SQL - V5.0.1
    • Feature differences between Enterprise Edition and Community Edition
      • Overview of Oracle compatibility
    • Deploy OceanBase
    • Experience high-concurrency OLTP scenarios
    • Experience HTAP mixed-workload scenarios
    • Experience AI scenarios
    • Experience multi-tenancy and resource isolation
    • Experience high availability and failover
    • Experience horizontal scaling and elastic scaling
    • Experience parallel import and high compression
    • Experience data protection and recovery
    • Experience online DDL
    • Develop applications (MySQL-compatible mode)
        • Overview of connection methods
          • JDBC
          • Spring JDBC
          • MyBatis sample application for connecting to OceanBase Database
          • Connector/J
          • TestContainers
          • MySQL-connector-python
          • MySQL Connector/C
        • NET
          • Connect to an OceanBase database by using OceanBase Connector/NET
        • PHP
          • EXT
          • MySQLi
          • PDO
        • Rust
          • Connect to OceanBase Database by using Rust
          • Connect to OceanBase Database by using SeaORM
          • Lock query results with SELECT FOR UPDATE
          • Use regular expressions in queries
    • Develop applications (Oracle-compatible mode)
        • NET
          • Connect to OceanBase Database using OceanBase Connector/NET
        • Configure servers
      • Deploy OceanBase Database Java SDK
        • Deploy OceanBase Database in a container
      • Deploy OceanBase Desktop
    • Clear an OceanBase cluster
    • Recommended configurations
  • OceanBase version upgrade
      • Check the status after the upgrade
      • Upgrade OceanBase Database with obd
      • Export data using the OUTFILE statement
    • Overview of direct load
        • Add nodes
        • Reset cluster parameters
          • Overview of Resource Isolation
          • Manage resource isolation (Oracle-compatible mode)
            • Configure cgroup
          • Manage resource isolation (MySQL-compatible mode)
            • Configure cgroup
            • Update resource management plan directive
          • Resource isolation configuration examples for background tasks
        • View tenant system variables
          • Tenant pre-scaling
          • Smooth scaling application scenarios
          • Merge and split a resource pool
          • Modify a unit config
          • Drop a unit config
        • Manage services
          • Create a service
          • Query the service status
          • Start a service
          • Stop a service
    • Manage log streams
      • Create a log stream
      • Modify a log stream
      • Replicas
          • Remove replicas
          • Replica migration
          • Cancel a replica task
      • Overview of data load balancing
      • Transfer Partition
      • Cancel a Balance Job
      • Suspend or resume a balance job
      • Table group weight management
        • Aggregation of user tables in a database
        • Set table group weights
        • Clear table group weights
        • Application scenarios of table group weight balancing
      • Balance weight management
        • Set partition weights
        • Clear partition weights
      • Partition balance management
        • Configure a scheduled partition balancing task
        • Manually trigger partition balancing
        • View the configurations of the scheduled partition balancing task
        • View the triggering history of the scheduled partition balancing task
        • View the partition balancing task in the background
        • View the history of partition balancing tasks in the background
      • GTS standalone application scenario
            • Set a log restore source
          • Specify log compression
        • Enable arbitration service for a tenant
        • MySQL-compatible mode
          • Login failure processing
          • Dual-password management
          • Configure caching_sha2_password for the entire connection chain
        • Oracle-compatible mode
          • Password Rotation
            • Privilege types in MySQL-compatible mode
            • Role management
              • Grant privileges to a role
            • Privilege types in Oracle-compatible mode
            • Use a proxy user
      • Data encryption
          • Transport encryption for OBServer
        • Tenant master key management
          • Generate a tenant master key (MySQL-compatible mode)
          • Generate a tenant master key (Oracle-compatible mode)
            • Enable TDE for new tables
            • Enable transparent data encryption for an existing table
        • Column encryption
          • Overview of column encryption
            • Create a column encryption rule
            • Manage column encryption privileges
            • Column encryption permissions
          • FAQ about column encryption
        • Security audit overview
        • Security audit in MySQL-compatible mode
          • Enable security auditing
          • Set an auditing rule
          • View auditing records
          • Disable security auditing
          • Appendix: Complete list of SQL types supported by general_sql_command
        • Security audit in Oracle-compatible mode
          • Manage audit logs
          • Audit user logins
        • Prepare for backup
        • Back up parameters
        • View parameters related to data backup
        • Modify the source-side backup path configuration
      • Update `access_id` and `access_key` information for the backup or archive path
        • Automatic backup cleanup
          • Automatically clean up expired backups
          • Delete a cleanup policy
        • Manual backup cleanup
          • Manually trigger the cleanup of expired backups
          • Manually clean up specified backup or archive data
          • Manually clear the backup path or archive path
        • Cancel a cleanup task
        • Query the backup cleanup results
      • Backup validation
        • Backup validation overview
        • Validate the entire backup path and archive path
        • Validate a specified backup set or log archive piece
        • Validate a backup set or log archive piece in a specified path
        • Cancel a backup validation task
        • View the backup verification progress
        • View the backup validation result
        • Prepare for restore
        • Perform physical restore
        • Overview of table-level restore
        • Preparations before table-level restore
        • Perform table-level restore
        • Schema recovery in table-level restore
        • Cancel table-level restore
        • Check the progress of table-level restore
        • Check the results of table-level restore
        • Parameters related to table-level restore
        • Views related to table-level restore
      • Backup and restore performance tuning
      • Example of configuring the source backup and archive paths
      • Appendix: S3 path format
          • Overview of system monitoring metrics
          • SYSSTAT metrics
      • Root service events
      • Log overview
      • Log interpretation
      • Alert logs
      • Check the resource usage status of a tenant
            • Large and small accounts
          • Join
              • Hash Join
              • Merge join
          • Schema specifications
      • BootStrap
        • Forced leader election
        • No leader
        • Transaction issues
        • Long-running transactions
        • Suspended transactions
        • Other issues
      • FAQ about manual operations on log streams
      • Materialized view exception diagnosis
      • Application exceptions -- error messages without OceanBase error codes
      • Application exceptions -- error messages with OceanBase error codes
      • Troubleshoot application disconnection issues
      • Troubleshoot merge exceptions
      • External table troubleshooting guide
          • SQL query exceptions
  • OceanBase AP
    • AP version update record
    • Overview of OceanBase Database AP
    • Core features of OceanBase Database AP
    • Quickly try out OceanBase AP
      • Deploy an AP architecture
      • Parameter configuration recommendations for AP scenarios
      • Deploy and use columnstore replicas
      • AP query routing rules
    • Data table design
      • Overview of Data Tables
      • Use columnstore and hybrid rowstore-columnstore formats
        • Dynamic partitioning
      • Best practices for data table design
        • Primary key design in AP scenarios
        • Practices for JSON multi-valued indexes and full-text indexes
        • Table partitioning design practices for AP scenarios
        • Configure Skip Index in conjunction with table update mode
        • Best practices for columnstore tables and indexes
    • Data transfer
      • Data transmission overview
      • Data migration
        • Data Migration Overview
        • Migrate data by using tools
        • Best practices for migrating data from mainstream AP databases to OceanBase
      • Data import
        • data-import
        • INSERT INTO SELECT
          • INSERT INTO SELECT FROM FILES
          • Import data using INSERT INTO SELECT from an external table
        • CREATE TABLE AS SELECT
        • Import data by using obloader
      • Data subscription and synchronization
        • Data Synchronization
        • Data subscription
      • Data processing in OceanBase Database
      • Data processing tools
      • Materialized views query acceleration
        • Query acceleration using materialized views
        • Classic scenarios for materialized views
    • Data lake
      • Data lake overview
      • Data lake integration
        • Access Hive tables through HMS Catalog
        • Load an Iceberg table through a catalog
        • ODPS
          • ODPS Catalog
          • ODPS External Table
        • Catalogs and external tables
        • File external tables
      • External tables via URL
      • Statistics
    • Data visualization
    • Ecosystem integration
      • Recommended practical tutorials for analytical processing
      • Accelerate offline queries in OceanBase Database using HMS Catalog
      • Practical Tutorial on Querying and Reading/Writing MaxCompute (ODPS) Data in OceanBase
    • AP FAQ
  • OceanBase AI
      • Overview of vector search
      • Core features of vector search
      • AI application workflow with OceanBase Vector Search
      • Use SQL to perform vector search
      • Perform a vector search by using Python
    • Vector embedding
    • Store vector data
    • Vector index
      • Vector index memory management
      • Dense vector index
        • Choose an index type
        • HNSW index
        • IVF series indexes
      • Semantic index
      • Sparse vector index
        • In-Memory Sparse Index
      • Monitor and maintain vector indexes
    • Use SQL functions
    • Vector similarity search
    • Hybrid search
      • Hybrid search (SQL interface)
      • Hybrid search (PL interface)
    • AI function service
      • Get started with AI Function Service
      • AI function service privileges
      • Register AI models
      • Syntax and examples of AI functions
    • Migrate to OceanBase Database from a vector database
    • Practical tutorial
    • Benchmark testing with VectorDBBench
    • Vector search references
      • Overview of vector data types
      • Search index
      • Compatibility
      • Supported clients and languages
        • Java SDK interface
  • Integrations
    • ORM frameworks
        • Connect to OceanBase Database by using Spring Boot
        • Connect to OceanBase Database by using Spring Batch
        • Connect to OceanBase Database by using Spring Data JDBC
        • Connect to OceanBase Database by using Spring Data JPA
        • Sample program that uses MyBatis to connect to OceanBase Database
        • Connect to OceanBase Database by using SQLAlchemy
        • Connect to OceanBase Database by using peewee
        • Connect to OceanBase Database by using GORM
      • Ruby
        • Connect to OceanBase Database by using Active Record
        • Sequel
    • Database version management
      • Liquibase
      • dbt
      • SeaTunnel
      • Maxwell
      • Debezium
    • SQL development
      • DBeaver
      • Navicat
      • DataGrip
      • TablePlus
    • Orchestration and scheduling
      • DolphinScheduler
      • Linkis
    • Visualization tools
      • Superset
      • Power BI
      • Quick BI
      • Tableau
      • NineData
      • Bytebase
    • AI
      • OpenAI
      • Qwen
      • LangChain
      • LlamaIndex
      • Dify
    • Build an intelligent Q&A assistant with OceanBase Database
    • Build a real-time data warehouse and visual dashboard with OceanBase
    • Analyze data in OceanBase Database using Superset
    • Build a WordPress website with OceanBase Database
    • Accelerate massive data import using direct load
    • OceanBase concepts
      • OceanBase Database architecture
          • Resource management for tenants
            • Replicated table
            • Temporary table
            • Table groups
            • Overview of indexes
            • Partition types
            • External table partitions
            • Views in a database
            • Standard views
              • Standard views
            • Replicated table
            • Table groups
            • Full-text index
            • Vector index
            • Search index
            • Standard views
              • Foreign key constraints
            • Read-only replicas
            • Columnstore replica
          • Data balancing
            • Intra-tenant balancing
          • Cluster-level scaling
          • Tenant-level scaling
        • Cross-data source access through DBLink
          • DBLink in MySQL-compatible mode
          • DBLink in Oracle-compatible mode
            • Monitor DDL execution progress
            • Tune parameters for parallel queries
            • Lock wait manager
            • Transaction isolation levels in Oracle-compatible mode
            • Transaction isolation levels in MySQL-compatible mode
          • Weak-consistency read
          • Columnar storage
          • Major compaction
        • Multi-level caching in shared-nothing architecture
          • Backup directory structure
          • Restore process
        • Configuration file
          • Trigger daily tenant compaction
          • Window compaction
          • Adaptive major compactions
          • Manually trigger a major compaction
          • View compaction information
        • Use the TTL feature
        • Memory management in a tenant
        • FAQ about memory
        • Configure dynamic expansion of disk data files
        • View the disk space used by a tenant or table
          • Skip index attribute
          • Change the attribute of a table
            • External tables and external files
            • Create and query external tables
            • Data type mappings
          • Partitioning overview
          • Partition splitting
            • Manual partition splitting
            • Automatic partition splitting
            • Automatic partition recommended configuration
            • Overview of dynamic partitioning
            • Create a dynamic partitioned table
            • Query a dynamic partitioned table
            • Modify a dynamically partitioned table
            • Dynamic partition management tasks
          • Random partition tables
            • Overview of Random Distribution Tables
            • Create a table with random distribution
            • Modify a table with a random distribution
          • Delete a partition
          • Truncate partitions
          • Partition exchange
          • Overview of Table Groups
          • Modify table group attributes
          • Manage tables within a table group
          • Manage standard views
          • Manage materialized views
            • Overview of materialized views
            • Materialized view logs
            • Create a materialized view
            • Refresh a materialized view
            • Query materialized views
            • Modify the attributes of a materialized view
            • Drop a materialized view
            • Materialized view resource isolation
        • Create and manage catalogs
          • Catalog Overview
          • Create catalog
          • View catalog
          • Drop catalog
            • Create and query an external table
            • Data type mapping
            • Automatic subpartition splitting
          • Drop partitions
            • Refresh materialized views
      • SQL overview
          • Overview of management commands
            • ADD REPLICA
            • ADD RESTORE SOURCE
            • BACKUP CLUSTER PARAMETERS
            • BALANCE JOB
            • CANCEL REPLICA TASK
            • CANCEL VALIDATE
            • CLEAR RESTORE SOURCE
            • CREATE LS
            • DELETE BACKUP ALL
            • DELETE BACKUPSET/ARCHIVELOG_PIECE
            • DELETE OBSOLETE BACKUP
            • LOAD MODULE DATA
            • MIGRATE REPLICA
            • MODIFY LS
            • MODIFY PAXOS_REPLICA_NUM
            • MODIFY REPLICA
            • FLUSH SEQUENCE CACHE
            • FLASHBACK STANDBY LOG
            • REMOVE REPLICA
            • RESTORE PREVIEW
            • SERVICE_NAME
            • TTL
            • VALIDATE
          • CLONE TENANT
          • SHOW RESTORE PREVIEW
        • User tenants (MySQL-compatible mode)
                • Overview of numeric types
                • Integer types
                • Fixed-point types
                • Floating-point types
                • BIT Value
                • Overview of datetime types
                • ON UPDATE CURRENT_TIMESTAMP column attribute
                • Overview of string types
                • Overview of large objects and text types
                • BLOB type
                • STRING type
                • LOB types
              • Set types
                • Overview of JSON data types
                • Convert data types to JSON
                • Update JSON data
                • Semi-structured encoding
                • Overview of spatial data types
                • Spatial reference systems (SRS)
                • Create spatial columns
                • Create spatial indexes
              • Roaring bitmap types
                • Overview of the RoaringBitmap data type
                • Create a roaring bitmap column
              • Array data types
                • Create an array column
              • Map data types
                • Overview of mapping data types
                • Create a mapped column
              • Overview of expressions
              • Simple Expressions
              • Compound Expressions
              • Conditional Expressions
              • Column Expressions
              • Date and time expressions
              • Function Expressions
              • List of Expressions
              • Character Sets
              • Character set and collation of character expressions
              • Character set and collation for client connections
              • String literals
              • Numeric values
              • Date and time values
              • NULL values
                • Use Query Block Name and QB_NAME Hint to control query optimization
                  • Global hints
                    • Optimizer Stats Hint under the Global Hint Type
                    • Transform Hint in the Global Hints section
                    • Other hints under global hints
                    • Access path hints in the Optimized Hint category
                    • Join order hints in the Optimized Hint category
                    • Join operation hints in the Optimized Hint category
                    • Subquery hints under the Optimized Hint category
                    • Group By Hint in the Optimized Hint category
                    • Distinct hint
                    • Set Hint in Optimized Hint Type
                    • Distributed DML hints in the Optimized Hint category
                    • Vector Index Hint in the Optimized Hint category
                  • Transform hints
                    • Stmt Transform Hint
                    • Cost-based transform hints
                    • Heuristics transform hints
                    • Other hints under the Transform Hint type
                  • Outline-related hints
            • Assignment operator
            • Character concatenation operators
            • BINARY conversion operators
            • Function overview
                • DATE_TRUNC
                • MONTHS_ADD
                • FORMATDATETIME
                • TOUNIXTIMESTAMP
                • parseDateTime
                • KEYVALUE
                • MAX_PT
                • MD5_CONCAT_WS
                • SPLIT_PART
                • URL_DECODE
                • URL_ENCODE
                • EDITDISTANCE
                • DECODE_TRACE_ID
              • ARG_MAX
              • ARG_MIN
              • WINDOW_FUNNEL
              • STRING_AGG
              • AVG_WEIGHTED
              • ARBITRARY
              • ANY
              • GROUPCONCAT
              • STDDEVSAMP
              • UNIQ
              • VARSAMP
              • LAGINFRAME
              • LEADINFRAME
              • ENHANCED_AES_ENCRYPT
              • ENHANCED_AES_DECRYPT
              • PASSWORD
              • SM3
              • SM4_ENCRYPT
              • SM4_DECRYPT
              • CATALOG
              • LAST_INSERT_ID Behavior Description
              • OB_TRANSACTION_ID
              • JSON_TABLE function
              • Overview of XML functions
            • Table functions
              • Overview of TABLE FUNCTIONS
              • FILES table function
              • Overview of spatial functions
              • Create a geometry value function
              • Spatial relationship functions
              • Geometry attribute functions
              • Spatial processing functions
              • _ST_GeoHash
              • Overview of lock functions
              • RELEASE_ALL_LOCKS()
            • Bitmap functions
              • RoaringBitmap constructor
              • Bitmap cardinality calculation functions
              • Bitmap operation functions
              • Bitmap decision functions
              • Bitmap output functions
              • Bitmap aggregate functions
            • Array functions
              • Overview of array functions
              • Array constructor functions
              • Array decision functions
              • Array output functions
              • Array functions
            • Text processing functions
              • TOKENIZE
            • Audit functions
              • AUDIT_LOG_FILTER_SET_FILTER
              • AUDIT_LOG_FILTER_SET_USER
              • AUDIT_LOG_ENCRYPTION_PASSWORD_SET
              • AUDIT_LOG_ENCRYPTION_PASSWORD_GET
            • Map functions
              • Overview of mapping functions
              • Map constructors and operators
              • Map decision functions
              • Map operation functions
              • MATCH AGAINST
              • ISNAN
            • Join
            • Full-text search
            • Common table expressions
            • ALTER COMPILE
            • ALTER LOCATION
            • ALTER MATERIALIZED VIEW
            • ALTER MATERIALIZED VIEW LOG
            • ALTER SENSITIVE RULE
            • ALTER SYSTEM FLUSH SEQUENCE CACHE
            • VALIDATE
            • ALTER TABLESPACE
            • ALTER INSTANCE ROTATE INNODB MASTER KEY
            • ALTER EVENT
            • CACHE INDEX
            • CREATE CONCURRENT_LIMITING_RULE
            • CREATE EXTERNAL CATALOG
            • CREATE LOCATION
            • CREATE MATERIALIZED VIEW
            • CREATE FORMAT OUTLINE
            • CREATE RESTORE POINT
            • CREATE SENSITIVE RULE
            • CHECKSUM TABLE
            • CREATE EVENT
            • DROP CATALOG
            • DROP CONCURRENT_LIMITING_RULE
            • DROP EVENT
            • DROP LOCATION
            • DROP MATERIALIZED VIEW
            • DROP MATERIALIZED VIEW LOG
            • DROP SENSITIVE RULE
            • DROP RESTORE POINT
            • FLUSH TABLE
            • LOAD_FILE
            • LOAD INDEX INTO CACHE
            • REPAIR TABLE
              • WINDOW clause
              • HYBRID_SEARCH
            • SET CATALOG
            • SUBMIT JOB
            • SHOW JOB STATUS
            • CANCEL JOB
            • UNLOCK TABLES
            • XA transaction
            • Overview of DDL operations
            • Online DDL and offline DDL operations
            • NUMBER type conversion rules
            • PARTITIONID pseudo column
            • Sequence pseudo column
            • Overview of SQL Conditions
            • Condition priority
            • Pattern matching conditions
            • NULL values condition
            • JSON Member Conditions
            • Boolean test conditions
        • User tenants (Oracle-compatible mode)
            • Overview of Pseudocolumns
            • Hierarchical query pseudo-columns
            • Sequence pseudo-column
            • ORA_ROWSCN pseudo-column
            • ROWNUM pseudo-column
            • ROWID pseudo-column
                • Overview of numeric data types
                • Numeric type priorities
                • Calculation of DATE and INTERVAL values
                • Overview of large object data types
                • LOB types
              • Rowid data type
                • Conversion rules for JSON data type
                • Overview of the XMLType data type
                • Conversion of the XMLType data type
                • Access SDO_GEOMETRY properties
              • Overview of data type comparison rules
              • Comparison rules of numeric values
              • Data type priority
              • Security considerations for data conversion in Oracle-compatible mode
                • DATE literals
                • TIMESTAMP literals
              • INTERVAL literals
              • Formatting models
              • RR date-time format element
              • Conversion rules from string to date
              • Overview of empty values
              • Null values in SQL functions
              • NULL values in comparison conditions
              • NULL values in conditional expressions
              • Comments on SQL statements
              • Comment on schema and nonschema objects
                • Overview of hints
                • Control query optimization by using Query Block Name and QB_NAME Hint
                  • Global hints
                    • Optimizer Stats Hint under Global Hints
                    • Transform Hint in Global Hints
                    • Other hints under the global hint type
                  • Optimized hints
                    • Join Order Hints
                    • DISTINCT hint
                    • Set Hint
                    • Distributed DML hint in the Optimized Hint category
                  • Transform hints
                    • Stmt Transform Hint in the Transform Hint Type
                    • Cost based transform hints
                    • Other TRANSFORM Hint
              • Overview of database object naming conventions
              • Schema object naming recommendations
              • Overview of database object references
                • Create a database link
                • Database links
              • Reference attributes and methods of object types
            • Overview of operators
            • Function overview
                • MAX_PT
                • SUBSTRB
                • INSTRB
                • INSTRC
                • LENGTHB
                • LENGTHC
                • EXTRACT (datetime)
                • ROUND (date)
                • TO_CHAR (datetime)
                • TRUNC (date)
                • NEW_TIME
                • RAWTONHEX
                • TO_CHAR (character)
                • TO_CHAR (number)
                • TO_NCHAR (character)
                • TO_NCHAR (datetime)
                • TO_NCHAR (number)
                • TIMESTAMP_NVL
              • Large object functions
                • EMPTY_BLOB
                • EMPTY_CLOB
                  • XMLCONCAT
                  • XMLFOREST
                  • EXISTSNODE
                • Constructor functions
                • Format conversion functions
              • REGR_ (Linear Regression)
              • WINDOW_FUNNEL
              • GROUP_ID
              • GROUPING_ID
              • Analytic function description
              • ARG_MIN
              • ARG_MAX
              • CATALOG
              • OB_TRANSACTION_ID
            • Table functions
            • Audit functions
              • Overview of audit functions
            • Conditional expressions
            • CURSOR Expressions
            • Scalar Subquery Expression
            • Overview of SQL conditions
            • Null conditions
            • Simple query
            • Hierarchical queries
            • Composite queries
            • Join queries
            • Query the DUAL table
              • ALTER LOCATION
              • ALTER SYSTEM ENABLE/DISABLE RESTRICTED SESSION
              • ALTER SYSTEM FLUSH CACHE
              • ALTER SYSTEM SET PARAMETER
              • VALIDATE
              • ALTER TABLESPACE
              • ALTER VIEW COMPILE
              • CREATE LOCATION
              • DROP LOCATION
                • Collection SELECT
                • WITH CLAUSE
                • APPLY clause
                • PIVOT clause
                • UNPIVOT clause
            • Operations on generated columns
        • SQL writing restrictions
          • SELECT statement writing specification
          • DML statement writing specifications
          • DDL statement writing specifications
          • Multi-table association specification
          • Table scanning mode specification
          • Transaction-related specifications
          • Cache usage specifications
          • Guidelines for using hints
          • Other specifications
          • Implicit type conversion
          • JOIN table usage suggestions
          • Pagination
      • Reserved keywords (MySQL-compatible mode)
      • Reserved keywords (Oracle-compatible mode)
      • Data type conversion behavior of a MySQL tenant in strict mode
        • PL overview
      • PL reference (MySQL-compatible mode)
        • PL syntax
          • Overview of PL stored programs
          • Manage stored routines and privileges
          • External storage functions
          • EVENT
          • Stored program usage restrictions
          • SQL Transpiler
          • PL asynchronous commit optimization
          • Server-side cursor usage limits
          • Scope of procedures
          • Overview of system packages
          • DBMS_AI_SERVICE
            • Overview of DBMS_AI_SERVICE
            • CREATE_AI_MODEL
            • DROP_AI_MODEL
            • CREATE_AI_MODEL_ENDPOINT
            • ALTER_AI_MODEL_ENDPOINT
            • DROP_AI_MODEL_ENDPOINT
          • DBMS_DAILY_MAINTENANCE
            • TRIGGER_WINDOW_COMPACTION_PROC
            • SET_THREAD_COUNT
          • DBMS_HYBRID_SEARCH
            • Overview of DBMS_HYBRID_SEARCH
            • SEARCH
            • GET_SQL
          • DBMS_MVIEW
            • Overview of DBMS_MVIEW
            • PURGE_LOG
            • KILL_REFRESH
            • REFRESH_REPORT
            • SET_REFRESH_PARAMS
            • EXPLAIN_REFRESH
          • DBMS_MVIEW_STATS
            • Overview of DBMS_MVIEW_STATS
            • PURGE_REFRESH_STATS
            • SET_MVREF_STATS_PARAMS
            • SET_SYSTEM_DEFAULT
          • DBMS_PARTITION
            • MANAGE_DYNAMIC_PARTITION
            • COPY_PLAN
            • System Packages
            • Overview of DBMS_STATS
            • DELETE_CATALOG_GLOBAL_PREFS
            • DELETE_CATALOG_TABLE_PREFS
            • GATHER_CATALOG_TABLE_STATS
            • GET_CATALOG_GLOBAL_PREFS
            • GET_CATALOG_PREFS
            • LOCK_CATALOG_PARTITION_STAT
            • LOCK_CATALOG_TABLE_STAT
            • SET_CATALOG_GLOBAL_PREFS
            • SET_CATALOG_TABLE_PREFS
            • UNLOCK_CATALOG_PARTITION_STAT
            • UNLOCK_CATALOG_TABLE_STAT
            • CANCEL_GATHER_STATS
            • GATHER_DATABASE_STATS_JOB_PROC
            • ADD_TRUSTED_CERTIFICATE
            • DELETE_TRUSTED_CERTIFICATE
            • UPDATE_TRUSTED_CERTIFICATE
          • DBMS_VECTOR
            • Overview of DBMS_VECTOR
            • REBUILD_INDEX
            • INDEX_VECTOR_MEMORY_ESTIMATE
            • INDEX_VECTOR_MEMORY_ADVISOR
            • FLUSH_INDEX
            • COMPACT_INDEX
            • INDEX_RECALL
            • QUERY_RECALL
            • Overview of DBMS_SESSION
            • Overview of DBMS_APPLICATION_INFO
          • DBMS_XPROFILE
            • Overview of DBMS_XPROFILE
            • DISPLAY_PROFILE
          • DBMS_BALANCE
            • SET_BALANCE_WEIGHT
            • CLEAR_BALANCE_WEIGHT
            • TRIGGER_PARTITION_BALANCE
            • SET_TABLEGROUP_BALANCE_WEIGHT
            • CLEAR_TABLEGROUP_BALANCE_WEIGHT
          • DBMS_LIMIT_CALCULATOR
          • DBMS_EXTERNAL_TABLE
            • Overview of DBMS_EXTERNAL_TABLE
            • AUTO_REFRESH_EXTERNAL_TABLE
          • DBMS_JAVA
            • Overview of DBMS_JAVA
            • LOADJAVA
            • DROPJAVA
            • GRANT_PERMISSION
            • RESTRICT_PERMISSION
            • REVOKE_PERMISSION
            • DISABLE_PERMISSION
            • ENABLE_PERMISSION
            • DELETE_PERMISSION
          • DBMS_PYTHON
            • DROPPYTHON
            • LOADPYTHON
          • DBMS_DATA_DICT
            • DBMS_DATA_DICT
          • DBMS_SCHEMA
            • Overview of DBMS_SCHEMA
            • RECYCLE_SCHEMA_HISTORY
            • RUN_INSPECTION
        • PL reserved and non-reserved keywords
      • PL reference (Oracle-compatible mode)
          • Lexical elements
          • Syntax
          • Identifier scope and visibility
          • Assignment
          • Error reporting functions
          • Boolean data type
          • Sequence control
          • Collection constructors
          • Records
          • Insert and update tables with records
          • Create and invoke subprograms with record-type parameters
            • Cursor overview
            • Explicit cursor
            • Use FOR loops to traverse cursors
            • Modify and delete cursors
            • Call autonomous functions from SQL
          • FORALL and BULK COLLECT
          • Grant privileges
            • Overview of pipelined table functions
            • Create a pipeline function
            • Related applications
          • SQL Transpiler
          • Information collection for stored procedures and parallel execution of SQL statements
          • PL Database Link
          • External Stored Functions
          • Modify and drop triggers
          • Disable and enable a trigger
          • View trigger information
          • INSTEAD OF DML triggers
          • Composite DML triggers
          • System triggers
          • Create a package
          • Manage packages
          • Definition of the STANDARD package for PL
          • Compile-Time Warnings
          • Exception handling order
          • Overview of the PL Label Security package
            • Overview of the SA_COMPONENTS package
            • Overview of SA_SESSION
        • PL system package (Oracle-compatible mode)
            • Overview of DBMS_AUDIT_MGMT
            • CLEAR_LAST_ARCHIVE_TIMESTAMP
            • SET_PURGE_JOB_INTERVAL
          • DBMS_BALANCE
            • Overview of DBMS_BALANCE
            • Overview of DBMS_CRYPTO
            • Overview of DBMS_DAILY_MAINTENANCE
            • SET_THREAD_COUNT
            • PING
            • SYNCHRONIZE
            • TARGET_PROGRAM_RUNNING
            • Overview of DBMS_LOB
            • CONVERTTOBLOB
            • Overview of DBMS_LOCK
            • RELEASE
            • Overview of DBMS_METADATA
            • GET_TABLE_INDEX_DDL
          • DBMS_MVIEW
            • PURGE_LOG
            • KILL_REFRESH
            • REFRESH_REPORT
            • EXPLAIN_REFRESH
            • Overview of DBMS_MONITOR
            • OB_SESSION_TRACE_ENABLE
            • OB_SESSION_TRACE_DISABLE
            • OB_CLIENT_ID_TRACE_ENABLE
            • OB_CLIENT_ID_TRACE_DISABLE
            • OB_MOD_ACT_TRACE_ENABLE
            • OB_MOD_ACT_TRACE_DISABLE
            • OB_TENANT_TRACE_ENABLE
            • OB_TENANT_TRACE_DISABLE
          • DBMS_MVIEW_STAT
            • Overview of DBMS_OUTPUT
            • Overview of DBMS_PLAN_CACHE
          • DBMS_PLSQL_CODE_COVERAGE
            • START_COVERAGE
            • STOP_COVERAGE
            • CREATE_COVERAGE_TABLES
          • 12580.dbms-preprocessor-oracle
            • DBMS_PREPROCESSOR overview
            • PRINT_POST_PROCESSED_SOURCE
            • GET_POST_PROCESSED_SOURCE
          • DBMS_PARTITION
            • DBMS_PARTITION overview
            • Overview of DBMS_RANDOM
          • DBMS_ERRLOG
            • Overview of DBMS_ERRLOG
            • CREATE_ERROR_LOG
          • DBMS_SYS_ERROR
            • Overview of DBMS_SYS_ERROR
            • RAISE_SYSTEM_ERROR
            • COPY_PLAN
          • DBMS_RLS
            • Overview of DBMS_RLS
            • ADD_POLICY
            • DROP_POLICY
            • ENABLE_POLICY
            • ALTER_POLICY
            • ADD_POLICY_CONTEXT / DROP_POLICY_CONTEXT
            • REFRESH_POLICY / REFRESH_GROUPED_POLICY
            • CREATE_POLICY_GROUP / DELETE_POLICY_GROUP
            • ADD_GROUPED_POLICY
            • DROP_GROUPED_POLICY
            • ENABLE_GROUPED_POLICY / DISABLE_GROUPED_POLICY
            • ALTER_GROUPED_POLICY
            • Overview of DBMS_SCHEDULER
            • CREATE_JOB_CLASS
            • DROP_JOB_CLASS
            • PURGE_LOG
            • STOP_JOB
          • DBMS_SCHEMA
            • RUN_INSPECTION
            • SESSION_IS_ROLE_ENABLED
            • IS_ROLE_ENABLED
            • Overview of DBMS_SQL
            • BIND_VARIABLE_CHAR
            • BIND_VARIABLE_RAW
            • COLUMN_VALUE_CHAR
            • COLUMN_VALUE_RAW
            • DEFINE_COLUMN_CHAR
            • DEFINE_COLUMN_RAW
            • DESCRIBE_COLUMNS2
            • DESCRIBE_COLUMNS3
            • VARIABLE_VALUE
            • VARIABLE_VALUE_CHAR
            • VARIABLE_VALUE_RAW
            • TO_CURSOR_NUMBER
            • TO_REFCURSOR
            • DBMS_UDR overview
            • Overview of DBMS_UTILITY
            • EXEC_DDL_STATEMENT
            • COMMA_TO_TABLE
            • CANONICALIZE
            • VALIDATE
            • Overview of DBMS_WORKLOAD_REPOSITORY
            • ASH_REPORT_TEXT
            • DBMS_XA overview
            • Constants of DBMS_XA
            • Overview of the DBMS_XMLGEN package
          • DBMS_PROFILER
            • Overview of DBMS_PROFILER
            • START_PROFILER
            • STOP_PROFILER
            • PAUSE_PROFILER
            • RESUME_PROFILER
            • FLUSH_DATA
            • GET_VERSION
            • INTERNAL_VERSION_CHECK
            • ROLLUP_UNIT
            • ROLLUP_RUN
            • OB_INIT_OBJECTS
            • OB_DROP_OBJECTS
            • Overview of DBMS_XPLAN
          • DBMS_XPROFILE
            • DISPLAY_PROFILE
          • DBMS_DDL
            • Overview of DBMS_DDL
            • WRAP
            • CREATE_WRAPPED
          • 21500.dbms-data-dict-oracle
            • DBMS_DATA_DICT
            • Overview of ODCIConst
            • Overview of UTL_ENCODE
            • MIMEHEADER_DECODE
            • MIMEHEADER_ENCODE
            • QUOTED_PRINTABLE_DECODE
            • QUOTED_PRINTABLE_ENCODE
            • TEXT_DECODE
            • TEXT_ENCODE
            • UUDECODE
            • UUENCODE
            • Overview of UTL_FILE
            • FCOPY
            • FCLOSE_ALL
            • FOPEN_NCHAR
            • FGETATTR
            • NEW_LINE_NCHAR
            • GET_LINE_NCHAR
            • GET_RAW
            • PUT_RAW
            • PUT_NCHAR
            • PUT_LINE_NCHAR
            • PUTF
            • PUTF_NCHAR
            • Overview of UTL_I18N
          • UTL_RECOMP
            • Overview of UTL_RECOMP
            • RECOMP_PARALLEL
            • RECOMP_SERIAL
            • PARALLEL_SLAVE
            • Overview of UTL_RAW
            • CAST_TO_NVARCHAR2
          • UTL_TCP
            • Overview of UTL_TCP
            • OPEN_CONNECTION
            • CLOSE_CONNECTION
            • CLOSE_ALL_CONNECTIONS
            • WRITE_LINE
            • WRITE_TEXT
            • WRITE_RAW
            • GET_TEXT
          • UTL_SMTP
            • Overview of UTL_SMTP
            • OPEN_CONNECTION
            • CLOSE_CONNECTION
            • QUIT
            • AUTH
            • COMMAND
            • COMMAND_REPLIES
            • HELO
            • EHLO
            • MAIL
            • RCPT
            • OPEN_DATA
            • WRITE_DATA
            • WRITE_RAW_DATA
            • CLOSE_DATA
            • DATA
            • VRFY
            • NOOP
            • RSET
          • UTL_HTTP
            • Overview of UTL_HTTP
            • BEGIN_REQUEST
            • END_REQUEST
            • GET_RESPONSE
            • END_RESPONSE
            • READ_LINE
            • READ_RAW
            • READ_TEXT
            • WRITE_LINE
            • WRITE_RAW
            • WRITE_TEXT
            • SET_TRANSFER_TIMEOUT
            • GET_TRANSFER_TIMEOUT
            • Overview of the ANYDATA type
            • BEGINCREATE static stored procedure
            • ENDCREATE member stored procedure
            • GET* member function
            • PIECEWISE member stored procedure
            • SET* member stored procedure
            • ACCESS* member functions
            • CONVERT* static functions
            • EXISTSNODE
        • PL reserved keywords
      • View changes in V3.x and V4.x
          • information_schema.events
          • information_schema.TRIGGERS
          • oceanbase.CDB_CKPT_HISTORY
          • oceanbase.CBA_SCHEDULER_RUNNING_JOBS
          • oceanbase.CDB_SCHEDULER_JOBS
          • CDB_INDEX_USAGE
          • oceanbase.CDB_MVIEW_DEPS
          • CDB_MVIEW_LOGS
          • oceanbase.CDB_MVIEW_RUNNING_JOBS
          • CDB_MVIEWS
          • CDB_MVREF_CHANGE_STATS
          • CDB_MVREF_RUN_STATS
          • CDB_MVREF_STATS
          • CDB_MVREF_STATS_PARAMS
          • CDB_MVREF_STMT_STATS
          • oceanbase.CDB_OB_AI_MODEL_ENDPOINTS
          • oceanbase.CDB_OB_AI_MODELS
          • oceanbase.CDB_OB_BACKUP_VALIDATE_JOBS
          • oceanbase.CDB_OB_BACKUP_VALIDATE_JOB_HISTORY
          • oceanbase.CDB_OB_BACKUP_VALIDATE_TASKS
          • oceanbase.CDB_OB_BACKUP_VALIDATE_TASK_HISTORY
          • oceanbase.CDB_OB_CCL_RULES
          • oceanbase.CDB_OB_CS_REPLICA_STATS
          • oceanbase.CDB_OB_DYNAMIC_PARTITION_TABLES
          • oceanbase.CDB_OB_LOB_CHECK_EXCEPTION_RESULT
          • oceanbase.CDB_OB_LOB_CHECK_TASKS
          • oceanbase.CDB_OB_LS_REPLICA_TASK_HISTORY
          • oceanbase.CDB_OB_OBJECT_BALANCE_WEIGHT
          • oceanbase.CDB_OB_SERVICES
          • oceanbase.CDB_OB_RSRC_DIRECTIVES
          • oceanbase.CDB_OB_SENSITIVE_COLUMNS
          • oceanbase.CDB_OB_SENSITIVE_RULE_PLAINACCESS_USERS
          • oceanbase.CDB_OB_SENSITIVE_RULES
          • oceanbase.CDB_OB_SERVER_SPACE_USAGE
          • oceanbase.CDB_OB_SPACE_USAGE
          • oceanbase.CDB_OB_SYS_VARIABLE_HISTORY
          • oceanbase.CDB_OB_STORAGE_IO_USAGE
          • oceanbase.CDB_OB_SPM_EVO_RESULT
          • oceanbase.CDB_OB_TABLE_SPACE_USAGE
          • oceanbase.CDB_OB_TEMP_FILES
          • oceanbase.CDB_OB_TENANT_FLASHBACK_LOG_SCN
          • oceanbase.CDB_OB_TTL_TASKS
          • oceanbase.CDB_OB_TTL_TASK_HISTORY
          • oceanbase.CDB_OB_VECTOR_INDEX_TASKS
          • oceanbase.CDB_OB_VECTOR_INDEX_TASK_HISTORY
          • oceanbase.CDB_WR_RES_MGR_SYSSTAT
          • oceanbase.CDB_WR_SQL_PLAN
          • oceanbase.CDB_OB_EXTERNAL_RESOURCES
          • oceanbase.DBA_INDEX_USAGE
          • oceanbase.DBA_MVIEW_DEPS
          • oceanbase.DBA_MVIEW_LOGS
          • oceanbase.DBA_MVIEW_RUNNING_JOBS
          • oceanbase.DBA_MVIEWS
          • DBA_MVREF_CHANGE_STATS
          • oceanbase.DBA_MVREF_RUN_STATS
          • oceanbase.DBA_MVREF_STATS
          • DBA_MVREF_STATS_PARAMS
          • DBA_MVREF_STMT_STATS
          • oceanbase.DBA_OB_AI_MODEL_ENDPOINTS
          • oceanbase.DBA_OB_AI_MODELS
          • oceanbase.DBA_OB_BACKUP_VALIDATE_JOBS
          • oceanbase.DBA_OB_BACKUP_VALIDATE_JOB_HISTORY
          • oceanbase.DBA_OB_BACKUP_VALIDATE_TASKS
          • oceanbase.DBA_OB_BACKUP_VALIDATE_TASK_HISTORY
          • oceanbase.DBA_OB_CCL_RULES
          • oceanbase.DBA_OB_CS_REPLICA_STATS
          • oceanbase.DBA_OB_DYNAMIC_PARTITION_TABLES
          • oceanbase.DBA_OB_EXTERNAL_PART_COL_STATISTICS
          • oceanbase.DBA_OB_EXTERNAL_TAB_COL_STATISTICS
          • oceanbase.DBA_OB_EXTERNAL_TAB_STATISTICS
          • oceanbase.DBA_OB_EXTERNAL_RESOURCES
          • DBA_OB_FORMAT_OUTLINES
          • oceanbase.DBA_OB_LOB_CHECK_EXCEPTION_RESULT
          • oceanbase.DBA_OB_LOB_CHECK_TASKS
          • oceanbase.DBA_OB_SERVICES
          • oceanbase.DBA_OB_RSRC_DIRECTIVES
          • oceanbase.DBA_SCHEDULER_RUNNING_JOBS
          • oceanbase.DBA_OB_STORAGE_IO_USAGE
          • oceanbase.DBA_OB_SPM_EVO_RESULT
          • oceanbase.DBA_OB_SYS_VARIABLE_HISTORY
          • oceanbase.DBA_OB_TEMP_FILES
          • oceanbase.DBA_OB_TENANT_FLASHBACK_LOG_SCN
          • oceanbase.DBA_OB_TTL_TASKS
          • oceanbase.DBA_OB_TTL_TASK_HISTORY
          • oceanbase.DBA_OB_VECTOR_INDEX_TASKS
          • oceanbase.DBA_OB_VECTOR_INDEX_TASK_HISTORY
          • oceanbase.DBA_RECYCLEBIN
          • oceanbase.DBA_TABLES
          • oceanbase.DBA_WR_RES_MGR_SYSSTAT
          • oceanbase.DBA_WR_SQL_PLAN
          • oceanbase.V$OB_KEYWORDS
          • GV$OB_CGROUP_CONFIG
          • GV$OB_EXTERNAL_CATALOG_CLIENT_POOL_STAT
          • GV$OB_FUNCTION_IO_STAT
          • GV$OB_GROUP_IO_STAT
          • GV$OB_HMS_CLIENT_POOL_STAT
          • GV$OB_HNSW_INDEX_INFO
          • GV$OB_HNSW_INDEX_SEGMENT_INFO
          • GV$OB_IVF_INDEX_INFO
          • GV$OB_KV_CONNECTIONS
          • GV$OB_LS_SNAPSHOTS
          • GV$OB_NIC_INFO
          • GV$OB_PLUGINS
          • GV$OB_RES_MGR_SYSSTAT
          • GV$OB_SESSION_PS_INFO
          • GV$OB_SHARED_STORAGE_QUOTA
          • GV$OB_SINDI_INDEX_INFO
          • GV$OB_SQL_CCL_STATUS
          • GV$OB_TABLET_REPLICA_INFO
          • GV$OB_TENANT_RESOURCE_LIMIT
          • GV$OB_TENANT_WORKER_GROUPS
          • GV$OB_VECTOR_MEMORY
          • gv$tenant
          • GV$OB_KV_CLIENT_INFO
          • GV$UNIT
          • V$OB_COMPATIBILITY_CONTROL
          • V$OB_CGROUP_CONFIG
          • V$OB_DYNAMIC_PARTITION_TABLES
          • V$OB_EXTERNAL_CATALOG_CLIENT_POOL_STAT
          • V$OB_FUNCTION_IO_STAT
          • V$OB_GROUP_IO_STAT
          • V$OB_HMS_CLIENT_POOL_STAT
          • V$OB_HNSW_INDEX_INFO
          • V$OB_HNSW_INDEX_SEGMENT_INFO
          • V$OB_IVF_INDEX_INFO
          • V$OB_KV_CLIENT_INFO
          • V$OB_KV_GROUP_COMMIT_STATUS
          • V$OB_KV_CONNECTIONS
          • V$OB_LS_SNAPSHOTS
          • V$OB_NIC_INFO
          • V$OB_PLUGINS
          • V$OB_RES_MGR_SYSSTAT
          • V$OB_SESSION_PS_INFO
          • V$OB_SHARED_STORAGE_QUOTA
          • V$OB_SINDI_INDEX_INFO
          • V$OB_SQL_CCL_STATUS
          • V$OB_TABLET_REPLICA_INFO
          • V$OB_TENANT_RESOURCE_LIMIT
          • V$OB_TRANSACTION_SCHEDULERS
          • V$RESTORE_POINT
          • V$OB_VECTOR_MEMORY
          • V$UNIT
          • mysql.audit_log_filter
          • mysql.audit_log_user
          • oceanbase.DBA_JAVA_POLICY
          • oceanbase.DBA_OB_OBJECT_BALANCE_WEIGHT
          • oceanbase.DBA_OB_SENSITIVE_COLUMNS
          • oceanbase.DBA_OB_SENSITIVE_RULE_PLAINACCESS_USERS
          • oceanbase.DBA_OB_SENSITIVE_RULES
          • oceanbase.DBA_OB_TABLE_SPACE_USAGE
          • oceanbase.USER_JAVA_POLICY
          • GV$OB_HNWS_INDEX_INFO
          • GV$OB_NIC_INFO
          • V$OB_HNWS_INDEX_INFO
          • V$OB_KEYWORDS
          • V$OB_LS_SNAPSHOTS
          • V$OB_NIC_INFO
          • V$RESTORE_POINT
          • ALL_LOCATIONS
          • ALL_MVIEW_LOGS
          • ALL_MVIEWS
          • ALL_OB_SOURCE
          • ALL_PLSQL_TYPES
          • ALL_PLSQL_COLL_TYPES
          • ALL_PLSQL_TYPE_ATTRS
          • DBA_INDEX_USAGE
          • DBA_JAVA_POLICY
          • DBA_MVIEW_DEPS
          • DBA_MVIEW_LOGS
          • DBA_MVIEW_RUNNING_JOBS
          • DBA_MVIEWS
          • DBA_MVREF_RUN_STATS
          • DBA_MVREF_STATS
          • DBA_OB_BACKUP_VALIDATE_JOBS
          • DBA_OB_BACKUP_VALIDATE_JOB_HISTORY
          • DBA_OB_BACKUP_VALIDATE_TASKS
          • DBA_OB_BACKUP_VALIDATE_TASK_HISTORY
          • DBA_OB_CS_REPLICA_STATS
          • DBA_OB_CCL_RULES
          • DBA_OB_DYNAMIC_PARTITION_TABLES
          • DBA_OB_LOB_CHECK_EXCEPTION_RESULT
          • DBA_OB_LOB_CHECK_TASKS
          • DBA_OB_SENSITIVE_COLUMNS
          • DBA_OB_SENSITIVE_RULE_PLAINACCESS_USERS
          • DBA_OB_SENSITIVE_RULES
          • DBA_OB_SERVICES
          • DBA_OB_OBJECT_BALANCE_WEIGHT
          • DBA_OB_PL_OBJ_CACHE_STATUS
          • DBA_OB_RSRC_DIRECTIVES
          • DBA_OB_SPATIAL_COLUMNS
          • DBA_OB_STORAGE_IO_USAGE
          • DBA_OB_SYS_VARIABLES
          • DBA_OB_SYS_VARIABLE_HISTORY
          • DBA_OB_SOURCE
          • DBA_OB_SPM_EVO_RESULT
          • DBA_OB_TENANT_FLASHBACK_LOG_SCN
          • DBA_OB_TEMP_FILES
          • DBA_PLSQL_TYPES
          • DBA_PLSQL_COLL_TYPES
          • DBA_PLSQL_TYPE_ATTRS
          • DBA_OB_TTL_TASKS
          • DBA_OB_TTL_TASK_HISTORY
          • DBA_SCHEDULER_RUNNING_JOBS
          • DBA_OB_TABLE_SPACE_USAGE
          • DBA_WR_RES_MGR_SYSSTAT
          • DBA_WR_SQL_PLAN
          • PROXY_USERS
          • USER_PLSQL_TYPES
          • USER_JAVA_POLICY
          • USER_PLSQL_COLL_TYPES
          • USER_PLSQL_TYPE_ATTRS
          • USER_MVIEW_LOGS
          • USER_MVIEWS
          • USER_MVREF_CHANGE_STATS
          • USER_MVREF_RUN_STATS
          • USER_MVREF_STATS
          • USER_MVREF_STATS_PARAMS
          • USER_MVREF_STMT_STATS
          • USER_OB_SOURCE
          • V$OB_KEYWORDS
          • GV$OB_NIC_INFO
          • GV$OB_RESULT_CACHE_OBJECTS
          • V$OB_KEYWORDS
          • V$OB_LS_SNAPSHOTS
          • V$OB_NIC_INFO
          • V$OB_RESULT_CACHE_OBJECTS
          • V$RESTORE_POINT
      • Overview of metrics
      • Common wait events
      • Overview of configuration parameters and system variables
      • Parameter and system variable changes between V3.x and V4.x
        • Overview of parameters
          • alert_log_level
          • async_ps_cursor_max_count
          • system_protected_sys_variables
          • system-protected-tenant-parameters
          • clog_io_isolation_mode
          • enable_ob_error_msg_style
          • external_table_disk_cache_max_percentage
          • global_background_cpu_quota
          • io_scheduler_thread_count
          • log_storage_warning_trigger_percentage
          • ob_java_connector_path
          • ob_python_home
          • ob_enable_java_env
          • ob_enable_utl_tcp
          • ob_java_home
          • ob_java_opts
          • ob_enable_utl_http
          • plugins_load
          • sync_io_thread_count
          • kv_transport_compress_func
          • unit_gc_wait_time
          • utl_file_open_max
          • approx_count_distinct_precision
          • audit_log_buffer_size
          • audit_log_compression
          • audit_log_enable
          • audit_log_encryption
          • audit_log_format
          • audit_log_max_size
          • audit_log_path
          • audit_log_prune_seconds
          • audit_log_query_sql
          • audit_log_rotate_on_size
          • audit_log_strategy
          • auto_split_tablet_size
          • default_delta_format
          • default_load_mode
          • default_micro_block_format_version
          • default_skip_index_level
          • default_table_merge_engine
          • default_table_organization
          • default_table_store_format
          • direct_load_allow_fallback
          • ddl_high_thread_score
          • document_ai_file_max_size
          • enable_adaptive_plan_cache
          • enable_auto_split
          • enable_database_sharding_none
          • enable_hbase_rowkey_ttl
          • enable_pl_rich_error_msg
          • enable_gts_standalone
          • enable_kv_group_commit
          • enable_lock_priority
          • enable_mlog_auto_maintenance
          • enable_mv_binlog_minimal_mode
          • enable_ls_leader_balance
          • enable_ttl
          • enable_window_compaction
          • enable_ps_parameterize
          • external_table_io_hole_size
          • external_table_io_range_size
          • external_table_csv_max_buffer_size
          • ob_vector_search_strategy
          • function_round_dialect
          • global_index_auto_split_policy
          • json_document_max_depth
          • kv_group_commit_batch_size
          • kv_group_commit_rw_mode
          • kv_hbase_client_scanner_timeout_period
          • kv_ttl_delete_max_ops
          • kv_transport_compress_threshold
          • load_data_diagnosis_log_compression
          • load_data_diagnosis_log_max_size
          • load_vector_index_on_follower
          • ls_scale_out_factor
          • mds_compaction_high_thread_score
          • mds_compaction_mid_thread_score
          • mds_minor_compact_trigger
          • mlog_trim_interval
          • model_max_retries
          • model_request_timeout
          • mv_refresh_concurrency
          • ob_encoding_granularity
          • ob_enable_java_udf
          • ob_enable_python_udf
          • ob_vector_index_active_segment_max_size
          • ob_vector_index_merge_trigger_percentage
          • ob_vector_memory_limit_percentage
          • px_node_policy
          • package_state_sync_max_size
          • px_target_high_watermark
          • px_target_low_watermark
          • px_target_workers_per_cpu
          • recover_table_concurrency
          • recover_table_dop
          • result_cache_max_size
          • result_cache_max_result
          • rest_oauth2_credential_refresh_interval
          • rest_oauth2_credential_evict_time
          • ob_result_cache_evict_percentage
          • schema_history_archive_expire_time
          • spill_compression_codec
          • sql_func_extension_mode
          • sts_credential
          • storage_rowsets_size
          • ttl_duty_time
          • vector_index_memory_saving_mode
          • vector_index_optimize_duty_time
          • zone_deploy_mode
          • zone_disk_balance_tolerance_percentage
          • ap_query_cost_threshold
          • ap_query_route_policy
          • ap_query_replica_fallback
          • caching_sha2_password_digest_rounds
          • default_authentication_plugin
          • ENABLE_OPTIMIZER_ROWGOAL
          • innodb_stats_persistent
          • long_query_time
          • max_execution_time
          • mview_refresh_dop
          • ob_compatibility_control
          • ob_compatibility_version
          • ob_enable_ps_parameter_anonymous_block
          • ob_enable_pl_async_commit
          • ob_table_access_policy
          • ob_udf_cost_factor
          • ob_udf_selectivity
          • ob_security_version
          • plsql_ccflags
          • pid_file
          • plsql_can_transform_sql_to_assign
          • port
          • query_rewrite_enabled
          • query_rewrite_integrity
          • socket
          • SQL_TRANSPILER
          • enable_sql_plan_monitor
          • ob_hnsw_ef_search
          • ob_ivf_nprobes
          • ob_sparse_drop_ratio_search
      • MySQL-compatible mode
        • 0001 ~ 3999
        • 4000 ~ 4499
        • 9000 ~ 9499
        • 10000 ~ 12000
      • Oracle-compatible mode
        • OBE-00000 to OBE-00999
        • OBE-01000 to OBE-01499
        • OBE-01500 to OBE-01999
        • OBE-02000 to OBE-04999
        • OBE-05000 to OBE-10000
        • OBE-10000 to OBE-19999
        • OBE-20000 to OBE-29999
        • OBE-30000 to OBE-49999
        • OBE-50000 to OBE-99999
          • Generate an ASH report
          • Analyze an ASH report
          • 500.execution-plan-operator
          • Parallel DDL
        • Parallel execution plans
          • Set concurrent execution
              • Asynchronous statistics collection
            • OceanBase statistics management practical guide
            • Rule-based query rewrite
            • Optimizer hint
            • SPM plan management
        • SQL Execution Plan Tuning Practices
        • obshell
          • Use cases
            • obshell management
              • Start or stop obshell
              • Upgrade obshell
            • cluster management
              • Deploy an OceanBase cluster
              • Deploy ODP
              • Initiate a cluster-level backup
              • Initiate a tenant-level backup
              • Initiate tenant-level restore
              • Expand a tenant
          • obshell commands
            • Agent commands of obshell
            • Cluster commands of obshell
            • obshell unit commands
            • obshell resource pool commands
            • Tenant command group of obshell
            • Task commands of obshell
            • Backup commands in obshell
            • obshell restore command group
            • obshell recyclebin command group
          • obshell Dashboard
              • Session management
            • Performance monitoring
            • Manage inspection services
            • Manage credentials
            • obshell API requests
              • Set node password
              • Initialize Cluster
              • Upgrade OceanBase Database
              • Scale out a cluster
              • GetObInfo
            • ODP management
              • Deploy ODP
              • Start ODP
              • Stop ODP
              • Upload an ODP installation package
              • Upgrade ODP
              • Destroy ODP
            • Unit config management
              • Create a resource specification
              • Retrieve all resource specifications
              • Query the information of a specified resource specification
              • Delete a resource specification
            • Resource pool management
              • Get information about all resource pools
              • Delete a specified resource pool
              • Query tenant information
              • Change the tenant password
              • Modify the access whitelist of a tenant
              • Modify the primary zone of a tenant
              • Modify tenant system variables
              • Modify tenant configurations
              • Add a tenant replica
              • Modify a tenant replica
              • Delete a tenant replica
              • Get an overview of all tenants
              • Query a system variable of a specified tenant
              • Fuzzy query tenant system variables
              • Query a tenant parameter
              • Fuzzy query tenant parameters
              • Query the session list of a tenant
              • Get tenant session details
              • Obtain tenant session statistics
              • Terminate a tenant session query
              • Query tenant deadlock history
            • Backup management
              • Set the backup configuration for a tenant
              • Set cluster-level backup configurations
              • Update the backup configuration of a tenant
              • Update the cluster-level backup configuration
              • Initiate a backup for a single tenant
              • View information about a backup task for a tenant
              • View cluster-level backup tasks
              • Modify the backup status of a tenant
              • Modify the status of cluster-level backups
              • Modify the log archiving status of a tenant
              • Modify the log archiving status of a cluster
            • Restore management
              • Initiate tenant restore
              • View tenant recovery
              • Cancel tenant restore
            • Inspection service management
              • Trigger an inspection
              • Query inspection history
              • Obtain an inspection report
            • Recycle bin management
              • Query all tenant information in the recycle bin
              • Restore a tenant from the recycle bin
              • Clear a tenant from the recycle bin
            • Credential management
              • Create credentials
              • Obtain credentials
              • Update credentials
              • Delete a credential
              • Batch delete credentials
              • Query the credential list
              • Verify credentials
              • Batch verify credentials
              • Update the credential encryption key
            • Other APIs
          • SDK references
                • Upgrade agents
                • Set node password
                • Query the status of a node
                • Initialize a cluster
                • Start a cluster
              • ODP management
                • Deploy ODP
                • Start ODP
                • Stop ODP
                • Upgrade ODP
                • Destroy ODP
                • Obtain information about all resource specifications
                • Query information about a specified resource unit
                • Delete a resource pool
                • Change the password of a tenant
                • Modify tenant parameters
                • Query the overview of all tenants
                • Query tenant system variables
                • Query tenant configuration items
              • Backup management
                • Configure the backup settings for a tenant
                • Configure cluster-level backup settings
                • Update cluster-level backup configuration
                • View a backup task of a tenant
                • View cluster-level tenant backup tasks
                • Change the log archiving status of a tenant
                • Restore a single tenant
                • Cancel tenant restoration
                • Get information about all tenants in the recycle bin
                • Purge a tenant from the recycle bin
                • Operate a task
                • Query all unfinished tasks
              • Other APIs
                • Upload an RPM package
            • GO
              • Quick Start with obshell-sdk-go
                • Upgrade agents
                • Start a cluster
                • Query all resource specifications
                • Query the specifications of a specified resource
                • Drop a resource unit configuration
                • Change a tenant password
                • Modify the tenant access whitelist
              • Backup management
                • Set the cluster-level backup configuration
                • Update the backup configuration for a tenant
                • View a backup task for a tenant
                • Modify the status of a cluster-level backup
                • Modify the status of cluster-level log archiving
                • Initiate a restore for a single tenant
                • Purge tenants from the recycle bin
                • Operate a task
              • Other APIs
          • Release notes
            • V4.4
              • OceanBase Shell V4.4.0.0 for local clusters
              • OceanBase Shell V4.3.2.1
              • OceanBase Shell V4.3.2.0
              • OceanBase Shell V4.3.1.0 for local clusters
        • obd
            • test_io_device
            • io_adapter_benchmark
        • sql_diagnoser
          • Install and use SQL diagnoser sql_diagnoser
            • Install sql_diagnoser
            • Use sql_diagnoser
          • sql_diagnoser parameters
            • API operations
      • Log analysis
        • oblogminer
          • Install oblogminer
        • obloader and obdumper
        • oblogproxy
            • Sample configuration file
            • General obcdc parameters
          • Throttling
      • Stress testing tools
    • OceanBase plugin
      • Overview of OceanBase plugin
      • Tokenizer plugin
      • MySQL external table plugin
    • Products
    • SQL FAQ
    • Deployment FAQ
    • FAQ about columnstores
    • Version number guidelines
    • Release history of OceanBase Database Enterprise Edition
    • Release notes of OceanBase Database Community Edition
      • V4.6
        • OceanBase Database Enterprise Edition V4.6.0
      • V4.5
        • OceanBase Database Enterprise Edition V4.5.0
      • V4.4
        • OceanBase Database Enterprise Edition V4.4.2
        • OceanBase Database Enterprise Edition V4.3.5
        • OceanBase Database Enterprise Edition V4.3.1
      • V4.5
        • OceanBase Database Community Edition V4.5.0
      • V4.4
        • OceanBase Database Community Edition V4.4.2
        • OceanBase Database Community Edition V4.3.5
  4. V5.0.1
Connect to OceanBase Database by using a Tomcat connection pool
Last Updated:2026-09-28 08:52:25
Step 1: Import the tomcat-oceanbase-client project into IntelliJ IDEA
Step 2: Obtain the connection information of OceanBase Database
Step 3: Modify the database connection information in the tomcat-oceanbase-client project
Step 4: Set up the Tomcat runtime environment of the tomcat-oceanbase-client project
Step 5: Run the tomcat-oceanbase-client project
Project code introduction
Code in the pom.xml file
Code in the application.properties file
Code in the web.xml file
Code in the UserConfig.java file
Code in the UserController.java file
Code in the User.java file
Complete code examples
This topic introduces how to build an application by using a Tomcat connection pool, OceanBase Connector/J, and OceanBase Database. It also covers the use of the application for fundamental database operations, including table creation, data insertion, data deletion, data updating, and data query.
Download the tomcat-oceanbase-client sample project
  • You have installed OceanBase Database.
  • You have installed Java Development Kit (JDK) 1.8 and Maven.
  • You have installed IntelliJ IDEA.
The tool used to run the sample code in this topic is IntelliJ IDEA 2021.3.2 (Community Edition), but you can also choose a tool that suits your personal preference to run the code.
The steps outlined in this topic are for the Windows environment. If you are using a different operating system or compiler, the steps may vary slightly.
  1. Import the tomcat-oceanbase-client project into IntelliJ IDEA.
  2. Obtain the connection information of OceanBase Database.
  3. Modify the database connection information in the tomcat-oceanbase-client project.
  4. Set up the Tomcat runtime environment of the tomcat-oceanbase-client project.
  5. Run the tomcat-oceanbase-client project.
  1. Start IntelliJ IDEA and choose File > Open....
    file
  2. In the Open File or Project window, select the project files and click OK to import the files.
  3. IntelliJ IDEA automatically recognizes the files and displays the project's directory structure, file list, module list, dependency relationships, and other details in the Project window. This window is typically positioned on the left side of the IntelliJ IDEA interface and is generally open by default. If the Project window is closed, you can reopen it by choosing View > Tool Windows > Project in the menu bar or by using the shortcut Alt + 1.
    When you import a project using IntelliJ IDEA, it will automatically detect the pom.xml file in the project, download the required dependency libraries based on the described dependencies in the file, and add them to the project.
  4. View the project.
    Tomcat
  1. Contact the deployment personnel or administrator of OceanBase Database to obtain the connection string.
    obclient -hxx.xx.xx.xx -P2883 -uroot@sys#cluster -p**** -A
  2. Fill in the URL below based on the OceanBase Database connection string.
    The URL of OceanBase Database is required in the application.properties file.
    jdbc:oceanbase://host:port/schema_name?user=$user_name&password=$password&characterEncoding=UTF-8
    where
    • host specifies the IP address for connecting to OceanBase Database. For connection through OceanBase Database Proxy (ODP), this parameter is the IP address of an ODP. For direct connection, this parameter is the IP address of an OBServer node.
    • port specifies the port for connecting to OceanBase Database. For connection through ODP, the default value is 2883, which can be customized when ODP is deployed. For direct connection, the default value is 2881, which can be customized when OceanBase Database is deployed.
    • schema_name specifies the name of the schema to be accessed.
    • user_name specifies the tenant account. For connection through ODP, the tenant account can be in the username@tenant name#cluster name or cluster name:tenant name:username format. For direction connection, the tenant account is in the username@tenant name format.
    • password specifies the password of the account.
    • characterEncoding specifies the character encoding format for the URL of OceanBase Database. The default value is utf8.
For more information about URL parameters, see Database URL.
Modify the database connection information in the application.properties file based on the information obtained in Step 2.
Here is an example:
  • The name of the database driver is com.oceanbase.jdbc.Driver.
  • The IP address of the OBServer node is 10.10.10.1.
  • The port is 2881.
  • The name of the schema to be accessed is SYS.
  • The tenant account is sys@xyoracle, where xyoracle is an Oracle user tenant created in OceanBase Database, and sys is the username of the xyoracle tenant.
  • The password is ******.
The sample code is as follows:
#Apache Commons DBCP2 Connection Pool
#Database Connection Pool Driver Class Name
db.app.pool.driverClassName=com.oceanbase.jdbc.Driver
#Database URL
db.app.pool.url=jdbc:oceanbase://10.10.10.1/SYS?characterEncoding=UTF-8
#Database username
db.app.pool.username=sys@xyoracle
#Database password
db.app.pool.password=******
#Initial size of connection pool
db.app.pool.initialSize=3
#Maximum number of connections in the connection pool
db.app.pool.maxTotal=10
#Maximum number of idle connections in the connection pool
db.app.pool.maxIdle=20
#Minimum number of idle connections in the connection pool
db.app.pool.minIdle=5
#Maximum wait time for obtaining connections (in milliseconds)
db.app.pool.maxWaitMillis=5000
#Verify the connection's query statement
db.app.pool.validationQuery=select 1 from dual
  1. Download Tomcat 8.5.95.
    Download the package of Tomcat 8.5.95 from the official website of Apache Tomcat and decompress the package to the directory where you want to install Tomcat.
  2. Configure Tomcat in IntelliJ IDEA.
    1. Open IntelliJ IDEA and choose File > Settings.
    2. In the Settings window, click Plugins in the left-side navigation pane.
    3. In the Plugins pane that appears, search for Smart Tomcat in the search box and install it.
    4. After Tomcat is installed, click Apply in the lower-right corner. Then, Tomcat Server appears at the bottom of the left-side navigation pane of the Settings window.
    5. Click Tomcat Server and then click the plus sign (+) in the right-side pane that appears.
    6. Select the directory where Tomcat is decompressed, click Apply, and then click OK.
    Tomcat server
  3. Create a Tomcat runtime configuration.
    1. In the top navigation bar of IntelliJ IDEA, choose Run > Edit Configurations.
    2. In the Run/Debug Configurations window, click the plus sign (+) and select Tomcat Server.
    3. Enter the server name in the Name field.
    4. In the Configuration section, select the installed version of Tomcat, change the value of Context path to /, and enter 8080 in the SSL port field.
    5. In the Before launch section, click the plus sign (+) and choose Launch Web Browser.
    6. Click Edit and enter http://localhost:8080/hello/getData in the URL field.
    7. Click Apply and then click OK.
    apache tomcat8.5.95
  4. Run the Tomcat server.
    1. In the top navigation bar of IntelliJ IDEA, select the Tomcat runtime configuration you just created.
    2. Click the Run button (a green triangle) to start the Tomcat server.
      Then, you can view the startup logs of the Tomcat server in the Run window of IntelliJ IDEA.
  1. Specify the running path.
    3. Enter the URL http://localhost:8080/hello/getData in Google Chrome or Internet Explorer to view the running result.
  2. View the running result.
    In the console window of IntelliJ IDEA, view the project logs and output results.
    • Result after data insertion:
      tomcat connection pool test 0
      tomcat connection pool test 1
      tomcat connection pool test 2
      tomcat connection pool test 3
      tomcat connection pool test 4
      tomcat connection pool test 5
      tomcat connection pool test 6
      tomcat connection pool test 7
      tomcat connection pool test 8
      tomcat connection pool test 9
    • Result after data modification:
      -----After modification-----
      Connection pool test 0
      Connection pool test 1
      Connection pool test 2
      Connection pool test 3
      Connection pool test 4
      Connection pool test 5
      Connection pool test 6
      Connection pool test 7
      Connection pool test 8
      Connection pool test 9
    • Return result on the web page:
      Web
Click tomcat-oceanbase-client to download the project code, which is a compressed file named tomcat-oceanbase-client.
After decompressing it, you will find a folder named tomcat-oceanbase-client. The directory structure is as follows:
│--pom.xml
├─.idea
├─src
│  ├─main
│  │  ├─java
│  │  │  └─com
│  │  │      └─oceanbase
│  │  │          └─testtomcat
│  │  │              ├─config
│  │  │              │   └─UserConfig.java
│  │  │              ├─controller
│  │  │              │   └─UserController.java
│  │  │              └─pojo
│  │  │                  └─User.java
│  │  ├─resources
│  │  │    └─application.properties
│  │  └─webapp
│  │      └─WEB-INF
│  │          └─web.xml
│  └─test
│      └─java
└─target
Here is a breakdown of the files and directories:
  • pom.xml: the configuration file of the Maven project, which contains the dependencies, plug-ins, and build details of the project.
  • .idea: the directory for storing project-related configuration information used in the Integrated Development Environment (IDE).
  • src: the directory for storing the source code in the project.
  • main: the directory for storing the main source code and resource files.
  • java: the directory for storing the Java source code.
  • com: the root directory for storing the Java package.
  • oceanbase: the root directory for storing the project.
  • testtomcat: the directory for storing code of the JFinal framework.
  • config: the directory for storing configuration files, including those of the application.
  • UserConfig.java: the user configuration file.
  • controller: the controller directory for storing the controller file of the application.
  • UserController.java: the controller file.
  • pojo: the directory for storing JavaBean or entity classes.
  • User.java: a file for storing user entity classes.
  • resources: the directory for storing resource files, such as configuration files and SQL files.
  • application.properties: the configuration file for storing database connection information.
  • webapp: the directory for storing the static resources and configuration file of the web application.
  • WEB-INF: the directory for storing the configuration file and other protected resource files of the web application.
  • web.xml: the deployment descriptor file of the web application.
  • test: the directory for storing the test code and resource files.
  • target: the directory for storing compiled class files and .jar packages.
If you only want to verify the example, use the default code without making any modifications. Alternatively, you can follow the instructions below to customize the pom.xml file to suit your specific requirements.
To modify the pom.xml file, perform the following steps:
  1. Declare the file.
    Declare the file to be an XML file that uses XML standard 1.0 and character encoding UTF-8.
  2. Configure the namespaces and the POM model version.
    1. xmlns: the default XML namespace, which is set to http://maven.apache.org/POM/4.0.0.
    2. xmlns:xsi: the namespace for XML elements prefixed with xsi, which is set to http://www.w3.org/2001/XMLSchema-instance.
    3. xsi:schemaLocation: the mapping between the XML namespace and its corresponding XML schema definition (XSD) file. The value typically consists of paired strings separated by spaces. Each pair consists of a default XML namespace (http://maven.apache.org/POM/4.0.0) in the first part, and the URI of the corresponding XSD file (http://maven.apache.org/xsd/maven-4.0.0.xsd) in the second part.
    4. <modelVersion>: the POM model version used by the POM file, which is set to 4.0.0.
    <project xmlns="http://maven.apache.org/POM/4.0.0"
          xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
          xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
    </project>
  3. Configure basic information.
    1. <groupId>: the ID of the project group, which is set to com.oceanbase.
    2. <artifactId>: the dependency of the project, which is set to tomcat-oceanbase-client.
    3. <version>: the version of the project, which is set to 1.0-SNAPSHOT.
    4. <packaging>: the packaging mode of the project, which is set to war. In this mode, archive files of the web application are packaged in the WAR format.
     <groupId>com.oceanbase</groupId>
     <artifactId>tomcat-oceanbase-client</artifactId>
     <version>1.0-SNAPSHOT</version>
     <!-- Packaging method (default to jar) -->
     <packaging>war</packaging>
  4. Configure the Maven version.
    Set the source code version and target code version of the compiler to Java 8 by using <maven.compiler.source> and <maven.compiler.target>.
     <properties>
         <maven.compiler.source>8</maven.compiler.source>
         <maven.compiler.target>8</maven.compiler.target>
     </properties>
  5. Configure core dependencies.
    1. Define a dependency named jfinal that belongs to the com.jfinal group and whose version is 5.0.6. With this dependency, you can use features of the JFinal framework.
      <dependency>
          <groupId>com.jfinal</groupId>
          <artifactId>jfinal</artifactId>
          <version>5.0.6</version>
      </dependency>
    2. Define a dependency named druid that belongs to the com.alibaba group and whose version is 1.2.8. With this dependency, you can use the Druid library to manage and optimize the establishment and release of database connections.
      <dependency>
          <groupId>com.alibaba</groupId>
          <artifactId>druid</artifactId>
          <version>1.2.8</version>
      </dependency>
    3. Define a dependency named commons-dbcp2 that belongs to the org.apache.commons group and whose version is 2.9.0. With this dependency, you can use the Apache Commons DBCP2 library to manage and optimize the establishment and release of database connections.
      <dependency>
          <groupId>org.apache.commons</groupId>
          <artifactId>commons-dbcp2</artifactId>
          <version>2.9.0</version>
      </dependency>
    4. Define a dependency named oceanbase-client that belongs to the com.oceanbase group and whose version is 2.4.3. With this dependency, you can use the features of OceanBase Client (OBClient), such as connections, queries, and transactions.
          <dependencies>
          <dependency>
              <artifactId>oceanbase-client</artifactId>
              <version>2.4.3</version>
          </dependency>
          </dependencies>
The application.properties file contains the configuration for connecting to OceanBase Database, including the class name of the database driver, connection URL, username, password, and settings for the connection pool. You can use the following parameters to obtain and manage database connections within the application to perform various database operations:
  • db.app.pool.driverClassName: the database driver used to establish a connection with OceanBase Database, which is set to com.oceanbase.jdbc.Driver.
  • db.app.pool.url: the URL for connecting to the database.
  • db.app.pool.username: the username for connecting to the database.
  • db.app.pool.password: the password for connecting to the database.
  • db.app.pool.initialSize: the initial size of the connection pool, which is set to 3, indicating that three database connections are initially created when the connection pool is started.
  • db.app.pool.maxTotal: the maximum size of the connection pool, which is set to 10, indicating that at most 10 database connections can be created in the connection pool.
  • db.app.pool.maxIdle: the maximum number of idle connections in the connection pool, which is set to 20.
  • db.app.pool.minIdle: the minimum number of idle connections in the connection pool, which is set to 5.
  • db.app.pool.maxWaitMillis: the timeout value for requesting a database connection, which is set to 5000ms. When you request a connection, a timeout exception is thrown if you fail to obtain a connection within 5,000 ms.
  • db.app.pool.validationQuery: the SQL query statement for verifying database connections, which is set to select 1 from dual. When you request a connection from the connection pool, this query statement is executed to verify the connection.
      #Database URL
      db.app.pool.url=jdbc:oceanbase:////host:port/schema_name?characterEncoding=UTF-8
      #Database username
      db.app.pool.username=user_name
      #Database password
The following table describes the general parameters of Tomcat Database Connection Pool (DBCP).
Notice
The actual parameter configurations depend on the project requirements and the characteristics of the database. We recommend that you adjust and configure them based on the actual situation.
Parameter
Default value
username N/A The username for connecting to the database.
password N/A The password for connecting to the database.
url N/A The URL for connecting to the database.
driverClassName N/A The standard Java class name of the database driver.
connectionProperties N/A The connection properties sent to the Java Database Connectivity (JDBC) driver when a connection is established, in the [propertyName=property;] format.
defaultAutoCommit driver default The default auto-commit state when a connection is created in the connection pool. If this parameter is not specified, the setAutoCommit method will not be called.
defaultReadOnly driver default The default read-only state when a connection is created in the connection pool. If this parameter is not specified, the setReadOnly method will not be called.
defaultTransactionIsolation driver default The default transaction isolation level when a connection is created in the connection pool.
defaultCatalog N/A The default connection catalog created in the connection pool.
cacheState true Specifies whether to cache the readOnly and autoCommit settings of connections. If you set the value to true, the current readOnly and autoCommit settings are cached for the first read and for all writes. This eliminates the need of extra database queries for any further getter calls.
defaultQueryTimeout null The query timeout value of the connection creation statement in the connection pool. If the value is not NULL, the specified integer is the query timeout value. If you set the value to NULL, the default timeout value of the driver is used.
enableAutoCommitOnReturn true Specifies whether to check and configure auto-commit for a connection when it is returned to the connection pool.
rollbackOnReturn true Specifies whether to roll back a non-read-only connection for which auto-commit is disabled when it is returned to the connection pool. If you set the value to true, a non-read-only connection for which auto-commit is disabled is rolled back when it is returned to the connection pool.
initialSize 0 The initial number of connections created when the connection pool is started.
maxTotal 8 The maximum number of active connections allocated from the connection pool.
maxIdle 8 The maximum number of idle connections in the connection pool. No extra connection is released when the number of idle connections reaches the specified value. A negative value indicates no limit.
minIdle 0 The minimum number of idle connections in the connection pool. No extra connection is created when the number of idle connections reaches the specified value. The value 0 indicates that no extra connections need to be created.
maxWaitMillis indefinitely The maximum duration for which the connection pool waits for a connection to return before an exception is thrown when no connection is available in the pool, in milliseconds. The value -1 indicates that the waiting duration is unlimited.
validationQuery N/A The SQL query statement for verifying connections. If this parameter is specified, the value must be an SQL SELECT statement that returns at least one row. If this parameter is not specified, the isValid method is called to verify connections.
validationQueryTimeout no timeout The time in seconds before the connection validation query fails. If set to a positive value, this value is passed to the driver's statement via the setQueryTimeout method that is used to execute the validation query.
testOnCreate false Specifies whether to verify a connection object after it is created. If the object cannot be verified, the borrow attempt that triggers the creation of the object will fail.
testOnBorrow true Specifies whether to verify a connection object before it is borrowed from the connection pool. If the object cannot be verified, it is deleted from the connection pool and an attempt will be made to borrow another object.
testOnReturn false Specifies whether to verify a connection object before it is returned to the connection pool.
testWhileIdle false Specifies whether connection objects will be verified by the idle object evictor (if any). If an object fails the verification, it is deleted from the connection pool.
timeBetweenEvictionRunsMillis -1 The amount of time for which the idle object eviction thread sleeps before it runs again, in milliseconds. If you specify a non-positive value, the idle object eviction thread will not run.
numTestsPerEvictionRun 3 The number of objects to check during each running period of the idle object eviction thread.
minEvictableIdleTimeMillis 1000 * 60 * 30 The minimum amount of time for which an object can be idle in the connection pool, in milliseconds.
softMinEvictableIdleTimeMillis -1 The minimum amount of time for which an object can be idle in the connection pool, in milliseconds, with the MinIdle constraint applied.
maxConnLifetimeMillis -1 The maximum lifetime of a connection, in milliseconds. A connection that exceeds its lifetime can no longer be activated, passivated, or verified. The value 0 or a smaller value indicates an unlimited lifetime.
logExpiredConnections true Specifies whether to record expired connections that are closed by the connection pool. The value false specifies to disable log recording for expired connections.
connectionInitSqls null The collection of SQL statements to be initialized when a physical connection is created for the first time. These statements are executed only when a connection is created in the configured connection factory.
lifo true Specifies whether the borrowObject method returns the most recently used connection in the connection pool. If you set the value to true, the borrowObject method returns the most recently used (last in) connection in the connection pool. If you set the value to false, the pool behaves as a first-in, first-out (FIFO) queue, in which idle connections are obtained from the idle instance pool in the order that they are returned to the pool.
poolPreparedStatements false Specifies whether to enable the prepared statement pool.
maxOpenPreparedStatements unlimited The maximum number of open statements that can be allocated from the connection pool. A negative value indicates no limit.
accessToUnderlyingConnectionAllowed false Specifies whether to allow access to the underlying connection.
removeAbandonedOnMaintenance false Specifies whether to remove abandoned connections within the maintenance period of the connection pool. The value true specifies to remove abandoned connections during the maintenance period (when eviction ends). To use this parameter, you must set timeBetweenEvictionRunsMillis to a positive value to enable maintenance.
removeAbandonedOnBorrow false Specifies whether to remove abandoned connections when a connection is borrowed from the connection pool. If you set the value to true, abandoned connections will be removed when a connection is borrowed from the connection pool under the following conditions:
  • getNumActive() > getMaxTotal() - 3
  • getNumIdle() < 2
removeAbandonedTimeout 300 The amount of time elapsed before an abandoned connection is removed, in seconds. This parameter specifies the maximum amount of time that a connection can sit idle before it is considered abandoned and eligible for eviction.
logAbandoned false Specifies whether to record stack traces for application code that abandoned a connection. Recording abandoned statements and connections will increase the overhead for each connection open or new statement because stack traces must be generated.
abandonedUsageTracking false Specifies whether to record stack traces for abandoned connections. If you set the value to true, the connection pool will record a stack trace each time when a method is called in the connection pool and will keep the recent stack trace to facilitate debugging of abandoned connections. However, this will significantly increase the overhead.
fastFailValidation false Specifies whether to quickly fail the verification of connections that throw a fatal SQLException. If set to true, the request to verify the disconnected connection will immediately fail without calling the isValid method of the driver or attempting to execute the verification query. The SQL_STATE codes considered as fatal errors are as follows:
  • 57P01: indicates a shutdown by the administrator.
  • 57P02: indicates a breakdown.
  • 57P03: indicates that a connection cannot be established now.
  • 01002: indicates an SQL92 disconnection error.
  • JZ0C0: indicates a Sybase disconnection error.
  • JZ0C1: indicates a Sybase disconnection error.
  • Any SQL_STATE code starting with 08
To overwrite this default set of disconnection codes, specify the disconnectionSqlCodes parameter.
disconnectionSqlCodes null A list of comma-separated SQL_STATE codes that indicate fatal disconnection errors. To use this parameter, you must set fastFailValidation to true.
jmxName N/A A data source object that can be operated and monitored. The data source must be registered as a Java Management Extensions (JMX) MBean under the specified name. This name must comply with the syntax for JMX object names. For more information, see javadoc.
The web.xml file is used to configure filters for web applications.
To configure the web.xml file, perform the following steps:
  2. Configure the XML namespace and the XML model version.
    1. xmlns:xsi: the namespace for XML elements prefixed with xsi, which is set to http://www.w3.org/2001/XMLSchema-instance.
    2. xmlns: the default XML namespace, which is set to http://java.sun.com/xml/ns/javaee.
    3. xsi:schemaLocation: the mapping between the XML namespace and its corresponding XML schema definition (XSD) file. The value typically consists of paired strings separated by spaces. Each pair consists of a default XML namespace (http://java.sun.com/xml/ns/javaee) in the first part, and the URI of the corresponding XSD file (http://java.sun.com/xml/ns/javaee/web-app_3_0.xsd) in the second part.
    4. <id> and <version>: the ID and version of the web application, which are respectively set to WebApp_ID and 3.0.
     <web-app xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
              xmlns="http://java.sun.com/xml/ns/javaee"
              xsi:schemaLocation="http://java.sun.com/xml/ns/javaee http://java.sun.com/xml/ns/javaee/web-app_3_0.xsd"
              id="WebApp_ID"
              version="3.0">
  3. Configure a JFinal filter.
    Configure a filter named jfinal. With this filter, you can use the JFinal framework in the web application. Set the class of the filter to com.jfinal.core.JFinalFilter. Configure the initialization parameter configClass to set the location of the configuration class of the JFinal framework to com.oceanbase.testtomcat.config.UserConfig. The JFinal filter allows you to use the JFinal framework in the web application and to configure the behavior of the JFinal framework based on the specified configuration class.
     <filter>
         <filter-name>jfinal</filter-name>
         <filter-class>com.jfinal.core.JFinalFilter</filter-class>
         <init-param>
             <param-name>configClass</param-name>
             <!-- your jfinal configuration location -->
             <param-value>com.oceanbase.testtomcat.config.UserConfig</param-value>
         </init-param>
     </filter>
  4. Configure mappings of the JFinal filter.
    Apply the JFinal filter named jfinal to all request paths, namely, to all requests in the application.
     <filter-mapping>
         <url-pattern>/*</url-pattern>
     </filter-mapping>
The UserConfig.java file is used to configure the routes, plug-ins, database connections, and other information of the application.
To configure the UserConfig.java file, perform the following steps:
  1. Reference other classes and APIs.
    Declare this file to contain the following APIs and classes:
    • StatFilter class: collects statistics about the database access performance.
    • JdbcConstants class: defines database type constants.
    • WallFilter class: prevents SQL injection attacks.
    • PropKit class: reads configuration files.
    • ActiveRecordPlugin class: operates the database.
    • Db class: executes database operations.
    • OracleDialect class: specifies a dialect of the database.
    • DruidPlugin class: connects to the database.
    • Engine class: configures the template engine.
    • UserController class: processes user requests.
    • User class: transmits and stores user data.
    import com.alibaba.druid.filter.stat.StatFilter;
    import com.alibaba.druid.util.JdbcConstants;
    import com.alibaba.druid.wall.WallFilter;
    import com.jfinal.config.*;
    import com.jfinal.kit.PropKit;
    import com.jfinal.plugin.activerecord.ActiveRecordPlugin;
    import com.jfinal.plugin.activerecord.Db;
    import com.jfinal.plugin.activerecord.dialect.OracleDialect;
    import com.jfinal.plugin.druid.DruidPlugin;
    import com.jfinal.template.Engine;
    import com.oceanbase.testjfinal.controller.UserController;
    import com.oceanbase.testjfinal.pojo.User;
  2. Define the UserConfig class.
    Rewrite the methods in the JFinalConfig class to configure constants, routes, plug-ins, database connections, and other information.
    1. Define the configConstant method.
      Use this method to configure constants of the JFinal framework and use PropKit to read configurations from the configuration file.
      @Override
      public void configConstant(Constants constants) {
          PropKit.use("application.properties");
    2. Define the configRoute method.
      Use this method to configure route mappings. Call the routes.add method to map the "/hello" path to the default access page of the UserController class.
      @Override
      public void configRoute(Routes routes) {
          routes.add("/hello", UserController.class, "/");
    3. Define the configEngine method.
      Use this method to configure the template engine.
      @Override
      public void configEngine(Engine engine) {
    4. Define the configPlugin method.
      Use this method to configure plug-ins of the application. Call the init method to initialize database connections and schemas, create the DruidPlugin and ActiveRecordPlugin plug-ins, and add them to plugins. Call the addMapping method of activeRecordPlugin to add the mappings between database tables and entity classes, so as to map the TEST_USER table to the User class.
      @Override
      public void configPlugin(Plugins plugins) {
          init();
          DruidPlugin druidPlugin = createDruidPlugin();
          plugins.add(druidPlugin);
          ActiveRecordPlugin activeRecordPlugin = createActiveRecordPlugin(druidPlugin);
          activeRecordPlugin.addMapping("TOMCAT_TEST", User.class);
          plugins.add(activeRecordPlugin);
    5. Define the createDruidPlugin method.
      Use this method to create the DruidPlugin plug-in and configure relevant parameters, including the connection pool size, SQL firewall, and connection error handling methods.
      • Call the get method of PropKit to obtain database connection properties from the configuration file, including the URL, username, password, and driver class. Then, create a DruidPlugin object and use the obtained property values to initialize the DruidPlugin object.
      • Call the addFilter method to add a StatFilter instance to DruidPlugin to collect statistics about the database access performance. Create a WallFilter instance, call the setDbType method to set the database type to OceanBase Database, and then add the instance to DruidPlugin for SQL firewall-based filtering.
      • Call the setInitialSize method to set the initial size of the connection pool, the setMaxPoolPreparedStatementPerConnectionSize method to set the maximum number of prepared statements allowed in each connection pool, the setTimeBetweenConnectErrorMillis method to set the time to wait before another connection attempt is made after an error, and the setValidationQuery method to set the query statement for verifying connections. Then, return the created DruidPlugin instance.
        private DruidPlugin createDruidPlugin() {
            DruidPlugin druidPlugin = new DruidPlugin(
                PropKit.get("db.app.pool.url"),
                PropKit.get("db.app.pool.username"),
                PropKit.get("db.app.pool.password"),
                PropKit.get("db.app.pool.driverClassName")
            druidPlugin.addFilter(new StatFilter());
            WallFilter wallFilter = new WallFilter();
            wallFilter.setDbType(JdbcConstants.OCEANBASE);
            druidPlugin.addFilter(wallFilter);
            druidPlugin.setInitialSize(PropKit.getInt("db.app.pool.initialSize"));
            druidPlugin.setMaxPoolPreparedStatementPerConnectionSize(PropKit.getInt("db.app.pool.maxTotal"));
            druidPlugin.setTimeBetweenConnectErrorMillis(PropKit.getInt("db.app.pool.maxWaitMillis"));
            druidPlugin.setValidationQuery("select 1 from dual");
            return druidPlugin;
    6. Define the init method.
      Use this method to initialize database connections and create database tables. Call the initDbConnection method to initialize the database connections and return an ActiveRecordPlugin instance. Execute an SQL statement to query whether the user table TOMCAT_TEST exists. If the TOMCAT_TEST table exists, execute the DROP TABLE TOMCAT_TEST statement to drop this table. Then, execute the CREATE TABLE statement to create a database table named TOMCAT_TEST, which contains the ID and USERNAME fields. Close the connection of the ActiveRecordPlugin plug-in to release the database connection.
      public void init() {
          ActiveRecordPlugin arp = initDbConnection();
          // Check if table exists
          boolean tableExists = Db.queryInt("SELECT COUNT(*) FROM USER_TABLES WHERE TABLE_NAME = 'TOMCAT_TEST'") > 0;
          // Drop table if it exists
          if (tableExists) {
              Db.update("DROP TABLE TOMCAT_TEST");
          // Create table
          String sql = "CREATE TABLE TOMCAT_TEST (ID NUMBER(10), USERNAME VARCHAR2(50))";
          Db.update(sql);
          arp.stop();
    7. Define the initDbConnection method.
      Use this method to initialize database connections. First, call the createDruidPlugin method to create a DruidPlugin object and assign it to the druidPlugin variable. This method is used to create and configure DruidPlugin objects for database connection pool management. Then, call the createActiveRecordPlugin method to create an ActiveRecordPlugin object and pass the DruidPlugin object as a parameter to the createActiveRecordPlugin method. This method is used to create and configure ActiveRecordPlugin objects for database operation management. Call the druidPlugin.start method to start the DruidPlugin object to initialize the database connection pool. Finally, call the activeRecordPlugin.start method to start the ActiveRecordPlugin object. This method initializes database operation settings based on configurations.
      private ActiveRecordPlugin initDbConnection() {
          druidPlugin.start();
          activeRecordPlugin.start();
          return activeRecordPlugin;
    8. Define the ConfigInterceptor and ConfigHandler methods.
      Use these methods for global configuration during system initialization.
      @Override
      public void configInterceptor(Interceptors interceptors) {
      @Override
      public void configHandler(Handlers handlers) {
The UserController.java file uses the getData method to insert data into the database, query data from the database, and return the query result to the client in the JavaScript Object Notation (JSON) format. Use the Db class of the JFinal framework for database operations, and use the custom User class for data mappings so as to return data.
To configure the UserController.java file, perform the following steps:
    • Controller class: processes requests and responses.
    • Record class: performs database operations, such as querying, inserting, updating, and deleting data.
    • ArrayList class: creates an empty list.
    • User class: maps database tables.
    • List API: operates the query result set.
    import com.jfinal.core.Controller;
    import com.jfinal.plugin.activerecord.Record;
    import java.util.ArrayList;
    import java.util.List;
  2. Define the UserController class.
    Use this class to provide a controller for the JFinal framework, and use the getData method to insert data into and query data from the database.
    1. Insert data. Create a dataList list that contains 10 Record objects. Each Record object has unique ID and USERNAME values. Use the Db.batchSave method to save the records in the dataList list to a database table named TOMCAT_TEST.
              for (int i = 0; i < 10; i++) {
                  Record record = new Record().set("ID", i).set("USERNAME", "Tomcat connection pool test" + i);
                  dataList.add(record);
              Db.batchSave("TOMCAT_TEST", dataList, dataList.size());
    2. Query data. Use the Db.find method to execute an SQL query and store the query result in the resultList list. Use an enhanced FOR loop to traverse each Record object in the resultList list. Use the getStr method to obtain values of specified fields in a Record object and use the System.out.println method to return these values.
          List<Record> resultList = Db.find("SELECT * FROM TOMCAT_TEST");
          for (Record result : resultList) {
              System.out.println(result.getStr("USERNAME"));
    3. Modify data. Use a loop to perform 10 rounds of iterations and execute an update statement in each iteration. Call the Db.update method to update records in the TOMCAT_TEST table based on specified conditions.
              Db.update("UPDATE TOMCAT_TEST SET USERNAME = 'Connection pool test" + i + "' WHERE ID = " + i);
    4. Query the modified data. Query the TOMCAT_TEST table and save the query result in modifiedList. Return the information in the -----After modification----- section. Traverse modifiedList and return the USERNAME value of each record. Use the renderJson method to render the response message Data retrieved successfully into the JSON format and return it to the client.
              List<Record> modifiedList = Db.find("SELECT * FROM TOMCAT_TEST");
              System.out.println("-----After modification-----");
              for (Record modified : modifiedList) {
                  System.out.println(modified.getStr("USERNAME"));
              renderJson("Data retrieved successfully");
The User.java file is used to map database tables and Java objects.
To configure the User.java file, perform the following steps:
  1. Reference the Model class.
    Use the Model class to map database tables and operate data.
  2. Define the User class.
    The User class inherits the methods provided in the Model class for database operations.
    import com.jfinal.plugin.activerecord.Model;
        public class User extends Model<User> {
            public static final User dao = new User();
pom.xml
web.xml
UserConfig.java
UserController.java
User.java
    <properties>
    </properties>
    <dependencies>
        <dependency>
        </dependency>
        <dependency>
        </dependency>
        <dependency>
        </dependency>
        <dependency>
        </dependency>
    </dependencies>
</project>
    #Database URL
    db.app.pool.url=jdbc:oceanbase://host:port/schema_name?characterEncoding=UTF-8
    #Database username
    #Database password
<web-app xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://java.sun.com/xml/ns/javaee" xsi:schemaLocation="http://java.sun.com/xml/ns/javaee http://java.sun.com/xml/ns/javaee/web-app_3_0.xsd" id="WebApp_ID" version="3.0">
    <filter>
        <init-param>
            <param-value>com.oceanbase.testjfinal.config.UserConfig</param-value>
        </init-param>
    </filter>
    <filter-mapping>
    </filter-mapping>
</web-app>
package com.oceanbase.testtomcat.config;
import com.oceanbase.testtomcat.controller.UserController;
import com.oceanbase.testtomcat.pojo.User;
public class UserConfig extends JFinalConfig {
    @Override
        // Read the properties configuration.
    @Override
        // Set the default access page for project startup, which does not need to be set in the web.
        routes.add("/hello", UserController.class);
    @Override
    @Override
        init();
        return druidPlugin;
    private ActiveRecordPlugin createActiveRecordPlugin(DruidPlugin druidPlugin) {
        ActiveRecordPlugin activeRecordPlugin = new ActiveRecordPlugin(druidPlugin);
        activeRecordPlugin.setDialect(new OracleDialect());
        // Check whether the table exists.
        // Drop the table if it exists.
        if (tableExists) {
        // Create a table.
        Db.update(sql);
        arp.stop();
    @Override
    @Override
package com.oceanbase.testtomcat.controller;
public class UserController extends Controller {
    public void getData() {
        try {
            List<Record> dataList = new ArrayList<>();
            // Insert data.
            // Query data.
            // Modify data.
            // Query the modified data.
        } catch (Exception e) {
            e.printStackTrace();
            renderJson("Error occurred");
package com.oceanbase.testtomcat.pojo;
For more information about OceanBase Connector/J, see OceanBase Connector/J.
Database connection pool configuration
c3p0
