch
        • SpringDataJPA
        • SQLAlchemy
        • peewee
        • Tortoise ORM
        • beego ORM
      • Rust
        • SeaORM
        • Diesel
      • Ruby
        • Active Record
        • Sequel
        • Ruby on Rails
      • Node.js
        • Sequelize
        • TypeORM
        • Prisma
        • Drizzle
      • C#
        • Dapper
        • FreeSQL
      • PHP
        • Yii 2.0 ORM
        • Laravel Eloquent ORM
    • Database version management
      • Liquibase
      • Flyway
      • Apache Flink
        • Apache Flink
        • Flink DirectLoad
        • Flink Connector OceanBase
      • dbt
      • SeaTunnel
      • Dataphin
      • Maxwell
      • Debezium
      • Spark Catalog
      • NiFi
      • Qlik Replicate
      • RisingWave MySQL-CDC
    • SQL development
      • WebLogic
      • DBeaver
      • Navicat
      • DataGrip
      • TablePlus
      • DMS
      • Trino
    • Orchestration and scheduling
      • DolphinScheduler
      • Linkis
    • Visualization tools
      • Superset
      • Power BI
      • Quick BI
      • Tableau
      • GuanData
      • vividime
      • Excel
      • NineData
      • Bytebase
      • DataHub
      • Zabbix
    • AI
      • OpenAI
      • Qwen
      • LangChain
      • LlamaIndex
      • Dify
      • n8n
      • Trae
      • SpringAI
      • Cline
      • Cursor
      • Continue
      • MCP Toolbox
      • CamelAI
      • Firecrawl
      • Hugging Face
      • Ollama
      • Google Gemini
      • Cloudflare Workers AI
      • Jina AI
      • Augment Code
      • Claude Code
      • Kiro
    • Build an intelligent Q&A assistant with OceanBase Database
    • Build an offline data warehouse and visual dashboard with OceanBase
    • Analyze data in OceanBase Database using Superset
    • Build a WordPress website with OceanBase Database
    • Efficiently retrieve large volumes of news data using full-text indexing
    • Use Spark to process and analyze large volumes of data in OceanBase Database quickly
    • Use direct load to accelerate the import of massive data
    • OceanBase MCP Server
    • OceanBase concepts
      • OceanBase Database architecture
        • Multi-tenant architecture overview
            • Database objects overview
            • Table overview
              • Data type overview
                • Format model overview
            • Replicated table
            • Temporary table
            • Table group overview
            • Overview of indexes
            • Full-text index
            • Partition overview
            • External table partitions
            • Views in a database
            • Standard views
              • Standard views
              • View overview
            • Materialized views
            • Data integrity overview
              • Integrity constraint types overview
            • Table overview
            • Replicated table
            • Table groups
            • Full-text index
            • Standard views
              • Oracle-compatible views in MySQL-compatible tenants
              • Foreign key constraints
        • Distributed database objects overview
          • Log stream and replica overview
            • Log stream replica overview
            • Read-only replicas
            • Columnstore replica
          • Data balancing
            • Intra-tenant balancing
          • Cluster-level scaling
          • Tenant-level scaling
        • Data link overview
          • Proxy overview
          • Database driver overview
        • Cross-data source access through DBLink
          • DBLink in MySQL-compatible mode
          • DBLink in Oracle-compatible mode
            • SQL overview
            • SQL statement overview
            • Monitor DDL execution progress
          • SQL execution plan
            • Generate distributed plans
            • Enable and disable parallel query
            • Optimize parameters for parallel query
          • PL execution mechanism
          • Global Timestamp Service (GTS)
            • Transaction control overview
            • Distributed transaction overview
          • Data concurrency and consistency overview
            • Concurrency control overview
            • Lock Wait Mgr
            • Transaction isolation level overview
            • Transaction isolation levels in Oracle-compatible mode
            • Transaction isolation levels in MySQL-compatible mode
          • Weak-consistency read
        • Storage architecture overview
          • Data storage overview
          • MemTable
          • SSTable
          • Columnar storage
          • Overview of dumping and merging
          • Dump (Mini and minor compactions)
          • Merge (Major compaction)
        • Multi-level caching in shared-nothing architecture
          • High availability architecture overview
        • Disaster recovery deployment plan
          • Data protection overview
          • Backup and restore overview
          • Backup directory structure
          • Restore process
        • Security mechanism overview
        • Configuration file
          • Thread introduction
          • Memory management overview
          • Memory-related logs
          • Memory problem diagnosis
        • Plugin mechanism
        • Configuration management introduction
          • Dump management overview
          • Adaptive major compactions
        • Maximum database memory
        • Memory management in a tenant
        • Common memory problems
        • Overview of OceanBase threads
        • Configure dynamic expansion of disk data files
        • View the disk space used by a tenant or table
      • Overview of database object management
          • About tables
          • Column skip index attribute
          • Change a table
          • Change the attribute of a table
            • About external tables and external files
            • Create and query external tables
            • Create external table partitions
            • Data type mapping
          • Partition splitting
            • Partition splitting overview
            • Manual partition splitting
            • Automatic partition splitting
            • Recommended configurations for automatic partitioning
            • Overview of dynamic partitioning
            • Create a dynamically partitioned table
            • Query a dynamic partitioned table
            • Modify a dynamically partitioned table
            • Dynamic partition management tasks
          • Drop a partition
            • Index overview
          • Partition exchange
          • About indexes
          • Manage standard views
          • Manage materialized views
            • Overview of materialized views
            • Materialized view logs
            • Create a materialized view
            • Refresh a materialized view
            • Query materialized views
            • Modify the attributes of a materialized view
            • Drop a materialized view
            • Resource isolation for materialized views
          • Trigger overview
        • Create and manage catalogs
          • Catalog overview
          • Create a catalog
          • View a catalog
          • Drop a catalog
          • About tables
          • Change the replicated table attribute
            • Data type mapping
          • Drop a partition
            • Index overview
          • About indexes
          • List of system functions supported for function-based indexes
            • Create materialized views
            • Materialized view resource isolation
          • Trigger overview
          • Create a DDL trigger
        • Manage directories
        • 1100.manage-catalog-of-oracle-mode
          • Overview of Catalog
          • Create a catalog
          • View Catalogs
          • Drop a catalog
        • Overview of object naming conventions
      • Introduction to SQL
            • ADD REPLICA
            • ADD RESTORE SOURCE
            • BACKUP CLUSTER PARAMETERS
            • BALANCE JOB
            • CANCEL REPLICA TASK
            • CANCEL VALIDATE
            • CLEAR RESTORE SOURCE
            • CREATE LS
            • DELETE BACKUP ALL
            • DELETE BACKUPSET/ARCHIVELOG_PIECE
            • DELETE OBSOLETE BACKUP
            • LOAD MODULE DATA
            • MIGRATE REPLICA
            • MODIFY LS
            • MODIFY PAXOS_REPLICA_NUM
            • MODIFY REPLICA
            • FLUSH SEQUENCE CACHE
            • FLASHBACK STANDBY LOG
            • REMOVE REPLICA
            • RESTORE PREVIEW
            • SERVICE_NAME
            • SET SYNC_STANDBY_DEST
            • SET STANDBY TENANT
            • VALIDATE
          • SHOW RESTORE PREVIEW
        • User tenants (MySQL-compatible mode)
                • Integer data types
                • Fixed-point data types
                • Floating-point data types
                • Bit value data type
                • ON UPDATE CURRENT_TIMESTAMP column attribute
                • BLOB types
                • STRING types
                • LOB types
              • SET type
                • Convert a JSON data type
                • Update partial JSON data
                • Semi-structured encoding
                • SRS
                • Create a spatial column
                • Create a spatial index
              • Roaring bitmap types
                • Create an efficient compressed bitmap column
              • Array data types
                • Create an array column
              • Map data types
                • Overview of the map data type
                • Create map columns
              • Character set
              • Collations
              • Character expression character sets and collations
              • Strings
              • Numbers
              • Datetime values
              • NULLs
            • Overview of operators
            • Assignment operators
            • BINARY operator
                • KEYVALUE
                • MAX_PT
                • MD5_CONCAT_WS
                • SPLIT_PART
                • URL_DECODE
                • URL_ENCODE
                • DECODE_TRACE_ID
              • ARG_MAX
              • ARG_MIN
              • WINDOW_FUNNEL
              • ENHANCED_AES_ENCRYPT
              • ENHANCED_AES_DECRYPT
              • PASSWORD
              • SM3
              • SM4_ENCRYPT
              • SM4_DECRYPT
              • LAST_INSERT_ID Behavior Description
              • OB_TRANSACTION_ID
              • `JSON_TABLE`
            • Table functions
              • Overview of TABLE FUNCTIONS
              • FILES table function
              • Spatial relation functions
              • Geometry property functions
              • _ST_GeoHash
              • RELEASE_ALL_LOCKS
            • Bitmap functions
              • RoaringBitmap constructor
              • Bitmap cardinality functions
            • Array functions
              • Array constructor functions
              • Array judgment functions
              • Array output functions
              • Array operation functions
            • Text processing functions
              • TOKENIZE
            • Auditing functions
              • AUDIT_LOG_FILTER_SET_FILTER
              • AUDIT_LOG_FILTER_SET_USER
              • AUDIT_LOG_ENCRYPTION_PASSWORD_SET
              • AUDIT_LOG_ENCRYPTION_PASSWORD_GET
            • Map functions
              • Overview of map functions
              • Mapping constructor
              • Mapping comparison functions and operators
              • Mapping Operation Functions
              • MATCH AGAINST
            • Full-text search
            • Common table expressions
            • ALTER COMPILE
            • ALTER LOCATION
            • ALTER MATERIALIZED VIEW
            • ALTER MATERIALIZED VIEW LOG
            • ALTER SENSITIVE RULE
            • ALTER SYSTEM FLUSH SEQUENCE CACHE
            • VALIDATE
            • ALTER TABLESPACE
            • ALTER INSTANCE ROTATE INNODB MASTER KEY
            • CACHE INDEX
            • CREATE CONCURRENT_LIMITING_RULE
            • CREATE EXTERNAL CATALOG
            • CREATE LOCATION
            • CREATE MATERIALIZED VIEW
            • CREATE FORMAT OUTLINE
            • CREATE RESTORE POINT
            • CREATE SENSITIVE RULE
            • CHECKSUM TABLE
            • CREATE EVENT
            • DROP CATALOG
            • DROP CONCURRENT_LIMITING_RULE
            • DROP LOCATION
            • DROP MATERIALIZED VIEW
            • DROP MATERIALIZED VIEW LOG
            • DROP SENSITIVE RULE
            • DROP RESTORE POINT
            • FLUSH TABLE
            • LOAD INDEX INTO CACHE
            • REPAIR TABLE
              • WINDOW clause
            • SET CATALOG
            • SUBMIT JOB
            • SHOW JOB STATUS
            • CANCEL JOB
            • UNLOCK TABLES
            • XA transaction
          • Pseudocolumns
            • PARTITIONID pseudo-column
            • Pseudo columns of sequences
        • User tenants (Oracle-compatible mode)
            • Sequence pseudocolumns
            • ORA_ROWSCN pseudocolumn
            • ROWNUM pseudocolumn
            • ROWID pseudocolumn
                • LOB types
              • Rowid data types
                • Conversion of the XMLType data type
              • Data type precedence
                • Date literals
                • Timestamp literals
              • Interval literals
              • RR datetime format element
              • NULLs in SQL functions
              • Remarks about SQL statements
                • Use query block name and QB_NAME hint to control query optimization
                  • Global hints
                    • Optimizer Stats Hint
                    • Transform Hint under the Global Hints category
                    • Other hints in the GLOBAL hint category
                  • Optimized hints
                    • Access path hints
                    • Join order hints in the Optimized Hint category
                    • Join operation hints in the Optimized Hint category
                    • Subquery hints in the Optimized Hint category
                    • Group By Hint in the Optimized Hint category
                    • DISTINCT hint
                    • Set Hint under Optimized Hint
                    • Distributed DML hints in the Optimized Hint category
                  • Transform hints
                    • Stmt Transform Hint
                    • Cost-based transform hints
                    • Heuristics transform hints
                    • Other hints under the TRANSFORM hint type
                  • Outline-related hints
                • Reference a DBLink
              • Refer to partitioned tables and indexes
                • MAX_PT
                • SUBSTRB
                • CONTAINS
                • SCORE
                • INSTRB
                • INSTRC
                • LENGTHB
                • LENGTHC
                • EXTRACT(datetime)
                • ROUND (date)
                • TRUNC (date)
                • RAWTONHEX
                • TO_NCHAR(character)
                • TO_NCHAR(datetime)
                • TO_NCHAR(number)
                • NLS_CHARSET_ID
                • TIMESTAMP_NVL
              • Large object functions
                • EMPTY_BLOB
                • EMPTY_CLOB
                  • XMLCONCAT
                  • XMLFOREST
                  • EXISTSNODE
                • Overview of spatial functions
                • Constructor functions
                • Spatial query functions
                • Format conversion functions
              • REGR_(Linear Regression)
              • WINDOW_FUNNEL
              • GROUP_ID
              • GROUPING_ID
              • ARG_MIN
              • ARG_MAX
              • OB_TRANSACTION_ID
            • Table functions
            • Audit functions
              • Overview of audit functions
            • CURSOR expressions
            • Condition precedence
            • NULL conditions
            • Simple queries
            • Hierarchical queries
            • Composite queries
            • JOIN queries
            • DUAL table query
            • Full-text query
              • ALTER LOCATION
              • ALTER SYSTEM ENABLE/DISABLE RESTRICTED SESSION
              • ALTER SYSTEM FLUSH CACHE
              • ALTER SYSTEM SET PARAMETER
              • VALIDATE
              • ALTER TABLESPACE
              • ALTER VIEW COMPILE
              • CREATE LOCATION
              • DROP LOCATION
              • DROP CATALOG
              • SET CATALOG
                • Set-based SELECT
                • WITH CLAUSE
                • APPLY clause
          • SELECT statements
          • Table scan
          • Cache
          • How to use hints
          • Read with eventual consistency
          • Pagination
      • Reserved keywords (MySQL-compatible mode)
      • Reserved keywords (Oracle-compatible mode)
      • Data type conversion behavior in MySQL-compatible tenants in strict mode
      • PL reference (MySQL-compatible mode)
          • External storage functions
          • EVENT
          • SQL Transpiler
          • PL asynchronous commit optimization
          • Scope of procedures
          • Diagnostic areas
          • DBMS_AI_SERVICE
            • Overview of DBMS_AI_SERVICE
            • CREATE_AI_MODEL
            • DROP_AI_MODEL
            • CREATE_AI_MODEL_ENDPOINT
            • ALTER_AI_MODEL_ENDPOINT
            • DROP_AI_MODEL_ENDPOINT
          • DBMS_HYBRID_SEARCH
            • Overview of DBMS_HYBRID_SEARCH
            • SEARCH
            • GET_SQL
          • DBMS_MVIEW
            • PURGE_LOG
            • KILL_REFRESH
            • REFRESH_REPORT
          • DBMS_MVIEW_STATS
            • PURGE_REFRESH_STATS
            • SET_MVREF_STATS_PARAMS
            • SET_SYSTEM_DEFAULT
          • DBMS_PARTITION
            • DBMS_PARTITION overview
            • MANAGE_DYNAMIC_PARTITION
            • System Packages
            • CANCEL_GATHER_STATS
            • ADD_TRUSTED_CERTIFICATE
            • DELETE_TRUSTED_CERTIFICATE
            • UPDATE_TRUSTED_CERTIFICATE
          • DBMS_VECTOR
            • Overview of DBMS_VECTOR
            • REFRESH_INDEX
            • REBUILD_INDEX
            • INDEX_VECTOR_MEMORY_ESTIMATE
            • INDEX_VECTOR_MEMORY_ADVISOR
          • DBMS_XPROFILE
            • Overview of DBMS_XPROFILE
            • DISPLAY_PROFILE
          • DBMS_BALANCE
            • SET_BALANCE_WEIGHT
            • CLEAR_BALANCE_WEIGHT
            • TRIGGER_PARTITION_BALANCE
            • SET_TABLEGROUP_BALANCE_WEIGHT
            • CLEAR_TABLEGROUP_BALANCE_WEIGHT
          • DBMS_LIMIT_CALCULATOR
          • DBMS_EXTERNAL_TABLE
            • AUTO_REFRESH_EXTERNAL_TABLE
          • DBMS_JAVA
            • Overview of DBMS_JAVA
            • LOADJAVA
            • DROPJAVA
          • DBMS_PYTHON
            • Overview of DBMS_PYTHON
            • DROPPYTHON
            • LOADPYTHON
          • DBMS_DATA_DICT
            • DBMS_DATA_DICT
          • DBMS_SCHEMA
            • Overview of DBMS_SCHEMA
            • RECYCLE_SCHEMA_HISTORY
            • RUN_INSPECTION
      • PL reference (Oracle-compatible mode)
          • Lexical elements
          • Declaration
          • Assignment
          • Error reporting functions
          • BOOLEAN type
          • Sequential control
          • Collection constructors
          • RECORD
            • Explicit cursor
            • Use the FOR loop to traverse a cursor
            • Modify and drop a cursor
            • Overview of autonomous transactions
          • FORALL bulk execution
          • Execute dynamic SQL
          • Privilege control
            • Create a pipelined function
            • Applications
          • SQL Transpiler
            • Interfaces of user-defined aggregate functions
          • PL Database Link
          • Modify and drop triggers
          • INSTEAD OF DML triggers
          • Composite DML triggers
          • System triggers
          • Create a package
          • Manage packages
          • PL environment definitions in the STANDARD package
          • Compile-time warnings
        • PL system package (Oracle-compatible mode)
          • DBMS_BALANCE
            • Overview of DBMS_LOB
            • DBMS_LOCK overview
            • RELEASE
            • Overview of DBMS_METADATA
            • GET_TABLE_INDEX_DDL
          • DBMS_MVIEW
            • PURGE_LOG
            • KILL_REFRESH
            • REFRESH_REPORT
            • OB_SESSION_TRACE_ENABLE
            • OB_SESSION_TRACE_DISABLE
            • OB_CLIENT_ID_TRACE_ENABLE
            • OB_CLIENT_ID_TRACE_DISABLE
            • OB_MOD_ACT_TRACE_ENABLE
            • OB_MOD_ACT_TRACE_DISABLE
            • OB_TENANT_TRACE_ENABLE
            • OB_TENANT_TRACE_DISABLE
          • DBMS_MVIEW_STAT
          • DBMS_PLSQL_CODE_COVERAGE
            • Overview of DBMS_PLSQL_CODE_COVERAGE
            • START_COVERAGE
            • STOP_COVERAGE
            • CREATE_COVERAGE_TABLES
          • DBMS_PARTITION
            • Overview of DBMS_PARTITION
            • CREATE_JOB_CLASS
            • DROP_JOB_CLASS
            • PURGE_LOG
            • STOP_JOB
          • DBMS_SCHEMA
            • RUN_INSPECTION
            • Overview of DBMS_SESSION
            • SESSION_IS_ROLE_ENABLED
            • IS_ROLE_ENABLED
            • BIND_ARRAY
            • RETURN_RESULT
            • VARIABLE_VALUE
            • Overview of DBMS_UTILITY
            • COMMA_TO_TABLE
            • VALIDATE
            • DBMS_XA constants
          • DBMS_XMLDOM
            • Overview of DBMS_XMLDOM
            • DOMDOCUMENT
            • DOMNODE
            • DOMNODELIST
            • FREEDOCUMENT
            • GETCHILDNODES
            • GETELEMENTSBYTAGNAME
            • GETNODEVALUE
            • ITEM
            • DOMATTR
            • DOMELEMENT
            • DOMTEXT
            • DOMCHARACTERDATA
            • NEWDOMDOCUMENT
            • CREATEELEMENT
            • CREATETEXTNODE
            • MAKENODE
            • MAKECHARACTERDATA
            • APPENDCHILD
            • REMOVECHILD
            • GETFIRSTCHILD
            • GETDOCUMENTELEMENT
            • GETNODENAME
            • GETLOCALNAME
            • GETNODETYPE
            • GETDATA
            • SETATTRIBUTE
            • SETCHARSET
            • SETVERSION
            • WRITETOBUFFER
            • WRITETOCLOB
          • DBMS_XMLPARSER
            • Overview of DBMS_XMLPARSER
            • PARSER
            • NEWPARSER
            • PARSECLOB
            • GETDOCUMENT
            • FREEPARSER
            • PARSEBUFFER
          • DBMS_PROFILER
            • START_PROFILER
            • STOP_PROFILER
            • PAUSE_PROFILER
            • RESUME_PROFILER
            • FLUSH_DATA
            • GET_VERSION
            • INTERNAL_VERSION_CHECK
            • ROLLUP_UNIT
            • ROLLUP_RUN
            • OB_INIT_OBJECTS
            • OB_DROP_OBJECTS
          • DBMS_XPROFILE
            • DISPLAY_PROFILE
          • DBMS_DDL
            • Overview of DBMS_DDL
            • WRAP
            • CREATE_WRAPPED
            • Overview of UTL_FILE
            • FCOPY
            • FCLOSE_ALL
            • FOPEN_NCHAR
            • FGETATTR
            • NEW_LINE_NCHAR
            • GET_RAW
            • GET_LINE_NCHAR
            • PUT_RAW
            • PUT_NCHAR
            • PUT_LINE_NCHAR
            • PUTF
            • PUTF_NCHAR
          • UTL_RECOMP
            • RECOMP_PARALLEL
            • RECOMP_SERIAL
            • PARALLEL_SLAVE
          • UTL_TCP
            • Overview of UTL_TCP
            • OPEN_CONNECTION
            • CLOSE_CONNECTION
            • CLOSE_ALL_CONNECTIONS
            • WRITE_LINE
            • WRITE_TEXT
            • WRITE_RAW
            • GET_TEXT
          • UTL_SMTP
            • Overview of UTL_SMTP
            • OPEN_CONNECTION
            • CLOSE_CONNECTION
            • QUIT
            • AUTH
            • COMMAND
            • COMMAND_REPLIES
            • HELO
            • EHLO
            • MAIL
            • RCPT
            • OPEN_DATA
            • WRITE_DATA
            • WRITE_RAW_DATA
            • CLOSE_DATA
            • DATA
            • VRFY
            • NOOP
            • RSET
          • UTL_HTTP
            • Overview of UTL_HTTP
            • BEGIN_REQUEST
            • END_REQUEST
            • GET_RESPONSE
            • END_RESPONSE
            • READ_LINE
            • READ_RAW
            • READ_TEXT
            • WRITE_LINE
            • WRITE_RAW
            • WRITE_TEXT
            • SET_TRANSFER_TIMEOUT
            • GET_TRANSFER_TIMEOUT
            • Overview of the ANYDATA type
            • ENDCREATE member procedure
            • GET* member functions
            • PIECEWISE member procedure
            • SET* member procedures
            • EXISTSNODE
            • TOOBJECT
        • Reserved PL keywords
      • View changes between V3.x and V4.x
          • information_schema.events
          • information_schema.TRIGGERS
          • oceanbase.CDB_CKPT_HISTORY
          • oceanbase.CBA_SCHEDULER_RUNNING_JOBS
          • oceanbase.CDB_SCHEDULER_JOBS
          • CDB_INDEX_USAGE
          • oceanbase.CDB_MVIEW_DEPS
          • CDB_MVIEW_LOGS
          • oceanbase.CDB_MVIEW_RUNNING_JOBS
          • CDB_MVIEWS
          • CDB_MVREF_CHANGE_STATS
          • CDB_MVREF_RUN_STATS
          • CDB_MVREF_STATS
          • CDB_MVREF_STATS_PARAMS
          • CDB_MVREF_STMT_STATS
          • oceanbase.CDB_OB_AI_MODEL_ENDPOINTS
          • oceanbase.CDB_OB_AI_MODELS
          • oceanbase.CDB_OB_BACKUP_VALIDATE_JOBS
          • oceanbase.CDB_OB_BACKUP_VALIDATE_JOB_HISTORY
          • oceanbase.CDB_OB_BACKUP_VALIDATE_TASKS
          • oceanbase.CDB_OB_BACKUP_VALIDATE_TASK_HISTORY
          • oceanbase.CDB_OB_CCL_RULES
          • oceanbase.CDB_OB_CS_REPLICA_STATS
          • oceanbase.CDB_OB_DYNAMIC_PARTITION_TABLES
          • oceanbase.CDB_OB_LOB_CHECK_EXCEPTION_RESULT
          • oceanbase.CDB_OB_LOB_CHECK_TASKS
          • oceanbase.CDB_OB_LS_REPLICA_TASK_HISTORY
          • oceanbase.CDB_OB_OBJECT_BALANCE_WEIGHT
          • oceanbase.CDB_OB_SERVICES
          • oceanbase.CDB_OB_RSRC_DIRECTIVES
          • oceanbase.CDB_OB_SENSITIVE_COLUMNS
          • oceanbase.CDB_OB_SENSITIVE_RULE_PLAINACCESS_USERS
          • oceanbase.CDB_OB_SENSITIVE_RULES
          • oceanbase.CDB_OB_SERVER_SPACE_USAGE
          • oceanbase.CDB_OB_SPACE_USAGE
          • oceanbase.CDB_OB_STORAGE_IO_USAGE
          • oceanbase.CDB_OB_SPM_EVO_RESULT
          • oceanbase.CDB_OB_SYNC_STANDBY_DEST
          • oceanbase.CDB_OB_TABLE_SPACE_USAGE
          • oceanbase.CDB_OB_TEMP_FILES
          • oceanbase.CDB_OB_TENANT_FLASHBACK_LOG_SCN
          • oceanbase.CDB_OB_VECTOR_INDEX_TASKS
          • oceanbase.CDB_OB_VECTOR_INDEX_TASK_HISTORY
          • oceanbase.CDB_WR_RES_MGR_SYSSTAT
          • oceanbase.CDB_WR_SQL_PLAN
          • oceanbase.CDB_OB_EXTERNAL_RESOURCES
          • oceanbase.DBA_INDEX_USAGE
          • oceanbase.DBA_JAVA_POLICY
          • oceanbase.DBA_MVIEW_DEPS
          • oceanbase.DBA_MVIEW_LOGS
          • oceanbase.DBA_MVIEW_RUNNING_JOBS
          • oceanbase.DBA_MVIEWS
          • oceanbase.DBA_MVREF_CHANGE_STATS
          • oceanbase.DBA_MVREF_RUN_STATS
          • oceanbase.DBA_MVREF_STATS
          • oceanbase.DBA_MVREF_STATS_PARAMS
          • oceanbase.DBA_MVREF_STATS_SYS_DEFAULTS
          • oceanbase.DBA_MVREF_STMT_STATS
          • oceanbase.DBA_OB_AI_MODEL_ENDPOINTS
          • oceanbase.DBA_OB_AI_MODELS
          • oceanbase.DBA_OB_BACKUP_VALIDATE_JOBS
          • oceanbase.DBA_OB_BACKUP_VALIDATE_JOB_HISTORY
          • oceanbase.DBA_OB_BACKUP_VALIDATE_TASKS
          • oceanbase.DBA_OB_BACKUP_VALIDATE_TASK_HISTORY
          • oceanbase.DBA_OB_CCL_RULES
          • oceanbase.DBA_OB_CS_REPLICA_STATS
          • oceanbase.DBA_OB_DYNAMIC_PARTITION_TABLES
          • oceanbase.DBA_OB_EXTERNAL_RESOURCES
          • DBA_OB_FORMAT_OUTLINES
          • oceanbase.DBA_OB_SERVICES
          • oceanbase.DBA_OB_RSRC_DIRECTIVES
          • oceanbase.DBA_SCHEDULER_RUNNING_JOBS
          • oceanbase.DBA_OB_STORAGE_IO_USAGE
          • oceanbase.DBA_OB_SYNC_STANDBY_DEST
          • oceanbase.DBA_OB_SPM_EVO_RESULT
          • oceanbase.DBA_OB_TEMP_FILES
          • oceanbase.DBA_OB_TENANT_FLASHBACK_LOG_SCN
          • oceanbase.DBA_OB_VECTOR_INDEX_TASKS
          • oceanbase.DBA_OB_VECTOR_INDEX_TASK_HISTORY
          • oceanbase.DBA_RECYCLEBIN
          • oceanbase.DBA_TABLES
          • oceanbase.DBA_WR_RES_MGR_SYSSTAT
          • oceanbase.DBA_WR_SQL_PLAN
          • oceanbase.USER_JAVA_POLICY
          • oceanbase.DBA_OB_LICENSE
          • GV$OB_CGROUP_CONFIG
          • GV$OB_FUNCTION_IO_STAT
          • GV$OB_GROUP_IO_STAT
          • GV$OB_HMS_CLIENT_POOL_STAT
          • GV$OB_HNSW_INDEX_INFO
          • GV$OB_IVF_INDEX_INFO
          • GV$OB_JAVA_SANDBOX_STATUS
          • GV$OB_JAVA_UDF_STATS
          • GV$OB_JVM_STATUS
          • GV$OB_KV_CONNECTIONS
          • GV$OB_LS_SNAPSHOTS
          • GV$OB_LS_LOG_REPLAY_STAT
          • GV$OB_LS_LOG_TRANSPORT_STAT
          • GV$OB_NIC_INFO
          • GV$OB_PLUGINS
          • GV$OB_RES_MGR_SYSSTAT
          • GV$OB_SESSION_PS_INFO
          • GV$OB_SHARED_STORAGE_QUOTA
          • GV$OB_SQL_CCL_STATUS
          • GV$OB_TENANT_RESOURCE_LIMIT
          • GV$OB_VECTOR_MEMORY
          • gv$tenant
          • GV$OB_KV_CLIENT_INFO
          • GV$UNIT
          • V$OB_COMPATIBILITY_CONTROL
          • V$OB_CGROUP_CONFIG
          • V$OB_DYNAMIC_PARTITION_TABLES
          • V$OB_FUNCTION_IO_STAT
          • V$OB_GROUP_IO_STAT
          • V$OB_HMS_CLIENT_POOL_STAT
          • V$OB_HNSW_INDEX_INFO
          • V$OB_IVF_INDEX_INFO
          • V$OB_JAVA_SANDBOX_STATUS
          • V$OB_JAVA_UDF_STATS
          • V$OB_JVM_STATUS
          • V$OB_KV_CLIENT_INFO
          • V$OB_KV_GROUP_COMMIT_STATUS
          • V$OB_LS_LOG_REPLAY_STAT
          • V$OB_LS_LOG_TRANSPORT_STAT
          • V$OB_LS_SNAPSHOTS
          • V$OB_NIC_INFO
          • V$OB_PLUGINS
          • V$OB_RES_MGR_SYSSTAT
          • V$OB_SESSION_PS_INFO
          • V$OB_SHARED_STORAGE_QUOTA
          • V$OB_SQL_CCL_STATUS
          • V$OB_TENANT_RESOURCE_LIMIT
          • V$OB_TRANSACTION_SCHEDULERS
          • V$RESTORE_POINT
          • V$OB_VECTOR_MEMORY
          • V$UNIT
          • mysql.audit_log_filter
          • mysql.audit_log_user
          • oceanbase.DBA_OB_LOB_CHECK_EXCEPTION_RESULT
          • oceanbase.DBA_OB_OBJECT_BALANCE_WEIGHT
          • oceanbase.DBA_OB_SENSITIVE_COLUMNS
          • oceanbase.DBA_OB_SENSITIVE_RULE_PLAINACCESS_USERS
          • oceanbase.DBA_OB_SENSITIVE_RULES
          • oceanbase.DBA_OB_TABLE_SPACE_USAGE
          • GV$OB_HNWS_INDEX_INFO
          • GV$OB_JVM_STATUS
          • GV$OB_NIC_INFO
          • V$OB_HNWS_INDEX_INFO
          • V$OB_JVM_STATUS
          • V$OB_KEYWORDS
          • V$OB_KV_CONNECTIONS
          • V$OB_LS_SNAPSHOTS
          • V$OB_NIC_INFO
          • V$RESTORE_POINT
          • ALL_LOCATIONS
          • ALL_MVIEW_LOGS
          • ALL_MVIEWS
          • ALL_OB_SOURCE
          • ALL_PLSQL_TYPES
          • ALL_PLSQL_COLL_TYPES
          • ALL_PLSQL_TYPE_ATTRS
          • DBA_INDEX_USAGE
          • DBA_JAVA_POLICY
          • DBA_MVIEW_DEPS
          • DBA_MVIEW_LOGS
          • DBA_MVIEW_RUNNING_JOBS
          • DBA_MVIEWS
          • DBA_MVREF_CHANGE_STATS
          • DBA_MVREF_RUN_STATS
          • DBA_MVREF_STATS
          • DBA_MVREF_STATS_PARAMS
          • DBA_MVREF_STMT_STATS
          • DBA_OB_BACKUP_VALIDATE_JOBS
          • DBA_OB_BACKUP_VALIDATE_JOB_HISTORY
          • DBA_OB_BACKUP_VALIDATE_TASKS
          • DBA_OB_BACKUP_VALIDATE_TASK_HISTORY
          • DBA_OB_CS_REPLICA_STATS
          • DBA_OB_CCL_RULES
          • DBA_OB_DYNAMIC_PARTITION_TABLES
          • DBA_OB_LOB_CHECK_EXCEPTION_RESULT
          • DBA_OB_PL_OBJ_CACHE_STATUS
          • DBA_OB_SENSITIVE_COLUMNS
          • DBA_OB_SENSITIVE_RULE_PLAINACCESS_USERS
          • DBA_OB_SENSITIVE_RULES
          • DBA_OB_SERVICES
          • DBA_OB_OBJECT_BALANCE_WEIGHT
          • DBA_OB_RSRC_DIRECTIVES
          • DBA_OB_SPATIAL_COLUMNS
          • DBA_OB_STORAGE_IO_USAGE
          • DBA_OB_SYNC_STANDBY_DEST
          • DBA_OB_SYS_VARIABLES
          • DBA_OB_SOURCE
          • DBA_OB_SPM_EVO_RESULT
          • DBA_OB_TENANT_FLASHBACK_LOG_SCN
          • DBA_OB_TEMP_FILES
          • DBA_PLSQL_TYPES
          • DBA_PLSQL_COLL_TYPES
          • DBA_PLSQL_TYPE_ATTRS
          • DBA_SCHEDULER_RUNNING_JOBS
          • DBA_OB_TABLE_SPACE_USAGE
          • DBA_WR_RES_MGR_SYSSTAT
          • DBA_WR_SQL_PLAN
          • PROXY_USERS
          • USER_PLSQL_TYPES
          • USER_PLSQL_COLL_TYPES
          • USER_PLSQL_TYPE_ATTRS
          • USER_MVIEW_LOGS
          • USER_MVIEWS
          • USER_MVREF_CHANGE_STATS
          • USER_MVREF_RUN_STATS
          • USER_MVREF_STATS
          • USER_MVREF_STATS_PARAMS
          • USER_MVREF_STMT_STATS
          • USER_OB_SOURCE
          • USER_SCHEDULER_JOBS
          • USER_JAVA_POLICY
          • GV$OB_NIC_INFO
          • GV$OB_RESULT_CACHE_OBJECTS
          • V$OB_KEYWORDS
          • V$OB_LS_SNAPSHOTS
          • V$OB_NIC_INFO
          • V$OB_RESULT_CACHE_OBJECTS
          • V$RESTORE_POINT
          • GV$OB_JVM_STATUS
          • V$OB_JVM_STATUS
      • Monitoring Items Overview
      • General wait events
      • Changes to parameters and system variables in V3.x and V4.x
        • Overview of parameters
          • alert_log_level
          • async_ps_cursor_max_count
          • clog_io_isolation_mode
          • das_batch_rpc_delay_us
          • enable_ob_error_msg_style
          • external_table_disk_cache_max_percentage
          • global_background_cpu_quota
          • io_scheduler_thread_count
          • log_storage_warning_trigger_percentage
          • ob_python_home
          • ob_enable_java_env
          • ob_java_home
          • ob_java_connector_path
          • ob_java_opts
          • ob_enable_java_udf_sandbox
          • ob_enable_utl_http
          • plugins_load
          • prometheus_metrics_port
          • sync_io_thread_count
          • syslog_sync_size_threshold
          • unit_gc_wait_time
          • utl_file_open_max
          • approx_count_distinct_precision
          • audit_log_buffer_size
          • audit_log_compression
          • audit_log_enable
          • audit_log_encryption
          • audit_log_format
          • audit_log_max_size
          • audit_log_path
          • audit_log_prune_seconds
          • audit_log_query_sql
          • audit_log_rotate_on_size
          • audit_log_strategy
          • auto_split_tablet_size
          • default_load_mode
          • default_micro_block_format_version
          • default_skip_index_level
          • default_table_merge_engine
          • default_table_organization
          • default_table_store_format
          • direct_load_allow_fallback
          • enable_adaptive_plan_cache
          • enable_auto_split
          • enable_clog_encryption
          • enable_database_sharding_none
          • enable_hbase_rowkey_ttl
          • enable_pl_rich_error_msg
          • enable_gts_standalone
          • enable_kv_group_commit
          • enable_lock_priority
          • enable_mlog_auto_maintenance
          • enable_ps_meta_response_optimize
          • enable_mv_binlog_minimal_mode
          • enable_ls_leader_balance
          • enable_standby_semi_sync
          • enable_ps_parameterize
          • external_table_io_hole_size
          • external_table_io_range_size
          • external_table_csv_max_buffer_size
          • global_index_auto_split_policy
          • json_document_max_depth
          • kv_group_commit_batch_size
          • kv_group_commit_rw_mode
          • kv_hbase_client_scanner_timeout_period
          • load_data_diagnosis_log_compression
          • load_data_diagnosis_log_max_size
          • load_vector_index_on_follower
          • ls_scale_out_factor
          • mds_compaction_high_thread_score
          • mds_compaction_mid_thread_score
          • mds_minor_compact_trigger
          • mlog_trim_interval
          • mv_refresh_concurrency
          • ob_encoding_granularity
          • ob_enable_python_udf
          • ob_vector_memory_limit_percentage
          • ob_vector_search_strategy
          • px_node_policy
          • package_state_sync_max_size
          • recover_table_concurrency
          • recover_table_dop
          • result_cache_max_size
          • result_cache_max_result
          • ob_result_cache_evict_percentage
          • schema_history_archive_expire_time
          • spill_compression_codec
          • sts_credential
          • storage_rowsets_size
          • vector_index_memory_saving_mode
          • vector_index_optimize_duty_time
          • zone_deploy_mode
          • zone_disk_balance_tolerance_percentage
          • caching_sha2_password_digest_rounds
          • default_authentication_plugin
          • ENABLE_OPTIMIZER_ROWGOAL
          • innodb_stats_persistent
          • json_float_full_precision
          • long_query_time
          • max_execution_time
          • mview_refresh_dop
          • ob_compatibility_control
          • ob_compatibility_version
          • ob_enable_ps_parameter_anonymous_block
          • ob_enable_pl_async_commit
          • ob_enable_parameter_anonymous_block
          • ob_sm3_password_digest_rounds
          • ob_table_access_policy
          • ob_udf_cost_factor
          • ob_udf_selectivity
          • ob_security_version
          • partition_index_dive_limit
          • plsql_ccflags
          • pid_file
          • plsql_can_transform_sql_to_assign
          • port
          • query_rewrite_enabled
          • query_rewrite_integrity
          • range_index_dive_limit
          • socket
          • session_track_schema
          • session_track_state_change
          • session_track_system_variables
          • SQL_TRANSPILER
          • enable_sql_plan_monitor
          • ob_hnsw_ef_search
          • ob_ivf_nprobes
          • ob_sparse_drop_ratio_search
      • MySQL-compatible mode
        • 0001 ~ 3999
        • 4000 ~ 4499
        • 4500 ~ 4999
        • 5000 ~ 5999
        • 6000 ~ 6999
        • 7000 ~ 7999
        • 8000 ~ 8999
        • 9000 ~ 9499
        • 9500 ~ 9999
        • 10000 ~ 12000
      • Oracle-compatible mode
        • OBE-00000 ~ OBE-00999
        • OBE-01000 ~ OBE-01499
        • OBE-01500 ~ OBE-01999
        • OBE-02000 ~ OBE-04999
        • OBE-05000 ~ OBE-10000
        • OBE-10000 ~ OBE-19999
        • OBE-20000 ~ OBE-29999
        • OBE-30000 ~ OBE-49999
        • OBE-50000 ~ OBE-99999
        • PLS-00000 ~ PLS-00999
          • Top general tool
          • CPU-related parameters
          • I/O-related parameters
          • Network transmission related parameters
        • Cluster performance diagnosis
          • Generate an ASH report
          • Analyze an ASH report
          • ASH best practices
          • Execution plan cache
          • Execution plan operators
            • JOIN
            • WINDOW FUNCTION
            • SUBPLAN FILTER
            • DISTINCT
            • SEQUENCE
            • MATERIAL
            • SORT
            • LIMIT
            • FOR UPDATE
            • SUBPLAN SCAN
            • UNION
            • INTERSECT
            • EXCEPT/MINUS
            • EXCHANGE
            • GI
          • Display execution plans in real time
          • Parallel DDL
        • Parallel execution plans
          • Set concurrent execution
          • Overview of SQL tuning
              • Overview of statistics collection methods
              • Asynchronous statistics collection
            • Collection and update strategy for partitioned table statistics
            • OceanBase statistics management practical guide
            • Rule-based query rewrite
            • Optimizer Hint
            • SQL execution plan management (SPM)
        • SQL performance analysis best practices
    • Performance testing
      • OceanBase Sysbench testing
        • OceanBase Sysbench high-performance parameter configuration
        • OceanBase Sysbench performance issue analysis
      • OceanBase TPC-DS testing
        • OceanBase Database TPC-DS testing
        • OceanBase Database TPC-DS benchmark report
      • OceanBase TPC-H testing
        • OceanBase Database TPC-H testing
        • OceanBase Database TPC-H benchmark report
      • OceanBase Developer Center (ODC)
        • obshell
          • Use cases
            • obshell management
              • Start or stop obshell
              • Upgrade obshell
            • cluster management
              • Deploy an OceanBase cluster
              • Deploy ODP
              • Initiate a cluster-level backup
              • Replace a faulty node
              • Initiate a tenant-level backup
              • Initiate tenant-level restore
              • Expand a tenant
          • obshell commands
            • Agent commands of obshell
            • Cluster commands of obshell
            • obshell unit commands
            • obshell resource pool commands
            • Tenant command group of obshell
            • Task commands of obshell
            • Backup commands in obshell
            • obshell restore command group
            • obshell recyclebin command group
          • obshell Dashboard
            • obshell Dashboard
            • Cluster information
            • Cluster Management
              • Database Management
              • User Management
                • Overview of Backup and Restore
                • Immediately backup
                • Initiate restore
            • Performance Monitoring
            • Alarm center
              • Managing Alert Suppression
            • Parameter management
            • Package management
            • Task Management
            • obshell API requests
              • Set node password
              • Initialize Cluster
              • Upgrade OceanBase Database
              • Scale out a cluster
              • Cluster shrink
              • GetObInfo
              • Delete a Zone
            • ODP management
              • Deploy ODP
              • Start ODP
              • Stop ODP
              • Upload an ODP installation package
              • Upgrade ODP
              • Destroy ODP
            • Unit config management
              • Create a resource specification
              • Retrieve all resource specifications
              • Query the information of a specified resource specification
              • Delete a resource specification
            • Resource pool management
              • Get information about all resource pools
              • Delete a specified resource pool
              • Query tenant information
              • Change the tenant password
              • Modify the access whitelist of a tenant
              • Modify the primary zone of a tenant
              • Modify tenant system variables
              • Modify tenant parameters
              • Add a tenant replica
              • Modify a tenant replica
              • Delete a tenant replica
              • Get an overview of all tenants
              • Query a system variable of a specified tenant
              • Fuzzy query tenant system variables
              • Query parameters of a specified tenant
              • Fuzzy query tenant parameters
            • Backup management
              • Set the backup configuration for a tenant
              • Set cluster-level backup configurations
              • Update the backup configuration of a tenant
              • Update the cluster-level backup configuration
              • Initiate a backup for a single tenant
              • View information about a backup task for a tenant
              • View cluster-level backup tasks
              • Modify the backup status of a tenant
              • Modify the status of cluster-level backups
              • Modify the log archiving status of a tenant
              • Modify the log archiving status of a cluster
            • Restore management
              • Initiate tenant restore
              • View tenant recovery
              • Cancel tenant restore
            • Recycle bin management
              • Query all tenant information in the recycle bin
              • Restore a tenant from the recycle bin
              • Clear a tenant from the recycle bin
            • Other APIs
          • SDK references
                • Install obshell
                • Start obshell
                • Upgrade agents
                • Set node password
                • Query the status of a node
                • Initialize nodes
                • Initialize a cluster
                • Start a cluster
                • Scale in a cluster
              • ODP management
                • Deploy ODP
                • Start ODP
                • Stop ODP
                • Upgrade ODP
                • Destroy ODP
                • Obtain information about all resource specifications
                • Query information about a specified resource unit
                • Delete a resource pool
                • Change the password of a tenant
                • Query the overview of all tenants
                • Query tenant system variables
                • Query tenant parameters
              • Backup management
                • Configure the backup settings for a tenant
                • Configure cluster-level backup settings
                • Update cluster-level backup configuration
                • View a backup task of a tenant
                • View cluster-level tenant backup tasks
                • Change the log archiving status of a tenant
                • Restore a single tenant
                • Cancel tenant restoration
                • Get information about all tenants in the recycle bin
                • Purge a tenant from the recycle bin
                • Operate a task
                • Query all unfinished tasks
              • Other APIs
                • Search for RPM packages
                • Download RPM packages
                • Upload an RPM package
            • GO
              • Quick Start with obshell-sdk-go
                • Install obshell
                • Start obshell
                • Upgrade agents
                • Initialize the nodes
                • Start a cluster
                • Cluster shrink
                • Query all resource specifications
                • Query the specifications of a specified resource
                • Drop a resource unit configuration
                • Change a tenant password
                • Modify the tenant access whitelist
              • Backup management
                • Set the cluster-level backup configuration
                • Update the backup configuration for a tenant
                • View a backup task for a tenant
                • Modify the status of a cluster-level backup
                • Modify the status of cluster-level log archiving
                • Initiate a restore for a single tenant
                • Purge tenants from the recycle bin
                • Operate a task
              • Other APIs
        • obd
            • test_io_device
            • io_adapter_benchmark
        • sql_diagnoser
          • Install and use SQL diagnoser sql_diagnoser
            • Install sql_diagnoser
            • Use sql_diagnoser
          • sql_diagnoser parameters
            • API operations
      • Log analysis
        • oblogminer
          • Install oblogminer
        • obloader and obdumper
          • Overview of obcdc
            • Sample configuration file
            • General obcdc parameters
          • Throttling
          • obcdc supports synchronous standby databases
          • obcdc supports data dictionaries.
      • Stress testing tools
    • OceanBase plugin
      • Overview of OceanBase plugin
      • Tokenizer plugin
      • MySQL external table plugin
    • Products
    • FAQ about SQL statements
    • FAQ about columnstores
    • Version number guidelines
    • Release history of OceanBase Database Enterprise Edition
    • Release history of OceanBase Database Community Edition
      • V4.4
        • OceanBase Database Enterprise Edition V4.4.2
        • OceanBase Database Enterprise Edition V4.3.5
        • OceanBase Database Enterprise Edition V4.3.1
      • V4.4
        • OceanBase Database Community Edition V4.4.2
        • OceanBase Database Community Edition V4.3.5
  4. V4.4.2
Last Updated:2026-09-03 07:31:11
Privilege requirements
Attributes
Examples
For V3.2.1, this parameter is available starting with V3.2.1.
connection_control_max_connection_delay specifies the maximum lock duration after the number of failed login attempts exceeds the threshold.
Applicability
This parameter is applicable only to OceanBase Database in MySQL-compatible mode.
  • Query the parameter
    The sys tenant and all user tenants can query this parameter by using the SHOW PARAMETERS statement or the GV$OB_PARAMETERS view.
  • Modify the parameter
    The sys tenant and user tenants can modify this parameter.
Attributes
Type Int
Default value 2147483647, in milliseconds
Modifiable Yes. You can use the ALTER SYSTEM SET statement to modify the parameter.
Effective upon OBServer node restart No. The setting takes effect immediately.
Examples
Set the maximum lock duration after the number of failed login attempts exceeds the threshold to 2147483647 milliseconds.
obclient> ALTER SYSTEM SET connection_control_max_connection_delay = 2147483647;
Identity authentication
connection_control_failed_connections_threshold
Attributes
Examples
