SQL - V4.2.5
    • Learn OceanBase SQL
      • Before you begin
      • Build a Python application
      • Build a Java application
      • Build a C application
      • Build a Go application
      • Scalable OLTP
      • Experience Operational OLAP
        • Create an external table
          • Error handling for MySQL-compatible applications
        • Configure servers
          • (Optional) Check resources
    • Clear an OceanBase cluster
  • Upgrade
    • Upgrade OceanBase Database Enterprise Edition
      • Upgrade overview
      • Check the status after the upgrade
    • Upgrade OceanBase Database Community Edition
      • Use the LOAD DATA statement to import data
      • Use the `SELECT INTO OUTFILE` statement to export data
    • Bypass import
      • Use the LOAD DATA statement to import data in direct load mode
      • Use the INSERT INTO SELECT statement to import data in direct load mode
            • Configure cgroups
            • Configure cgroups
        • Query tenant and resource information
        • Clone a tenant
        • Cancel tenant cloning
          • Modify a unit config
          • Drop a unit config
        • Manage services
          • Create a service
          • Query the service status
          • Start a service
          • Stop a service
          • Add replicas
          • Remove replicas
          • Migrate replicas
          • Cancel a replica task
        • Transfer a partition
        • Cancel a load balancing job
        • Partition balancing
          • Configure the scheduled partition balancing job
          • Manually trigger a partition balancing job
          • View the parameters of the scheduled partition balancing job
          • Query the scheduling history of the scheduled partition balancing job
          • Query partition balancing jobs and tasks in the background
          • Query the history of partition balancing jobs and tasks in the background
          • View the log restore source
          • Specify log compression
          • Login failure handling
              • Grant privileges to a role
            • Indirect privileges
            • Use a proxy user
        • OBServer node transmission encryption
      • Transparent data encryption
          • Enable TDE for new tables
          • Enable security audit
          • Set audit rules
          • View audit records
          • Disable security audit
          • Audit user login operations
        • View archive parameters
        • Prepare for backup
        • Back up parameters
        • View data backup parameters
        • Automatically clean up expired backups
        • Stop backup cleanup
        • Perform physical restore
        • Perform table restore
        • Cancel table restore
      • Log overview
      • Alert logs
      • Check tenant resource usage
    • Performance tunning
      • Identify bottlenecks on a link
            • Suboptimal plans
            • Cardinality
      • SQL tunning
                • Automatically collect statistics
              • Hash joins
              • Merge joins
          • Schema specifications
      • Bootstrap
        • Absence of the leader
        • Transaction-related errors
        • Long-running transaction
        • Suspended transaction
        • Other issues
          • Exceptions of SQL queries
    • OceanBase concepts
            • Temporary table
            • Index overview
            • View categorization
            • Data operations in views
            • Data access from views
            • Updatable views
            • About indexes
            • Updatable views
        • Log streams and replicas
          • Replica type
            • Read-only replicas
          • Data balancing
            • Intra-tenant balancing
          • Cluster scaling
          • Tenant resource scaling
            • DCL statements
            • Optimize parameters for parallel query
              • MySQL Mode
            • Lock Wait Mgr
          • Weak-consistency read
          • Minor compaction
          • Major compaction
        • Multi-level caches
          • Backup directory structures
          • Restore process
        • Configuration files
          • Adaptive major compactions
        • Memory usage control
        • FAQ about memory
          • Alter a table
          • Change the replicated table attribute
          • Drop a partition
          • Drop a partition
            • ADD REPLICA
            • ADD RESTORE SOURCE
            • BACKUP CLUSTER PARAMETERS
            • BALANCE JOB
            • CANCEL REPLICA TASK
            • CHANGE TENANT
            • CLEAR RESTORE SOURCE
            • CREATE LS
            • MIGRATE REPLICA
            • MODIFY LS
            • MODIFY PAXOS_REPLICA_NUM
            • MODIFY REPLICA
            • MODULE DATA
            • FLASHBACK STANDBY LOG
            • REMOVE REPLICA
            • RESTORE PREVIEW
            • SERVICE_NAME
            • LOAD MODULE DATA
            • CHECK MODULE DATA
          • SHOW RESTORE PREVIEW
        • User tenants (MySQL mode)
                • Integer data types
                • Fixed-point types
                • Floating-point data types
                • Bit value data type
                • BLOB types
                • LOB types
              • SET type
                • Convert a JSON data type
                • Overview of spatial data types
                • Spatial reference systems (SRS)
                • Create a spatial column
                • Create a spatial index
              • Strings
              • Numbers
              • Datetime values
              • NULLs
            • Overview of operators
            • Assignment operators
            • BINARY operator
          • Sequence pseudo-columns
                • DECODE_TRACE_ID
                • TO_PINYIN
              • ENHANCED_AES_ENCRYPT
              • ENHANCED_AES_DECRYPT
              • PASSWORD
              • SM3
              • SM4_ENCRYPT
              • SM4_DECRYPT
              • Search JSON text functions
              • Spatial relation functions
              • Geometry property functions
              • _ST_GeoHash
              • RELEASE_ALL_LOCKS()
            • GTID function
              • GTID_SUBSET()
              • GTID_SUBTRACT()
              • WAIT_FOR_EXECUTED_GTID_SET()
              • WAIT_UNTIL_SQL_THREAD_AFTER_GTIDS()
            • Audit functions
              • AUDIT_LOG_FILTER_SET_FILTER
              • AUDIT_LOG_FILTER_SET_USER
            • Common table expressions
            • ALTER COMPILE
            • ALTER SERVER
            • ALTER TABLESPACE
            • ALTER EVENT
            • ALTER LOGFILE GROUP
            • CACHE INDEX
            • CHECK TABLE
            • CREATE FORMAT OUTLINE
            • CREATE LOGFILE GROUP
            • DROP RESTORE POINT
            • CREATE SERVER
            • CHECKSUM TABLE
            • CREATE EVENT
            • DROP EVENT
            • DROP FORMAT OUTLINE
            • DROP SERVER
            • DROP LOGFILE GROUP
            • FLUSH
            • HANDLER
            • INSTALL PLUGIN
            • LOAD INDEX INTO CACHE
            • REPAIR TABLE
              • SELECT statement
              • OVER clause
            • UNLOCK TABLES
            • UNINSTALL PLUGIN
            • XA transaction
        • User tenants (Oracle mode)
          • Introduction to SQL
            • Sequence pseudo columns
            • ORA_ROWSCN pseudocolumn
            • ROWNUM pseudocolumn
            • ROWID pseudocolumn
              • Rowid data types
                • Conversion of the XMLType data type
                • Create a spatial data column
              • Data type precedence
                • Date literals
                • Timestamp literals
              • Interval literals
              • RR datetime format element
              • NULLs in SQL functions
              • Comments on SQL statements
                  • Hints related to joins
                  • Hints related to query strategies
                  • Other hints
                • Reference a DBLink
              • Access partitioned tables and indexes
                • EXTRACT(datetime)
                • ROUND (date)
                • TRUNC (date)
                • TO_NCHAR(character)
                • TO_NCHAR(datetime)
                • TO_NCHAR(number)
                • TO_PINYIN
                  • XMLCONCAT
                  • XMLFOREST
                  • EXISTSNODE
              • Spatial-functions
              • REGR_(Linear Regression)
              • GROUP_ID
              • GROUPING_ID
              • Analytic functions
            • Table functions
              • Table function
            • CURSOR expressions
            • Condition precedence
            • NULL conditions
            • Simple queries
            • Hierarchical queries
            • Composite queries
            • Join queries
            • DUAL table query
              • ALTER SYSTEM PARAMETER
                • Set-based SELECT
                • WITH CLAUSE
          • SELECT statements
          • DML statement writing standards
          • Multi-table join
          • Table scan
          • Cache
          • Hint
          • Other related specifications
          • Read with weak consistency
          • Pagination
          • PL overview
        • PL reference (MySQL mode)
            • Events
            • INFORMATION_SCHEMA.TRIGGERS
            • Procedure scope
            • Overview of system packages
            • DBMS_BALANCE
              • Overview of DBMS_BALANCE
              • SET_BALANCE_WEIGHT
              • CLEAR_BALANCE_WEIGHT
              • TRIGGER_PARTITION_BALANCE
            • DBMS_LIMIT_CALCULATOR
            • DBMS_DATA_DICT
              • DBMS_DATA_DICT
        • PL reference (Oracle mode)
            • Lexical elements
            • Declaration
            • Identifier scope and visibility
            • Assignment
            • Error-reporting functions
            • BOOLEAN type
            • Sequential control
            • Collection constructors
            • RECORD
              • Explicit cursors
              • Use a FOR loop to traverse a cursor
              • Modify and drop a cursor
            • FORALL and BULK COLLECT
            • Execute dynamic SQL
            • Privilege control
              • Application
            • PL Database Link
            • INSTEAD OF DML triggers
            • Composite DML triggers
            • System triggers
            • Create a package
            • Manage packages
            • Compile-time warnings
            • DBMS_BALANCE
            • DBMS_JOB
              • BROKEN
              • CHANGE
              • NEXT_DATE
              • RUN
              • SUBMIT
              • USER_EXPORT
              • WHAT
              • GET_TABLE_INDEX_DDL
              • OB_SESSION_TRACE_ENABLE
              • OB_SESSION_TRACE_DISABLE
              • OB_CLIENT_ID_TRACE_ENABLE
              • OB_CLIENT_ID_TRACE_DISABLE
              • OB_MOD_ACT_TRACE_ENABLE
              • OB_MOD_ACT_TRACE_DISABLE
              • OB_TENANT_TRACE_ENABLE
              • OB_TENANT_TRACE_DISABLE
              • STOP_JOB
              • VARIABLE_VALUE
              • Overview of DBMS_UTILITY
              • COMMA_TO_TABLE
              • DBMS_XA constants
            • DBMS_PROFILER
              • START_PROFILER
              • STOP_PROFILER
              • PAUSE_PROFILER
              • RESUME_PROFILER
              • FLUSH_DATA
              • GET_VERSION
              • INTERNAL_VERSION_CHECK
              • ROLLUP_UNIT
              • ROLLUP_RUN
              • OB_INIT_OBJECTS
              • OB_DROP_OBJECTS
            • DBMS_DDL
              • Overview of DBMS_DDL
              • WRAP
              • CREATE_WRAPPED
            • UTL_RECOMP
              • RECOMP_PARALLEL
              • RECOMP_SERIAL
              • PARALLEL_SLAVE
            • UTL_TCP
              • Overview of UTL_TCP
              • OPEN_CONNECTION
              • CLOSE_CONNECTION
              • CLOSE_ALL_CONNECTIONS
              • WRITE_LINE
              • WRITE_TEXT
              • WRITE_RAW
              • GET_TEXT
            • UTL_SMTP
              • Overview of UTL_SMTP
              • OPEN_CONNECTION
              • CLOSE_CONNECTION
              • QUIT
              • AUTH
              • COMMAND
              • COMMAND_REPLIES
              • HELO
              • EHLO
              • MAIL
              • RCPT
              • OPEN_DATA
              • WRITE_DATA
              • WRITE_RAW_DATA
              • CLOSE_DATA
              • DATA
              • VRFY
              • NOOP
              • RSET
              • Overview of the ANYDATA type
              • BEGINCREATE static stored procedure
              • ENDCREATE member procedure
              • GET* member function
              • PIECEWISE member stored procedure
              • SET* member stored procedure
              • Overview of XMLType
              • EXISTSNODE
          • Reserved PL keywords
      • Data type conversion behavior in MySQL tenants in strict mode
      • System views overview
          • information_schema.events
          • mysql.audit_log_filter
          • mysql.audit_log_user
          • oceanbase.CDB_CKPT_HISTORY
          • oceanbase.CDB_INDEX_USAGE
          • oceanbase.CDB_OB_LS_REPLICA_TASK_HISTORY
          • oceanbase.CDB_OB_OBJECT_BALANCE_WEIGHT
          • oceanbase.CDB_OB_SERVICES
          • oceanbase.CDB_OB_TENANT_FLASHBACK_LOG_SCN
          • oceanbase.CDB_WR_SQL_PLAN
          • oceanbase.DBA_INDEX_USAGE
          • DBA_OB_FORMAT_OUTLINES
          • oceanbase.DBA_OB_SERVICES
          • oceanbase.DBA_OB_SPM_EVO_RESULT
          • oceanbase.DBA_OB_TENANT_FLASHBACK_LOG_SCN
          • oceanbase.DBA_RECYCLEBIN
          • oceanbase.DBA_WR_SQL_PLAN
          • oceanbase.DBA_OB_LICENSE
          • GV$OB_RES_MGR_SYSSTAT
          • GV$OB_SESSION_PS_INFO
          • GV$OB_TENANT_RESOURCE_LIMIT
          • gv$tenant
          • GV$UNIT
          • GV$OB_KV_CLIENT_INFO
          • GV$OB_KV_CONNECTIONS
          • V$OB_KV_CONNECTIONS
          • GV$OB_CGROUP_CONFIG
          • V$OB_CGROUP_CONFIG
          • V$OB_COMPATIBILITY_CONTROL
          • V$OB_RES_MGR_SYSSTAT
          • V$OB_SESSION_PS_INFO
          • V$OB_TENANT_RESOURCE_LIMIT
          • V$RESTORE_POINT
          • V$UNIT
          • V$OB_KV_CLIENT_INFO
          • V$OB_KV_GROUP_COMMIT_STATUS
          • oceanbase.DBA_OB_KV_REDIS_TABLE
          • oceanbase.DBA_OB_OBJECT_BALANCE_WEIGHT
          • oceanbase.DBA_OB_TABLE_SPACE_USAGE
          • V$OB_TRANSACTION_SCHEDULERS
          • V$RESTORE_POINT
          • ALL_OB_SOURCE
          • ALL_PLSQL_TYPES
          • ALL_PLSQL_COLL_TYPES
          • ALL_PLSQL_TYPE_ATTRS
          • DBA_INDEX_USAGE
          • DBA_OB_PL_OBJ_CACHE_STATUS
          • DBA_OB_SERVICES
          • DBA_OB_SYS_VARIABLES
          • DBA_OB_SPM_EVO_RESULT
          • DBA_OB_SOURCE
          • DBA_PLSQL_TYPES
          • DBA_PLSQL_COLL_TYPES
          • DBA_PLSQL_TYPE_ATTRS
          • PROXY_USERS
          • USER_PLSQL_TYPES
          • USER_PLSQL_COLL_TYPES
          • USER_PLSQL_TYPE_ATTRS
          • USER_SCHEDULER_JOBS
          • USER_OB_SOURCE
          • V$RESTORE_POINT
      • Common statistical events
      • General wait events
      • Changes in parameters and system variables from V3.x to V4.x
          • alert_log_level
          • global_background_cpu_quota
          • log_storage_warning_trigger_percentage
          • rdma_io_thread_count
          • unit_gc_wait_time
          • utl_file_open_max
          • audit_log_buffer_size
          • audit_log_compression
          • audit_log_enable
          • audit_log_format
          • audit_log_max_size
          • audit_log_path
          • audit_log_prune_seconds
          • audit_log_query_sql
          • audit_log_rotate_on_size
          • audit_log_strategy
          • enable_gts_standalone
          • enable_kv_group_commit
          • enable_lock_priority
          • enable_ls_leader_balance
          • plsql_warnings
          • enable_ps_parameterize
          • json_document_max_depth
          • kv_group_commit_batch_size
          • kv_group_commit_rw_mode
          • kv_transport_compress_func
          • kv_transport_compress_threshold
          • ls_scale_out_factor
          • recover_table_concurrency
          • recover_table_dop
          • sts_credential
          • zone_deploy_mode
          • debug_sync
          • innodb_stats_persistent
          • ob_compatibility_control
          • ob_compatibility_version
          • ob_enable_trace_log
          • ob_enable_parameter_anonymous_block
          • ob_security_version
          • partition_index_dive_limit
          • pid_file
          • port
          • range_index_dive_limit
          • socket
          • ob_enable_rich_error_msg
          • enable_sql_plan_monitor
        • 4500 - 4999
        • 5000 - 5999
        • 6000 - 6999
        • 8000 - 8999
        • 10000 to 12000
        • ORA-00000 to ORA-00999
        • ORA-01000 to ORA-01499
        • ORA-01500 to ORA-01999
        • ORA-02000 to ORA-04999
        • ORA-05000 to ORA-10000
        • ORA-10000 to ORA-19999
        • ORA-20000 to ORA-29999
        • ORA-30000 to ORA-49999
        • ORA-50000 to ORA-99999
      • System tunning
          • CPU-related parameters
        • Hot row optimization
          • Experience the hot row update capability of OceanBase Database
          • How to use group commit for hot rows and best practices
          • How hot row performance optimization works
          • Monitor the performance of historical sessions
          • Generate ASH reports
          • Analyze the ASH report
      • SQL tunning
          • Execution plan operators
            • ADAPTIVE JOIN queries
            • JOIN
            • WINDOW FUNCTION
            • SUBPLAN FILTER
            • DISTINCT
            • SEQUENCE
            • MATERIAL
            • SORT
            • LIMIT
            • FOR UPDATE
            • SUBPLAN SCAN
            • UNION
            • INTERSECT
            • EXCEPT/MINUS
            • EXCHANGE
            • GI
          • SQL tuning practice with EXPLAIN
          • Parallel DDL
        • Parallel execution plan
          • Set parallel execution
            • Statistics collection and update strategy for partitioned tables
            • Rule-based query rewrite
              • Runtime filters
            • SQL plan management
    • Performance test
      • Achieve high performance with Sysbench on OceanBase Database: deployment and troubleshooting
    • Platform products
      • OCP Express
        • OCP Express
        • Monitor a cluster
        • Diagnostic analysis
        • Log service
    • components & tools
        • OBShell
          • Use OBShell
            • Start or stop OBShell
          • Command line
            • Cluster commands of OBShell
            • Utilities commands of OBShell
            • OBShell API requests
            • Authentication based on public-key encryption
              • Modify tenant parameters
              • Query parameters of a specified tenant
              • Fuzzy query for tenant parameters
            • InitializeCluster
            • UpgradeOb
            • AddNode
            • GetObInfo
          • SDK references
                • Query tenant parameters
            • GO
        • OBD
        • SQL diagnoser
            • Install SQL Diagnoser
            • Use SQL Diagnoser
          • SQL diagnoser remarks
            • APIs
        • DOOBA
        • obloader & obdumper
        • Partition calculator
        • CDC
          • OBLogProxy
            • Deploy and use obcdc
              • Install and deploy OBCDC
            • FAQ about obcdc
            • Common obcdc parameters
          • oblogmsg
            • Install and deploy oblogmsg
      • Stress testing tool
    • Products
        • OceanBase Database V4.2.5
        • OceanBase Database Community Edition V4.2.5
  4. V4.2.5
Last Updated:2026-09-04 09:48:50
Privilege requirements
Attributes
Examples
For V3.2.1, this parameter is available starting with V3.2.1.
connection_control_max_connection_delay specifies the maximum lock duration after exceeding the threshold of failed login attempts.
Applicability
This parameter applies only to OceanBase Database in MySQL mode.
  • Query the parameter
    The sys tenant and all user tenants can use the SHOW PARAMETERS statement or the GV$OB_PARAMETERS view to query this parameter.
  • Modify the parameter
    The sys tenant and user tenants can modify this parameter.
Attributes
Type Int
Default value 2147483647, in milliseconds
Modifiable Yes. You can use the ALTER SYSTEM SET statement to modify the parameter.
Effective upon OBServer node restart No. The setting takes effect immediately.
Examples
Set the maximum lock duration after exceeding the threshold of failed login attempts to 2147483647 milliseconds.
obclient> ALTER SYSTEM SET connection_control_max_connection_delay = 2147483647;
Identity authentication
connection_control_failed_connections_threshold
Attributes
Examples
