SQL - V5.0.1
    • Feature differences between Enterprise Edition and Community Edition
      • Overview of Oracle compatibility
    • Learn OceanBase SQL
      • Before you begin
      • Basic SQL operations (MySQL-compatible mode)
      • Basic SQL operations (Oracle-compatible mode)
    • Build a sample application (MySQL-compatible mode)
      • Build a Python application
      • Build a Java application
      • Build a C application
      • Build a Go application
    • Build a sample application (Oracle-compatible mode)
      • Create a Java sample application
      • Create a C application
      • Scalable OLTP
        • Experience the hot row update capability of OceanBase Database
      • Try out operational OLAP
    • Develop applications (MySQL-compatible mode)
          • JDBC
          • Spring JDBC
          • MyBatis sample application for connecting to OceanBase Database
          • Connector/J
          • TestContainers
          • MySQL-connector-python
          • MySQL Connector/C
        • NET
          • Connect to an OceanBase database by using OceanBase Connector/NET
        • PHP
          • EXT
          • MySQLi
          • PDO
        • Rust
          • Connect to OceanBase Database by using Rust
          • Connect to OceanBase Database by using SeaORM
          • Lock query results with SELECT FOR UPDATE
          • Use regular expressions in queries
    • Develop applications (Oracle-compatible mode)
        • NET
          • Connect to OceanBase Database using OceanBase Connector/NET
        • Configure servers
      • Deploy OceanBase Database Java SDK
        • Deploy OceanBase Database in a container
      • Deploy OceanBase Desktop
    • Clear an OceanBase cluster
    • Recommended configurations
  • OceanBase version upgrade
      • Check the status after the upgrade
      • Upgrade OceanBase Database with obd
      • Export data using the OUTFILE statement
    • Overview of direct load
        • Add nodes
        • Reset cluster parameters
          • Overview of Resource Isolation
          • Manage resource isolation (Oracle-compatible mode)
            • Configure cgroup
          • Manage resource isolation (MySQL-compatible mode)
            • Configure cgroup
            • Update resource management plan directive
          • Resource isolation configuration examples for background tasks
        • View tenant system variables
          • Tenant pre-scaling
          • Smooth scaling application scenarios
          • Merge and split a resource pool
          • Modify a unit config
          • Drop a unit config
        • Manage services
          • Create a service
          • Query the service status
          • Start a service
          • Stop a service
    • Manage log streams
      • Create a log stream
      • Modify a log stream
      • Replicas
          • Remove replicas
          • Replica migration
          • Cancel a replica task
      • Overview of data load balancing
      • Transfer Partition
      • Cancel a Balance Job
      • Suspend or resume a balance job
      • Table group weight management
        • Aggregation of user tables in a database
        • Set table group weights
        • Clear table group weights
        • Application scenarios of table group weight balancing
      • Balance weight management
        • Set partition weights
        • Clear partition weights
      • Partition balance management
        • Configure a scheduled partition balancing task
        • Manually trigger partition balancing
        • View the configurations of the scheduled partition balancing task
        • View the triggering history of the scheduled partition balancing task
        • View the partition balancing task in the background
        • View the history of partition balancing tasks in the background
      • GTS standalone application scenario
            • Set a log restore source
          • Specify log compression
        • Enable arbitration service for a tenant
        • MySQL-compatible mode
          • Login failure processing
          • Dual-password management
        • Oracle-compatible mode
          • Password Rotation
            • Privilege types in MySQL-compatible mode
            • Role management
              • Grant privileges to a role
            • Privilege types in Oracle-compatible mode
            • Use a proxy user
      • Data encryption
          • Transport encryption for OBServer
        • Tenant master key management
          • Generate a tenant master key (MySQL-compatible mode)
          • Generate a tenant master key (Oracle-compatible mode)
            • Enable TDE for new tables
        • Column encryption
          • Overview of column encryption
            • Create a column encryption rule
            • Manage column encryption privileges
            • Column encryption permissions
          • FAQ about column encryption
        • Security audit overview
        • Security audit in MySQL-compatible mode
          • Enable security auditing
          • Set an auditing rule
          • View auditing records
          • Disable security auditing
          • Appendix: Complete list of SQL types supported by general_sql_command
        • Security audit in Oracle-compatible mode
          • Audit user logins
        • Prepare for backup
        • Back up parameters
        • View parameters related to data backup
        • Modify the source-side backup path configuration
      • Update `access_id` and `access_key` information for the backup or archive path
        • Automatic backup cleanup
          • Automatically clean up expired backups
          • Delete a cleanup policy
        • Manual backup cleanup
          • Manually trigger the cleanup of expired backups
          • Manually clean up specified backup or archive data
          • Manually clear the backup path or archive path
        • Cancel a cleanup task
        • Query the backup cleanup results
      • Backup validation
        • Backup validation overview
        • Validate the entire backup path and archive path
        • Validate a specified backup set or log archive piece
        • Validate a backup set or log archive piece in a specified path
        • Cancel a backup validation task
        • View the backup verification progress
        • View the backup validation result
        • Prepare for restore
        • Perform physical restore
        • Overview of table-level restore
        • Preparations before table-level restore
        • Perform table-level restore
        • Schema recovery in table-level restore
        • Cancel table-level restore
        • Check the progress of table-level restore
        • Check the results of table-level restore
        • Parameters related to table-level restore
        • Views related to table-level restore
      • Backup and restore performance tuning
      • Example of configuring the source backup and archive paths
      • Appendix: S3 path format
          • Overview of system monitoring metrics
          • SYSSTAT metrics
      • Root service events
      • Log overview
      • Log interpretation
      • Alert logs
      • Check the resource usage status of a tenant
            • Large and small accounts
          • Join
              • Hash Join
              • Merge join
          • Schema specifications
      • BootStrap
        • Forced leader election
        • No leader
        • Transaction issues
        • Long-running transactions
        • Suspended transactions
        • Other issues
      • FAQ about manual operations on log streams
      • Materialized view exception diagnosis
      • Application exceptions -- error messages without OceanBase error codes
      • Application exceptions -- error messages with OceanBase error codes
      • Troubleshoot application disconnection issues
      • Troubleshoot merge exceptions
      • External table troubleshooting guide
          • SQL query exceptions
  • OceanBase AP
    • AP version update record
    • Overview of OceanBase Database AP
    • Core features of OceanBase Database AP
    • Quickly try out OceanBase AP
      • Deploy an AP architecture
      • Parameter configuration recommendations for AP scenarios
      • Deploy and use columnstore replicas
      • AP query routing rules
    • Data table design
      • Overview of Data Tables
      • Use columnar storage and hybrid row-column storage
        • Dynamic partitioning
      • Best practices for data table design
        • Primary key design in AP scenarios
        • Practices for JSON multi-valued indexes and full-text indexes
        • Table partitioning design practices for AP scenarios
        • Configure Skip Index in conjunction with table update mode
        • Columnstore tables and indexes in practice
    • Data transfer
      • Data transmission overview
      • Data migration
        • Data Migration Overview
        • Migrate data by using tools
        • Best practices for migrating data from mainstream AP databases to OceanBase
      • Data import
        • data-import
        • INSERT INTO SELECT
          • INSERT INTO SELECT FROM FILES
          • Import data using INSERT INTO SELECT from an external table
        • CREATE TABLE AS SELECT
        • Import data by using obloader
      • Data subscription and synchronization
        • Data Synchronization
        • Data subscription
      • Data processing in OceanBase Database
      • Data processing tools
      • Materialized views query acceleration
        • Query acceleration using materialized views
        • Classic scenarios for materialized views
    • Data lake
      • Data lake overview
      • Data lake integration
        • Access Hive tables through HMS Catalog
        • Load an Iceberg table through a catalog
        • ODPS
          • ODPS Catalog
          • ODPS External Table
        • Catalogs and external tables
        • File external tables
      • External tables via URL
      • Statistics
    • Data visualization
    • Ecosystem integration
      • Recommended practical tutorials for analytical processing
      • Accelerate offline queries in OceanBase Database using HMS Catalog
      • Practical Tutorial on Querying and Reading/Writing MaxCompute (ODPS) Data in OceanBase
    • AP FAQ
  • OceanBase AI
      • Overview of vector search
      • Core features of vector search
      • AI application workflow with OceanBase Vector Search
      • Use SQL to perform vector search
      • Perform a vector search by using Python
    • Vector embedding
    • Store vector data
    • Vector index
      • Vector index memory management
      • Dense vector index
        • Choose an index type
        • HNSW index
        • IVF series indexes
      • Semantic index
      • Sparse vector index
        • In-Memory Sparse Index
      • Monitor and maintain vector indexes
    • Use SQL functions
    • Vector similarity search
    • Hybrid search
      • Hybrid search (SQL interface)
      • Hybrid search (PL interface)
    • AI function service
      • Get started with AI Function Service
      • AI function service privileges
      • Register AI models
      • Syntax and examples of AI functions
    • Migrate to OceanBase Database from a vector database
    • Practical tutorial
    • Benchmark testing with VectorDBBench
    • Vector search references
      • Overview of vector data types
      • Search index
      • Compatibility
      • Supported clients and languages
        • Java SDK interface
  • Integrations
    • ORM frameworks
        • Connect to OceanBase Database by using Spring Boot
        • Connect to OceanBase Database by using Spring Batch
        • Connect to OceanBase Database by using Spring Data JDBC
        • Connect to OceanBase Database by using Spring Data JPA
        • Sample program that uses MyBatis to connect to OceanBase Database
        • Connect to OceanBase Database by using SQLAlchemy
        • Connect to OceanBase Database by using peewee
        • Connect to OceanBase Database by using GORM
      • Ruby
        • Connect to OceanBase Database by using Active Record
        • Sequel
    • Database version management
      • Liquibase
      • dbt
      • SeaTunnel
      • Maxwell
      • Debezium
    • SQL development
      • DBeaver
      • Navicat
      • DataGrip
      • TablePlus
    • Orchestration and scheduling
      • DolphinScheduler
      • Linkis
    • Visualization tools
      • Superset
      • Power BI
      • Quick BI
      • Tableau
      • NineData
      • Bytebase
    • AI
      • OpenAI
      • Qwen
      • LangChain
      • LlamaIndex
      • Dify
    • Build an intelligent Q&A assistant with OceanBase Database
    • Build a real-time data warehouse and visual dashboard with OceanBase
    • Analyze data in OceanBase Database using Superset
    • Build a WordPress website with OceanBase Database
    • Accelerate massive data import using direct load
    • OceanBase concepts
      • OceanBase Database architecture
          • Resource management for tenants
            • Replicated table
            • Temporary table
            • Table groups
            • Overview of indexes
            • Partition types
            • External table partitions
            • Views in a database
            • Standard views
              • Standard views
            • Replicated table
            • Table groups
            • Full-text index
            • Vector index
            • Search index
            • Standard views
              • Foreign key constraints
            • Read-only replicas
            • Columnstore replica
          • Data balancing
            • Intra-tenant balancing
          • Cluster-level scaling
          • Tenant-level scaling
        • Cross-data source access through DBLink
          • DBLink in MySQL-compatible mode
          • DBLink in Oracle-compatible mode
            • Monitor DDL execution progress
            • Tune parameters for parallel queries
            • Lock wait manager
            • Transaction isolation levels in Oracle-compatible mode
            • Transaction isolation levels in MySQL-compatible mode
          • Weak-consistency read
          • Columnar storage
          • Major compaction
        • Multi-level caching in shared-nothing architecture
          • Backup directory structure
          • Restore process
        • Configuration file
          • Trigger daily tenant compaction
          • Window compaction
          • Adaptive major compactions
          • Manually trigger a major compaction
          • View compaction information
        • Use the TTL feature
        • Memory management in a tenant
        • FAQ about memory
        • Configure dynamic expansion of disk data files
        • View the disk space used by a tenant or table
          • Skip index attribute
          • Change the attribute of a table
            • External tables and external files
            • Create and query external tables
            • Data type mapping
          • Partitioning overview
          • Partition splitting
            • Manual partition splitting
            • Automatic partition splitting
            • Automatic partition recommended configuration
            • Overview of dynamic partitioning
            • Create a dynamic partitioned table
            • Query a dynamic partitioned table
            • Modify a dynamically partitioned table
            • Dynamic partition management tasks
          • Random partition tables
            • Overview of Random Distribution Tables
            • Create a table with random distribution
            • Modify a table with a random distribution
          • Delete a partition
          • Truncate partitions
          • Partition exchange
          • Overview of Table Groups
          • Modify table group attributes
          • Manage tables within a table group
          • Manage standard views
          • Manage materialized views
            • Overview of materialized views
            • Materialized view logs
            • Create a materialized view
            • Refresh a materialized view
            • Query materialized views
            • Modify the attributes of a materialized view
            • Drop a materialized view
            • Materialized view resource isolation
        • Create and manage catalogs
          • Catalog Overview
          • Create catalog
          • View catalog
          • Drop catalog
            • Create and query an external table
            • Data type mapping
            • Automatic subpartition splitting
          • Drop partitions
            • Refresh materialized views
      • SQL overview
          • Overview of management commands
            • ADD REPLICA
            • ADD RESTORE SOURCE
            • BACKUP CLUSTER PARAMETERS
            • BALANCE JOB
            • CANCEL REPLICA TASK
            • CANCEL VALIDATE
            • CLEAR RESTORE SOURCE
            • CREATE LS
            • DELETE BACKUP ALL
            • DELETE BACKUPSET/ARCHIVELOG_PIECE
            • DELETE OBSOLETE BACKUP
            • LOAD MODULE DATA
            • MIGRATE REPLICA
            • MODIFY LS
            • MODIFY PAXOS_REPLICA_NUM
            • MODIFY REPLICA
            • FLUSH SEQUENCE CACHE
            • FLASHBACK STANDBY LOG
            • REMOVE REPLICA
            • RESTORE PREVIEW
            • SERVICE_NAME
            • TTL
            • VALIDATE
          • CLONE TENANT
          • SHOW RESTORE PREVIEW
        • User tenants (MySQL-compatible mode)
                • Overview of numeric types
                • Integer types
                • Fixed-point types
                • Floating-point types
                • BIT Value
                • Overview of datetime types
                • ON UPDATE CURRENT_TIMESTAMP column attribute
                • Overview of string types
                • Overview of large objects and text types
                • BLOB type
                • STRING type
                • LOB types
              • Set types
                • Overview of JSON data types
                • Convert data types to JSON
                • Update JSON data
                • Semi-structured encoding
                • Overview of spatial data types
                • Spatial reference systems (SRS)
                • Create spatial columns
                • Create spatial indexes
              • Roaring bitmap types
                • Overview of the RoaringBitmap data type
                • Create a roaring bitmap column
              • Array data types
                • Create an array column
              • Map data types
                • Overview of mapping data types
                • Create a mapped column
              • Overview of expressions
              • Simple Expressions
              • Compound Expressions
              • Conditional Expressions
              • Column Expressions
              • Date and time expressions
              • Function Expressions
              • List of Expressions
              • Character Sets
              • Character set and collation of character expressions
              • Character set and collation for client connections
              • String literals
              • Numeric values
              • Date and time values
              • NULL values
                • Use Query Block Name and QB_NAME Hint to control query optimization
                  • Global hints
                    • Optimizer Stats Hint under the Global Hint Type
                    • Transform Hint in the Global Hints section
                    • Other hints under global hints
                    • Access path hints in the Optimized Hint category
                    • Join order hints in the Optimized Hint category
                    • Join operation hints in the Optimized Hint category
                    • Subquery hints under the Optimized Hint category
                    • Group By Hint in the Optimized Hint category
                    • Distinct hint
                    • Set Hint in Optimized Hint Type
                    • Distributed DML hints in the Optimized Hint category
                    • Vector Index Hint in the Optimized Hint category
                  • Transform hints
                    • Stmt Transform Hint
                    • Cost-based transform hints
                    • Heuristics transform hints
                    • Other hints under the Transform Hint type
                  • Outline-related hints
            • Assignment operator
            • Character concatenation operators
            • BINARY conversion operators
            • Function overview
                • DATE_TRUNC
                • MONTHS_ADD
                • FORMATDATETIME
                • TOUNIXTIMESTAMP
                • parseDateTime
                • KEYVALUE
                • MAX_PT
                • MD5_CONCAT_WS
                • SPLIT_PART
                • URL_DECODE
                • URL_ENCODE
                • EDITDISTANCE
                • DECODE_TRACE_ID
              • ARG_MAX
              • ARG_MIN
              • WINDOW_FUNNEL
              • STRING_AGG
              • AVG_WEIGHTED
              • ARBITRARY
              • ANY
              • GROUPCONCAT
              • STDDEVSAMP
              • UNIQ
              • VARSAMP
              • LAGINFRAME
              • LEADINFRAME
              • ENHANCED_AES_ENCRYPT
              • ENHANCED_AES_DECRYPT
              • PASSWORD
              • SM3
              • SM4_ENCRYPT
              • SM4_DECRYPT
              • CATALOG
              • LAST_INSERT_ID Behavior Description
              • OB_TRANSACTION_ID
              • JSON_TABLE function
              • Overview of XML functions
            • Table functions
              • Overview of TABLE FUNCTIONS
              • FILES table function
              • Overview of spatial functions
              • Create a geometry value function
              • Spatial relationship functions
              • Geometry attribute functions
              • Spatial processing functions
              • _ST_GeoHash
              • Overview of lock functions
              • RELEASE_ALL_LOCKS()
            • Bitmap functions
              • RoaringBitmap constructor
              • Bitmap cardinality calculation functions
              • Bitmap operation functions
              • Bitmap decision functions
              • Bitmap output functions
              • Bitmap aggregate functions
            • Array functions
              • Overview of array functions
              • Array constructor functions
              • Array decision functions
              • Array output functions
              • Array functions
            • Text processing functions
              • TOKENIZE
            • Audit functions
              • AUDIT_LOG_FILTER_SET_FILTER
              • AUDIT_LOG_FILTER_SET_USER
              • AUDIT_LOG_ENCRYPTION_PASSWORD_SET
              • AUDIT_LOG_ENCRYPTION_PASSWORD_GET
            • Map functions
              • Overview of mapping functions
              • Map constructors and operators
              • Map decision functions
              • Map operation functions
              • MATCH AGAINST
              • ISNAN
            • Join
            • Full-text search
            • Common table expressions
            • ALTER COMPILE
            • ALTER LOCATION
            • ALTER MATERIALIZED VIEW
            • ALTER MATERIALIZED VIEW LOG
            • ALTER SENSITIVE RULE
            • ALTER SYSTEM FLUSH SEQUENCE CACHE
            • VALIDATE
            • ALTER TABLESPACE
            • ALTER INSTANCE ROTATE INNODB MASTER KEY
            • ALTER EVENT
            • CACHE INDEX
            • CREATE CONCURRENT_LIMITING_RULE
            • CREATE EXTERNAL CATALOG
            • CREATE LOCATION
            • CREATE MATERIALIZED VIEW
            • CREATE FORMAT OUTLINE
            • CREATE RESTORE POINT
            • CREATE SENSITIVE RULE
            • CHECKSUM TABLE
            • CREATE EVENT
            • DROP CATALOG
            • DROP CONCURRENT_LIMITING_RULE
            • DROP EVENT
            • DROP LOCATION
            • DROP MATERIALIZED VIEW
            • DROP MATERIALIZED VIEW LOG
            • DROP SENSITIVE RULE
            • DROP RESTORE POINT
            • FLUSH TABLE
            • LOAD_FILE
            • LOAD INDEX INTO CACHE
            • REPAIR TABLE
              • WINDOW clause
              • HYBRID_SEARCH
            • SET CATALOG
            • SUBMIT JOB
            • SHOW JOB STATUS
            • CANCEL JOB
            • UNLOCK TABLES
            • XA transaction
            • Overview of DDL operations
            • Online DDL and offline DDL operations
            • NUMBER type conversion rules
            • PARTITIONID pseudo column
            • Sequence pseudo column
            • Overview of SQL Conditions
            • Condition priority
            • Pattern matching conditions
            • NULL values condition
            • JSON Member Conditions
            • Boolean test conditions
        • User tenants (Oracle-compatible mode)
            • Hierarchical query pseudo-columns
            • Sequence pseudo-column
            • ORA_ROWSCN pseudo-column
            • ROWNUM pseudo-column
            • ROWID pseudo-column
                • Overview of numeric data types
                • Numeric type priorities
                • Calculation of DATE and INTERVAL values
                • Overview of large object data types
                • LOB types
              • Rowid data type
                • Conversion rules for JSON data type
                • Overview of the XMLType data type
                • Conversion of the XMLType data type
                • Access SDO_GEOMETRY properties
              • Overview of data type comparison rules
              • Comparison rules of numeric values
              • Data type priority
              • Security considerations for data conversion in Oracle-compatible mode
                • DATE literals
                • TIMESTAMP literals
              • INTERVAL literals
              • Formatting models
              • RR date-time format element
              • Conversion rules from string to date
              • Overview of empty values
              • Null values in SQL functions
              • NULL values in comparison conditions
              • NULL values in conditional expressions
              • Comments on SQL statements
              • Comment on schema and nonschema objects
                • Overview of hints
                • Control query optimization by using Query Block Name and QB_NAME Hint
                  • Global hints
                    • Optimizer Stats Hint under Global Hints
                    • Transform Hint in Global Hints
                    • Other hints under the global hint type
                  • Optimized hints
                    • Join Order Hints
                    • DISTINCT hint
                    • Set Hint
                    • Distributed DML hint in the Optimized Hint category
                  • Transform hints
                    • Stmt Transform Hint in the Transform Hint Type
                    • Cost based transform hints
                    • Other TRANSFORM Hint
              • Overview of database object naming conventions
              • Schema object naming recommendations
              • Overview of database object references
                • Create a database link
                • Database links
              • Reference attributes and methods of object types
            • Overview of operators
            • Function overview
                • MAX_PT
                • SUBSTRB
                • INSTRB
                • INSTRC
                • LENGTHB
                • LENGTHC
                • EXTRACT (datetime)
                • ROUND (date)
                • TO_CHAR (datetime)
                • TRUNC (date)
                • NEW_TIME
                • RAWTONHEX
                • TO_CHAR (character)
                • TO_CHAR (number)
                • TO_NCHAR (character)
                • TO_NCHAR (datetime)
                • TO_NCHAR (number)
                • TIMESTAMP_NVL
              • Large object functions
                • EMPTY_BLOB
                • EMPTY_CLOB
                  • XMLCONCAT
                  • XMLFOREST
                  • EXISTSNODE
                • Constructor functions
                • Format conversion functions
              • REGR_ (Linear Regression)
              • WINDOW_FUNNEL
              • GROUP_ID
              • GROUPING_ID
              • Analytic function description
              • ARG_MIN
              • ARG_MAX
              • CATALOG
              • OB_TRANSACTION_ID
            • Table functions
            • Audit functions
              • Overview of audit functions
            • Conditional expressions
            • CURSOR Expressions
            • Scalar Subquery Expression
            • Overview of SQL conditions
            • Null conditions
            • Simple query
            • Hierarchical queries
            • Composite queries
            • Join queries
            • Query the DUAL table
              • ALTER LOCATION
              • ALTER SYSTEM ENABLE/DISABLE RESTRICTED SESSION
              • ALTER SYSTEM FLUSH CACHE
              • ALTER SYSTEM SET PARAMETER
              • VALIDATE
              • ALTER TABLESPACE
              • ALTER VIEW COMPILE
              • CREATE LOCATION
              • DROP LOCATION
                • Collection SELECT
                • WITH CLAUSE
                • APPLY clause
            • Operations on generated columns
        • SQL writing restrictions
          • SELECT statement writing specification
          • DML statement writing specifications
          • DDL statement writing specifications
          • Multi-table association specification
          • Table scanning mode specification
          • Transaction-related specifications
          • Cache usage specifications
          • Guidelines for using hints
          • Other specifications
          • Implicit type conversion
          • JOIN table usage suggestions
          • Pagination
      • Reserved keywords (MySQL-compatible mode)
      • Reserved keywords (Oracle-compatible mode)
      • Data type conversion behavior of a MySQL tenant in strict mode
        • PL overview
      • PL reference (MySQL-compatible mode)
        • PL syntax
          • Overview of PL stored programs
          • Manage stored routines and privileges
          • External storage functions
          • EVENT
          • Stored program usage restrictions
          • SQL Transpiler
          • PL asynchronous commit optimization
          • Server-side cursor usage limits
          • Scope of procedures
          • Overview of system packages
          • DBMS_AI_SERVICE
            • Overview of DBMS_AI_SERVICE
            • CREATE_AI_MODEL
            • DROP_AI_MODEL
            • CREATE_AI_MODEL_ENDPOINT
            • ALTER_AI_MODEL_ENDPOINT
            • DROP_AI_MODEL_ENDPOINT
          • DBMS_DAILY_MAINTENANCE
            • TRIGGER_WINDOW_COMPACTION_PROC
            • SET_THREAD_COUNT
          • DBMS_HYBRID_SEARCH
            • Overview of DBMS_HYBRID_SEARCH
            • SEARCH
            • GET_SQL
          • DBMS_MVIEW
            • Overview of DBMS_MVIEW
            • PURGE_LOG
            • KILL_REFRESH
            • REFRESH_REPORT
            • SET_REFRESH_PARAMS
            • EXPLAIN_REFRESH
          • DBMS_MVIEW_STATS
            • Overview of DBMS_MVIEW_STATS
            • PURGE_REFRESH_STATS
            • SET_MVREF_STATS_PARAMS
            • SET_SYSTEM_DEFAULT
          • DBMS_PARTITION
            • MANAGE_DYNAMIC_PARTITION
            • COPY_PLAN
            • System Packages
            • Overview of DBMS_STATS
            • DELETE_CATALOG_GLOBAL_PREFS
            • DELETE_CATALOG_TABLE_PREFS
            • GATHER_CATALOG_TABLE_STATS
            • GET_CATALOG_GLOBAL_PREFS
            • GET_CATALOG_PREFS
            • LOCK_CATALOG_PARTITION_STAT
            • LOCK_CATALOG_TABLE_STAT
            • SET_CATALOG_GLOBAL_PREFS
            • SET_CATALOG_TABLE_PREFS
            • UNLOCK_CATALOG_PARTITION_STAT
            • UNLOCK_CATALOG_TABLE_STAT
            • CANCEL_GATHER_STATS
            • GATHER_DATABASE_STATS_JOB_PROC
            • ADD_TRUSTED_CERTIFICATE
            • DELETE_TRUSTED_CERTIFICATE
            • UPDATE_TRUSTED_CERTIFICATE
          • DBMS_VECTOR
            • Overview of DBMS_VECTOR
            • REBUILD_INDEX
            • INDEX_VECTOR_MEMORY_ESTIMATE
            • INDEX_VECTOR_MEMORY_ADVISOR
            • FLUSH_INDEX
            • COMPACT_INDEX
            • INDEX_RECALL
            • QUERY_RECALL
            • Overview of DBMS_SESSION
            • Overview of DBMS_APPLICATION_INFO
          • DBMS_XPROFILE
            • Overview of DBMS_XPROFILE
            • DISPLAY_PROFILE
          • DBMS_BALANCE
            • SET_BALANCE_WEIGHT
            • CLEAR_BALANCE_WEIGHT
            • TRIGGER_PARTITION_BALANCE
            • SET_TABLEGROUP_BALANCE_WEIGHT
            • CLEAR_TABLEGROUP_BALANCE_WEIGHT
          • DBMS_LIMIT_CALCULATOR
          • DBMS_EXTERNAL_TABLE
            • Overview of DBMS_EXTERNAL_TABLE
            • AUTO_REFRESH_EXTERNAL_TABLE
          • DBMS_JAVA
            • Overview of DBMS_JAVA
            • LOADJAVA
            • DROPJAVA
          • DBMS_PYTHON
            • DROPPYTHON
            • LOADPYTHON
          • DBMS_DATA_DICT
            • DBMS_DATA_DICT
          • DBMS_SCHEMA
            • Overview of DBMS_SCHEMA
            • RECYCLE_SCHEMA_HISTORY
            • RUN_INSPECTION
        • PL reserved and non-reserved keywords
      • PL reference (Oracle-compatible mode)
          • Lexical elements
          • Syntax
          • Identifier scope and visibility
          • Assignment
          • Error reporting functions
          • Boolean data type
          • Sequence control
          • Collection constructors
          • Records
          • Insert and update tables with records
          • Create and invoke subprograms with record-type parameters
            • Cursor overview
            • Explicit cursor
            • Use FOR loops to traverse cursors
            • Modify and delete cursors
            • Call autonomous functions from SQL
          • FORALL and BULK COLLECT
          • Grant privileges
            • Overview of pipelined table functions
            • Create a pipeline function
            • Related applications
          • SQL Transpiler
          • Information collection for stored procedures and parallel execution of SQL statements
          • PL Database Link
          • External Stored Functions
          • Modify and drop triggers
          • Disable and enable a trigger
          • View trigger information
          • INSTEAD OF DML triggers
          • Composite DML triggers
          • System triggers
          • Create a package
          • Manage packages
          • Definition of the STANDARD package for PL
          • Compile-Time Warnings
          • Exception handling order
          • Overview of the PL Label Security package
            • Overview of the SA_COMPONENTS package
            • Overview of SA_SESSION
        • PL system package (Oracle-compatible mode)
            • Overview of DBMS_AUDIT_MGMT
            • CLEAR_LAST_ARCHIVE_TIMESTAMP
            • SET_PURGE_JOB_INTERVAL
          • DBMS_BALANCE
            • Overview of DBMS_BALANCE
            • Overview of DBMS_CRYPTO
            • Overview of DBMS_DAILY_MAINTENANCE
            • SET_THREAD_COUNT
            • PING
            • SYNCHRONIZE
            • TARGET_PROGRAM_RUNNING
            • Overview of DBMS_LOB
            • CONVERTTOBLOB
            • Overview of DBMS_LOCK
            • RELEASE
            • Overview of DBMS_METADATA
            • GET_TABLE_INDEX_DDL
          • DBMS_MVIEW
            • PURGE_LOG
            • KILL_REFRESH
            • REFRESH_REPORT
            • EXPLAIN_REFRESH
            • Overview of DBMS_MONITOR
            • OB_SESSION_TRACE_ENABLE
            • OB_SESSION_TRACE_DISABLE
            • OB_CLIENT_ID_TRACE_ENABLE
            • OB_CLIENT_ID_TRACE_DISABLE
            • OB_MOD_ACT_TRACE_ENABLE
            • OB_MOD_ACT_TRACE_DISABLE
            • OB_TENANT_TRACE_ENABLE
            • OB_TENANT_TRACE_DISABLE
          • DBMS_MVIEW_STAT
            • Overview of DBMS_OUTPUT
            • Overview of DBMS_PLAN_CACHE
          • DBMS_PLSQL_CODE_COVERAGE
            • START_COVERAGE
            • STOP_COVERAGE
            • CREATE_COVERAGE_TABLES
          • 12580.dbms-preprocessor-oracle
            • DBMS_PREPROCESSOR overview
            • PRINT_POST_PROCESSED_SOURCE
            • GET_POST_PROCESSED_SOURCE
          • DBMS_PARTITION
            • DBMS_PARTITION overview
            • Overview of DBMS_RANDOM
          • DBMS_ERRLOG
            • Overview of DBMS_ERRLOG
            • CREATE_ERROR_LOG
          • DBMS_SYS_ERROR
            • Overview of DBMS_SYS_ERROR
            • RAISE_SYSTEM_ERROR
            • COPY_PLAN
          • DBMS_RLS
            • Overview of DBMS_RLS
            • ADD_POLICY
            • DROP_POLICY
            • ENABLE_POLICY
            • ALTER_POLICY
            • ADD_POLICY_CONTEXT / DROP_POLICY_CONTEXT
            • REFRESH_POLICY / REFRESH_GROUPED_POLICY
            • CREATE_POLICY_GROUP / DELETE_POLICY_GROUP
            • ADD_GROUPED_POLICY
            • DROP_GROUPED_POLICY
            • ENABLE_GROUPED_POLICY / DISABLE_GROUPED_POLICY
            • ALTER_GROUPED_POLICY
            • Overview of DBMS_SCHEDULER
            • CREATE_JOB_CLASS
            • DROP_JOB_CLASS
            • PURGE_LOG
            • STOP_JOB
          • DBMS_SCHEMA
            • RUN_INSPECTION
            • SESSION_IS_ROLE_ENABLED
            • IS_ROLE_ENABLED
            • Overview of DBMS_SQL
            • BIND_VARIABLE_CHAR
            • BIND_VARIABLE_RAW
            • COLUMN_VALUE_CHAR
            • COLUMN_VALUE_RAW
            • DEFINE_COLUMN_CHAR
            • DEFINE_COLUMN_RAW
            • DESCRIBE_COLUMNS2
            • DESCRIBE_COLUMNS3
            • VARIABLE_VALUE
            • VARIABLE_VALUE_CHAR
            • VARIABLE_VALUE_RAW
            • TO_CURSOR_NUMBER
            • TO_REFCURSOR
            • DBMS_UDR overview
            • Overview of DBMS_UTILITY
            • EXEC_DDL_STATEMENT
            • COMMA_TO_TABLE
            • CANONICALIZE
            • VALIDATE
            • Overview of DBMS_WORKLOAD_REPOSITORY
            • ASH_REPORT_TEXT
            • DBMS_XA overview
            • Constants of DBMS_XA
            • Overview of the DBMS_XMLGEN package
          • DBMS_PROFILER
            • Overview of DBMS_PROFILER
            • START_PROFILER
            • STOP_PROFILER
            • PAUSE_PROFILER
            • RESUME_PROFILER
            • FLUSH_DATA
            • GET_VERSION
            • INTERNAL_VERSION_CHECK
            • ROLLUP_UNIT
            • ROLLUP_RUN
            • OB_INIT_OBJECTS
            • OB_DROP_OBJECTS
            • Overview of DBMS_XPLAN
          • DBMS_XPROFILE
            • DISPLAY_PROFILE
          • DBMS_DDL
            • Overview of DBMS_DDL
            • WRAP
            • CREATE_WRAPPED
          • 21500.dbms-data-dict-oracle
            • DBMS_DATA_DICT
            • Overview of ODCIConst
            • Overview of UTL_ENCODE
            • MIMEHEADER_DECODE
            • MIMEHEADER_ENCODE
            • QUOTED_PRINTABLE_DECODE
            • QUOTED_PRINTABLE_ENCODE
            • TEXT_DECODE
            • TEXT_ENCODE
            • UUDECODE
            • UUENCODE
            • Overview of UTL_FILE
            • FCOPY
            • FCLOSE_ALL
            • FOPEN_NCHAR
            • FGETATTR
            • NEW_LINE_NCHAR
            • GET_LINE_NCHAR
            • GET_RAW
            • PUT_RAW
            • PUT_NCHAR
            • PUT_LINE_NCHAR
            • PUTF
            • PUTF_NCHAR
            • Overview of UTL_I18N
          • UTL_RECOMP
            • Overview of UTL_RECOMP
            • RECOMP_PARALLEL
            • RECOMP_SERIAL
            • PARALLEL_SLAVE
            • Overview of UTL_RAW
            • CAST_TO_NVARCHAR2
          • UTL_TCP
            • Overview of UTL_TCP
            • OPEN_CONNECTION
            • CLOSE_CONNECTION
            • CLOSE_ALL_CONNECTIONS
            • WRITE_LINE
            • WRITE_TEXT
            • WRITE_RAW
            • GET_TEXT
          • UTL_SMTP
            • Overview of UTL_SMTP
            • OPEN_CONNECTION
            • CLOSE_CONNECTION
            • QUIT
            • AUTH
            • COMMAND
            • COMMAND_REPLIES
            • HELO
            • EHLO
            • MAIL
            • RCPT
            • OPEN_DATA
            • WRITE_DATA
            • WRITE_RAW_DATA
            • CLOSE_DATA
            • DATA
            • VRFY
            • NOOP
            • RSET
          • UTL_HTTP
            • Overview of UTL_HTTP
            • BEGIN_REQUEST
            • END_REQUEST
            • GET_RESPONSE
            • END_RESPONSE
            • READ_LINE
            • READ_RAW
            • READ_TEXT
            • WRITE_LINE
            • WRITE_RAW
            • WRITE_TEXT
            • SET_TRANSFER_TIMEOUT
            • GET_TRANSFER_TIMEOUT
            • Overview of the ANYDATA type
            • BEGINCREATE static stored procedure
            • ENDCREATE member stored procedure
            • GET* member function
            • PIECEWISE member stored procedure
            • SET* member stored procedure
            • ACCESS* member functions
            • CONVERT* static functions
            • EXISTSNODE
        • PL reserved keywords
      • View changes in V3.x and V4.x
          • information_schema.events
          • information_schema.TRIGGERS
          • oceanbase.CDB_CKPT_HISTORY
          • oceanbase.CBA_SCHEDULER_RUNNING_JOBS
          • oceanbase.CDB_SCHEDULER_JOBS
          • CDB_INDEX_USAGE
          • oceanbase.CDB_MVIEW_DEPS
          • CDB_MVIEW_LOGS
          • oceanbase.CDB_MVIEW_RUNNING_JOBS
          • CDB_MVIEWS
          • CDB_MVREF_CHANGE_STATS
          • CDB_MVREF_RUN_STATS
          • CDB_MVREF_STATS
          • CDB_MVREF_STATS_PARAMS
          • CDB_MVREF_STMT_STATS
          • oceanbase.CDB_OB_AI_MODEL_ENDPOINTS
          • oceanbase.CDB_OB_AI_MODELS
          • oceanbase.CDB_OB_BACKUP_VALIDATE_JOBS
          • oceanbase.CDB_OB_BACKUP_VALIDATE_JOB_HISTORY
          • oceanbase.CDB_OB_BACKUP_VALIDATE_TASKS
          • oceanbase.CDB_OB_BACKUP_VALIDATE_TASK_HISTORY
          • oceanbase.CDB_OB_CCL_RULES
          • oceanbase.CDB_OB_CS_REPLICA_STATS
          • oceanbase.CDB_OB_DYNAMIC_PARTITION_TABLES
          • oceanbase.CDB_OB_LOB_CHECK_EXCEPTION_RESULT
          • oceanbase.CDB_OB_LOB_CHECK_TASKS
          • oceanbase.CDB_OB_LS_REPLICA_TASK_HISTORY
          • oceanbase.CDB_OB_OBJECT_BALANCE_WEIGHT
          • oceanbase.CDB_OB_SERVICES
          • oceanbase.CDB_OB_RSRC_DIRECTIVES
          • oceanbase.CDB_OB_SENSITIVE_COLUMNS
          • oceanbase.CDB_OB_SENSITIVE_RULE_PLAINACCESS_USERS
          • oceanbase.CDB_OB_SENSITIVE_RULES
          • oceanbase.CDB_OB_SERVER_SPACE_USAGE
          • oceanbase.CDB_OB_SPACE_USAGE
          • oceanbase.CDB_OB_SYS_VARIABLE_HISTORY
          • oceanbase.CDB_OB_STORAGE_IO_USAGE
          • oceanbase.CDB_OB_SPM_EVO_RESULT
          • oceanbase.CDB_OB_TABLE_SPACE_USAGE
          • oceanbase.CDB_OB_TEMP_FILES
          • oceanbase.CDB_OB_TENANT_FLASHBACK_LOG_SCN
          • oceanbase.CDB_OB_TTL_TASKS
          • oceanbase.CDB_OB_TTL_TASK_HISTORY
          • oceanbase.CDB_OB_VECTOR_INDEX_TASKS
          • oceanbase.CDB_OB_VECTOR_INDEX_TASK_HISTORY
          • oceanbase.CDB_WR_RES_MGR_SYSSTAT
          • oceanbase.CDB_WR_SQL_PLAN
          • oceanbase.CDB_OB_EXTERNAL_RESOURCES
          • oceanbase.DBA_INDEX_USAGE
          • oceanbase.DBA_MVIEW_DEPS
          • oceanbase.DBA_MVIEW_LOGS
          • oceanbase.DBA_MVIEW_RUNNING_JOBS
          • oceanbase.DBA_MVIEWS
          • DBA_MVREF_CHANGE_STATS
          • oceanbase.DBA_MVREF_RUN_STATS
          • oceanbase.DBA_MVREF_STATS
          • DBA_MVREF_STATS_PARAMS
          • DBA_MVREF_STMT_STATS
          • oceanbase.DBA_OB_AI_MODEL_ENDPOINTS
          • oceanbase.DBA_OB_AI_MODELS
          • oceanbase.DBA_OB_BACKUP_VALIDATE_JOBS
          • oceanbase.DBA_OB_BACKUP_VALIDATE_JOB_HISTORY
          • oceanbase.DBA_OB_BACKUP_VALIDATE_TASKS
          • oceanbase.DBA_OB_BACKUP_VALIDATE_TASK_HISTORY
          • oceanbase.DBA_OB_CCL_RULES
          • oceanbase.DBA_OB_CS_REPLICA_STATS
          • oceanbase.DBA_OB_DYNAMIC_PARTITION_TABLES
          • oceanbase.DBA_OB_EXTERNAL_PART_COL_STATISTICS
          • oceanbase.DBA_OB_EXTERNAL_TAB_COL_STATISTICS
          • oceanbase.DBA_OB_EXTERNAL_TAB_STATISTICS
          • oceanbase.DBA_OB_EXTERNAL_RESOURCES
          • DBA_OB_FORMAT_OUTLINES
          • oceanbase.DBA_OB_LOB_CHECK_EXCEPTION_RESULT
          • oceanbase.DBA_OB_LOB_CHECK_TASKS
          • oceanbase.DBA_OB_SERVICES
          • oceanbase.DBA_OB_RSRC_DIRECTIVES
          • oceanbase.DBA_SCHEDULER_RUNNING_JOBS
          • oceanbase.DBA_OB_STORAGE_IO_USAGE
          • oceanbase.DBA_OB_SPM_EVO_RESULT
          • oceanbase.DBA_OB_SYS_VARIABLE_HISTORY
          • oceanbase.DBA_OB_TEMP_FILES
          • oceanbase.DBA_OB_TENANT_FLASHBACK_LOG_SCN
          • oceanbase.DBA_OB_TTL_TASKS
          • oceanbase.DBA_OB_TTL_TASK_HISTORY
          • oceanbase.DBA_OB_VECTOR_INDEX_TASKS
          • oceanbase.DBA_OB_VECTOR_INDEX_TASK_HISTORY
          • oceanbase.DBA_RECYCLEBIN
          • oceanbase.DBA_TABLES
          • oceanbase.DBA_WR_RES_MGR_SYSSTAT
          • oceanbase.DBA_WR_SQL_PLAN
          • oceanbase.V$OB_KEYWORDS
          • GV$OB_CGROUP_CONFIG
          • GV$OB_EXTERNAL_CATALOG_CLIENT_POOL_STAT
          • GV$OB_FUNCTION_IO_STAT
          • GV$OB_GROUP_IO_STAT
          • GV$OB_HMS_CLIENT_POOL_STAT
          • GV$OB_HNSW_INDEX_INFO
          • GV$OB_HNSW_INDEX_SEGMENT_INFO
          • GV$OB_IVF_INDEX_INFO
          • GV$OB_KV_CONNECTIONS
          • GV$OB_LS_SNAPSHOTS
          • GV$OB_NIC_INFO
          • GV$OB_PLUGINS
          • GV$OB_RES_MGR_SYSSTAT
          • GV$OB_SESSION_PS_INFO
          • GV$OB_SHARED_STORAGE_QUOTA
          • GV$OB_SINDI_INDEX_INFO
          • GV$OB_SQL_CCL_STATUS
          • GV$OB_TABLET_REPLICA_INFO
          • GV$OB_TENANT_RESOURCE_LIMIT
          • GV$OB_TENANT_WORKER_GROUPS
          • GV$OB_VECTOR_MEMORY
          • gv$tenant
          • GV$OB_KV_CLIENT_INFO
          • GV$UNIT
          • V$OB_COMPATIBILITY_CONTROL
          • V$OB_CGROUP_CONFIG
          • V$OB_DYNAMIC_PARTITION_TABLES
          • V$OB_EXTERNAL_CATALOG_CLIENT_POOL_STAT
          • V$OB_FUNCTION_IO_STAT
          • V$OB_GROUP_IO_STAT
          • V$OB_HMS_CLIENT_POOL_STAT
          • V$OB_HNSW_INDEX_INFO
          • V$OB_HNSW_INDEX_SEGMENT_INFO
          • V$OB_IVF_INDEX_INFO
          • V$OB_KV_CLIENT_INFO
          • V$OB_KV_GROUP_COMMIT_STATUS
          • V$OB_KV_CONNECTIONS
          • V$OB_LS_SNAPSHOTS
          • V$OB_NIC_INFO
          • V$OB_PLUGINS
          • V$OB_RES_MGR_SYSSTAT
          • V$OB_SESSION_PS_INFO
          • V$OB_SHARED_STORAGE_QUOTA
          • V$OB_SINDI_INDEX_INFO
          • V$OB_SQL_CCL_STATUS
          • V$OB_TABLET_REPLICA_INFO
          • V$OB_TENANT_RESOURCE_LIMIT
          • V$OB_TRANSACTION_SCHEDULERS
          • V$RESTORE_POINT
          • V$OB_VECTOR_MEMORY
          • V$UNIT
          • mysql.audit_log_filter
          • mysql.audit_log_user
          • oceanbase.DBA_JAVA_POLICY
          • oceanbase.DBA_OB_OBJECT_BALANCE_WEIGHT
          • oceanbase.DBA_OB_SENSITIVE_COLUMNS
          • oceanbase.DBA_OB_SENSITIVE_RULE_PLAINACCESS_USERS
          • oceanbase.DBA_OB_SENSITIVE_RULES
          • oceanbase.DBA_OB_TABLE_SPACE_USAGE
          • oceanbase.USER_JAVA_POLICY
          • GV$OB_HNWS_INDEX_INFO
          • GV$OB_NIC_INFO
          • V$OB_HNWS_INDEX_INFO
          • V$OB_KEYWORDS
          • V$OB_LS_SNAPSHOTS
          • V$OB_NIC_INFO
          • V$RESTORE_POINT
          • ALL_LOCATIONS
          • ALL_MVIEW_LOGS
          • ALL_MVIEWS
          • ALL_OB_SOURCE
          • ALL_PLSQL_TYPES
          • ALL_PLSQL_COLL_TYPES
          • ALL_PLSQL_TYPE_ATTRS
          • DBA_INDEX_USAGE
          • DBA_JAVA_POLICY
          • DBA_MVIEW_DEPS
          • DBA_MVIEW_LOGS
          • DBA_MVIEW_RUNNING_JOBS
          • DBA_MVIEWS
          • DBA_MVREF_RUN_STATS
          • DBA_MVREF_STATS
          • DBA_OB_BACKUP_VALIDATE_JOBS
          • DBA_OB_BACKUP_VALIDATE_JOB_HISTORY
          • DBA_OB_BACKUP_VALIDATE_TASKS
          • DBA_OB_BACKUP_VALIDATE_TASK_HISTORY
          • DBA_OB_CS_REPLICA_STATS
          • DBA_OB_CCL_RULES
          • DBA_OB_DYNAMIC_PARTITION_TABLES
          • DBA_OB_LOB_CHECK_EXCEPTION_RESULT
          • DBA_OB_LOB_CHECK_TASKS
          • DBA_OB_SENSITIVE_COLUMNS
          • DBA_OB_SENSITIVE_RULE_PLAINACCESS_USERS
          • DBA_OB_SENSITIVE_RULES
          • DBA_OB_SERVICES
          • DBA_OB_OBJECT_BALANCE_WEIGHT
          • DBA_OB_PL_OBJ_CACHE_STATUS
          • DBA_OB_RSRC_DIRECTIVES
          • DBA_OB_SPATIAL_COLUMNS
          • DBA_OB_STORAGE_IO_USAGE
          • DBA_OB_SYS_VARIABLES
          • DBA_OB_SYS_VARIABLE_HISTORY
          • DBA_OB_SOURCE
          • DBA_OB_SPM_EVO_RESULT
          • DBA_OB_TENANT_FLASHBACK_LOG_SCN
          • DBA_OB_TEMP_FILES
          • DBA_PLSQL_TYPES
          • DBA_PLSQL_COLL_TYPES
          • DBA_PLSQL_TYPE_ATTRS
          • DBA_OB_TTL_TASKS
          • DBA_OB_TTL_TASK_HISTORY
          • DBA_SCHEDULER_RUNNING_JOBS
          • DBA_OB_TABLE_SPACE_USAGE
          • DBA_WR_RES_MGR_SYSSTAT
          • DBA_WR_SQL_PLAN
          • PROXY_USERS
          • USER_PLSQL_TYPES
          • USER_JAVA_POLICY
          • USER_PLSQL_COLL_TYPES
          • USER_PLSQL_TYPE_ATTRS
          • USER_MVIEW_LOGS
          • USER_MVIEWS
          • USER_MVREF_CHANGE_STATS
          • USER_MVREF_RUN_STATS
          • USER_MVREF_STATS
          • USER_MVREF_STATS_PARAMS
          • USER_MVREF_STMT_STATS
          • USER_OB_SOURCE
          • V$OB_KEYWORDS
          • GV$OB_NIC_INFO
          • GV$OB_RESULT_CACHE_OBJECTS
          • V$OB_KEYWORDS
          • V$OB_LS_SNAPSHOTS
          • V$OB_NIC_INFO
          • V$OB_RESULT_CACHE_OBJECTS
          • V$RESTORE_POINT
      • Overview of metrics
      • Common wait events
      • Overview of configuration parameters and system variables
      • Parameter and system variable changes between V3.x and V4.x
        • Overview of parameters
          • alert_log_level
          • async_ps_cursor_max_count
          • system_protected_sys_variables
          • system-protected-tenant-parameters
          • clog_io_isolation_mode
          • enable_ob_error_msg_style
          • external_table_disk_cache_max_percentage
          • global_background_cpu_quota
          • io_scheduler_thread_count
          • log_storage_warning_trigger_percentage
          • ob_java_connector_path
          • ob_python_home
          • ob_enable_java_env
          • ob_enable_utl_tcp
          • ob_java_home
          • ob_java_opts
          • ob_enable_utl_http
          • plugins_load
          • sync_io_thread_count
          • kv_transport_compress_func
          • unit_gc_wait_time
          • utl_file_open_max
          • approx_count_distinct_precision
          • audit_log_buffer_size
          • audit_log_compression
          • audit_log_enable
          • audit_log_encryption
          • audit_log_format
          • audit_log_max_size
          • audit_log_path
          • audit_log_prune_seconds
          • audit_log_query_sql
          • audit_log_rotate_on_size
          • audit_log_strategy
          • auto_split_tablet_size
          • default_delta_format
          • default_load_mode
          • default_micro_block_format_version
          • default_skip_index_level
          • default_table_merge_engine
          • default_table_organization
          • default_table_store_format
          • direct_load_allow_fallback
          • ddl_high_thread_score
          • document_ai_file_max_size
          • enable_adaptive_plan_cache
          • enable_auto_split
          • enable_database_sharding_none
          • enable_hbase_rowkey_ttl
          • enable_pl_rich_error_msg
          • enable_gts_standalone
          • enable_kv_group_commit
          • enable_lock_priority
          • enable_mlog_auto_maintenance
          • enable_mv_binlog_minimal_mode
          • enable_ls_leader_balance
          • enable_ttl
          • enable_window_compaction
          • enable_ps_parameterize
          • external_table_io_hole_size
          • external_table_io_range_size
          • external_table_csv_max_buffer_size
          • ob_vector_search_strategy
          • function_round_dialect
          • global_index_auto_split_policy
          • json_document_max_depth
          • kv_group_commit_batch_size
          • kv_group_commit_rw_mode
          • kv_hbase_client_scanner_timeout_period
          • kv_ttl_delete_max_ops
          • kv_transport_compress_threshold
          • load_data_diagnosis_log_compression
          • load_data_diagnosis_log_max_size
          • load_vector_index_on_follower
          • ls_scale_out_factor
          • mds_compaction_high_thread_score
          • mds_compaction_mid_thread_score
          • mds_minor_compact_trigger
          • mlog_trim_interval
          • model_max_retries
          • model_request_timeout
          • mv_refresh_concurrency
          • ob_encoding_granularity
          • ob_enable_java_udf
          • ob_enable_python_udf
          • ob_vector_index_active_segment_max_size
          • ob_vector_index_merge_trigger_percentage
          • ob_vector_memory_limit_percentage
          • px_node_policy
          • package_state_sync_max_size
          • px_target_high_watermark
          • px_target_low_watermark
          • px_target_workers_per_cpu
          • recover_table_concurrency
          • recover_table_dop
          • result_cache_max_size
          • result_cache_max_result
          • rest_oauth2_credential_refresh_interval
          • rest_oauth2_credential_evict_time
          • ob_result_cache_evict_percentage
          • schema_history_archive_expire_time
          • spill_compression_codec
          • sql_func_extension_mode
          • sts_credential
          • storage_rowsets_size
          • ttl_duty_time
          • vector_index_memory_saving_mode
          • vector_index_optimize_duty_time
          • zone_deploy_mode
          • zone_disk_balance_tolerance_percentage
          • ap_query_cost_threshold
          • ap_query_route_policy
          • ap_query_replica_fallback
          • caching_sha2_password_digest_rounds
          • default_authentication_plugin
          • ENABLE_OPTIMIZER_ROWGOAL
          • innodb_stats_persistent
          • long_query_time
          • max_execution_time
          • mview_refresh_dop
          • ob_compatibility_control
          • ob_compatibility_version
          • ob_enable_ps_parameter_anonymous_block
          • ob_enable_pl_async_commit
          • ob_table_access_policy
          • ob_udf_cost_factor
          • ob_udf_selectivity
          • ob_security_version
          • plsql_ccflags
          • pid_file
          • plsql_can_transform_sql_to_assign
          • port
          • query_rewrite_enabled
          • query_rewrite_integrity
          • socket
          • SQL_TRANSPILER
          • enable_sql_plan_monitor
          • ob_hnsw_ef_search
          • ob_ivf_nprobes
          • ob_sparse_drop_ratio_search
      • MySQL-compatible mode
        • 0001 ~ 3999
        • 4000 ~ 4499
        • 9000 ~ 9499
        • 10000 ~ 12000
      • Oracle-compatible mode
        • OBE-00000 to OBE-00999
        • OBE-01000 to OBE-01499
        • OBE-01500 to OBE-01999
        • OBE-02000 to OBE-04999
        • OBE-05000 to OBE-10000
        • OBE-10000 to OBE-19999
        • OBE-20000 to OBE-29999
        • OBE-30000 to OBE-49999
        • OBE-50000 to OBE-99999
          • Generate an ASH report
          • Analyze an ASH report
          • 500.execution-plan-operator
          • Parallel DDL
        • Parallel execution plans
          • Set concurrent execution
              • Asynchronous statistics collection
            • OceanBase statistics management practical guide
            • Rule-based query rewrite
            • Optimizer hint
            • SPM plan management
        • obshell
          • Use cases
            • obshell management
              • Start or stop obshell
              • Upgrade obshell
            • cluster management
              • Deploy an OceanBase cluster
              • Deploy ODP
              • Initiate a cluster-level backup
              • Initiate a tenant-level backup
              • Initiate tenant-level restore
              • Expand a tenant
          • obshell commands
            • Agent commands of obshell
            • Cluster commands of obshell
            • obshell unit commands
            • obshell resource pool commands
            • Tenant command group of obshell
            • Task commands of obshell
            • Backup commands in obshell
            • obshell restore command group
            • obshell recyclebin command group
          • obshell Dashboard
              • Session management
            • Performance monitoring
            • Manage inspection services
            • Manage credentials
            • obshell API requests
              • Set node password
              • Initialize Cluster
              • Upgrade OceanBase Database
              • Scale out a cluster
              • GetObInfo
            • ODP management
              • Deploy ODP
              • Start ODP
              • Stop ODP
              • Upload an ODP installation package
              • Upgrade ODP
              • Destroy ODP
            • Unit config management
              • Create a resource specification
              • Retrieve all resource specifications
              • Query the information of a specified resource specification
              • Delete a resource specification
            • Resource pool management
              • Get information about all resource pools
              • Delete a specified resource pool
              • Query tenant information
              • Change the tenant password
              • Modify the access whitelist of a tenant
              • Modify the primary zone of a tenant
              • Modify tenant system variables
              • Modify tenant configurations
              • Add a tenant replica
              • Modify a tenant replica
              • Delete a tenant replica
              • Get an overview of all tenants
              • Query a system variable of a specified tenant
              • Fuzzy query tenant system variables
              • Query a tenant parameter
              • Fuzzy query tenant parameters
              • Query the session list of a tenant
              • Get tenant session details
              • Obtain tenant session statistics
              • Terminate a tenant session query
              • Query tenant deadlock history
            • Backup management
              • Set the backup configuration for a tenant
              • Set cluster-level backup configurations
              • Update the backup configuration of a tenant
              • Update the cluster-level backup configuration
              • Initiate a backup for a single tenant
              • View information about a backup task for a tenant
              • View cluster-level backup tasks
              • Modify the backup status of a tenant
              • Modify the status of cluster-level backups
              • Modify the log archiving status of a tenant
              • Modify the log archiving status of a cluster
            • Restore management
              • Initiate tenant restore
              • View tenant recovery
              • Cancel tenant restore
            • Inspection service management
              • Trigger an inspection
              • Query inspection history
              • Obtain an inspection report
            • Recycle bin management
              • Query all tenant information in the recycle bin
              • Restore a tenant from the recycle bin
              • Clear a tenant from the recycle bin
            • Credential management
              • Create credentials
              • Obtain credentials
              • Update credentials
              • Delete a credential
              • Batch delete credentials
              • Query the credential list
              • Verify credentials
              • Batch verify credentials
              • Update the credential encryption key
            • Other APIs
          • SDK references
                • Upgrade agents
                • Set node password
                • Query the status of a node
                • Initialize a cluster
                • Start a cluster
              • ODP management
                • Deploy ODP
                • Start ODP
                • Stop ODP
                • Upgrade ODP
                • Destroy ODP
                • Obtain information about all resource specifications
                • Query information about a specified resource unit
                • Delete a resource pool
                • Change the password of a tenant
                • Modify tenant parameters
                • Query the overview of all tenants
                • Query tenant system variables
                • Query tenant configuration items
              • Backup management
                • Configure the backup settings for a tenant
                • Configure cluster-level backup settings
                • Update cluster-level backup configuration
                • View a backup task of a tenant
                • View cluster-level tenant backup tasks
                • Change the log archiving status of a tenant
                • Restore a single tenant
                • Cancel tenant restoration
                • Get information about all tenants in the recycle bin
                • Purge a tenant from the recycle bin
                • Operate a task
                • Query all unfinished tasks
              • Other APIs
                • Upload an RPM package
            • GO
              • Quick Start with obshell-sdk-go
                • Upgrade agents
                • Start a cluster
                • Query all resource specifications
                • Query the specifications of a specified resource
                • Drop a resource unit configuration
                • Change a tenant password
                • Modify the tenant access whitelist
              • Backup management
                • Set the cluster-level backup configuration
                • Update the backup configuration for a tenant
                • View a backup task for a tenant
                • Modify the status of a cluster-level backup
                • Modify the status of cluster-level log archiving
                • Initiate a restore for a single tenant
                • Purge tenants from the recycle bin
                • Operate a task
              • Other APIs
          • Release notes
            • V4.4
              • OceanBase Shell V4.4.0.0 for local clusters
              • OceanBase Shell V4.3.2.1
              • OceanBase Shell V4.3.2.0
              • OceanBase Shell V4.3.1.0 for local clusters
        • obd
            • test_io_device
            • io_adapter_benchmark
        • sql_diagnoser
          • Install and use SQL diagnoser sql_diagnoser
            • Install sql_diagnoser
            • Use sql_diagnoser
          • sql_diagnoser parameters
            • API operations
      • Log analysis
        • oblogminer
          • Install oblogminer
        • obloader and obdumper
        • oblogproxy
            • Sample configuration file
            • General obcdc parameters
          • Throttling
      • Stress testing tools
    • OceanBase plugin
      • Overview of OceanBase plugin
      • Tokenizer plugin
      • MySQL external table plugin
    • Products
    • SQL FAQ
    • Deployment FAQ
    • FAQ about columnstores
    • Version number guidelines
    • Release history of OceanBase Database Enterprise Edition
    • Release notes of OceanBase Database Community Edition
      • V4.6
        • OceanBase Database Enterprise Edition V4.6.0
      • V4.5
        • OceanBase Database Enterprise Edition V4.5.0
      • V4.4
        • OceanBase Database Enterprise Edition V4.4.2
        • OceanBase Database Enterprise Edition V4.3.5
        • OceanBase Database Enterprise Edition V4.3.1
      • V4.5
        • OceanBase Database Community Edition V4.5.0
      • V4.4
        • OceanBase Database Community Edition V4.4.2
        • OceanBase Database Community Edition V4.3.5
  4. V5.0.1
Last Updated:2026-09-04 11:28:24
Privilege requirements
Attributes
Examples
For V3.2.1, this parameter is available starting with V3.2.1.
connection_control_max_connection_delay specifies the maximum lock duration after the number of failed login attempts exceeds the threshold.
Applicability
This parameter applies only to OceanBase Database in MySQL-compatible mode.
  • Query the parameter
    The sys tenant and all user tenants can query this parameter by using the SHOW PARAMETERS statement or the GV$OB_PARAMETERS view.
  • Modify the parameter
    The sys tenant and user tenants can modify this parameter.
Attributes
Type Int
Default value 2147483647 milliseconds
Modifiable Yes. You can use the ALTER SYSTEM SET statement to modify the parameter.
Effective upon OBServer node restart No. The setting takes effect immediately.
Examples
Set the maximum lock duration after the number of failed login attempts exceeds the threshold to 2147483647 milliseconds.
obclient> ALTER SYSTEM SET connection_control_max_connection_delay = 2147483647;
Identity authentication
connection_control_failed_connections_threshold
Attributes
Examples
