OceanBase Cloud PlatformOceanBase Migration ServiceOceanBase Developer CenterOceanBase Migration AssessmentOceanBase Admin ToolOceanBase Loader and DumperOceanBase DeployerKubernetes operator for OceanBaseOceanBase Diagnostic Tool OceanBase Binlog ServiceOceanBase DataPilot
V3.1.1Community Edition
      • Deploy OBD
      • Deploy OceanBase Database
      • Create tenants
    • Check after installation
      • \*-example.yaml
  • User Guide
    • OCP overview
      • Clusters
        • Cluster overview
      • Hosts
        • Host overview
        • Host details
      • OBProxy
        • OBProxy overview
        • OBProxy cluster overview
        • Alert overview
        • View tasks
        • Security overview
      • Personal center
        • Change the logon password
        • Password box
      • Basic cluster operations
          • Create a zone
          • Add an OBServer
          • Restart an OBServer
          • Stop an OBServer
          • Replace an OBServer
        • Change a password
        • Disable SQL collection
      • Performance monitoring
      • Cluster resource management
        • Major compaction details
        • Major freeze statistics
      • Basic tenant operations
        • Manage unit types
        • Modify the whitelist
      • View a tenant topology
        • TopSQL diagnosis
        • Slow SQL diagnosis
    • Manage hosts
      • Restart OCP Agent
      • Stop OCP Agent
    • Manage software packages
    • Manage OBProxies
      • Create an alert item
      • View alert items
      • Copy an alert item
      • Edit an alert item
      • Delete an alert item
      • Alert groups
      • View alert channels
      • View an alert event
      • Delete a blocking condition
      • Add a filtering keyword
      • Delete a filtering keyword
      • Manage alert subscriptions
    • Use system management
      • Role overview
      • View users
      • Change a user password
      • Logon history
      • SQL performance module
      • OCP error table
      • Monitoring metrics
      • OBProxy startup parameters
      • FAQ about multi-zone mode
      • FAQ about OBProxy takeover
      • Install dependent software
      • ob_log_alarm
      • no_enough_exporter
      • backup_schedule_fail
      • Modify alert thresholds
      • OCP-Agent script
    • Cluster information
      • Query clusters
      • Add an OBServer
      • Stop an OBServer
      • Start an OBServer
      • Query servers
      • Query servers in a zone
    • Tenant information
    • Hosts
      • Add a region
      • Add an IDC
      • Add a host type
    • OCP Agent management
      • Task information
  3. V3.1.1
system_obproxy_unavailable
Last Updated:2026-09-04 10:28:16
Alert information
Alert rule
Alert templates
Impact on the system
Possible causes
Solutions
This alert is triggered when the OBProxy service port is unavailable.
Alert information
Trigger method
Alert level
Scope
Timed task of OCP Critical Service
Alert rule
Metric
Default threshold
Source
Duration
Detection cycle
Elimination cycle
N/A N/A N/A N/A 60s 5 min
Alert templates
  • Overview: ${alarm_target} ${alarm_name}
  • Details: ${alarm_target} ${alarm_name}
  • Overview example: ocp_ip=xxx.xxx.xxx.1:obproxy_address=xxx.xxx.xxx.2:obproxy_port=2888 The system OBProxy is unavailable.
  • Details example: ocp_ip=xxx.xxx.xxx.1:obproxy_address=xxx.xxx.xxx.2:obproxy_port=2888 The system OBProxy is unavailable.
Where, ${alarm_target} indicates the object where the alert is generated, in the ocp_ip=xx:obproxy_address=xx:obproxy_port=xx format. ocp_ip is the IP address of the OCP node that detects the alert. obproxy_address is the service address of the OBProxy that generates the alert. obproxy_port is the service port number of the OBProxy that generates the alert.
As the proxy layer of the OBServer cluster, the OBProxy provides access to OBServer. If the OBProxy cannot be reached, applications cannot connect to the database through the OBProxy.
Possible causes
The following are the common causes:
  • A network communication error occurs.
  • The OBProxy process has stopped abnormally.
Solutions
  • Check whether the network communication is faulty.
    On the OCP host, run netstat -a | grep -i established | grep "${obproxy_address}:${obproxy_port}" and check the information returned.
    • If the command returns information, the network communication is normal.
    • If not, a network communication error occurs. Check the specific fault that has caused the network communication failure. For example,
      • If the OBProxy host fails, we recommend that you replace an OBProxy.
      • If the network is disconnected due to a firewall, set the firewall properly.
  • Check whether the OBProxy process is normal.
    In OCP, select the OBProxy host and check whether relevant OBProxy processes are normal in the Processes list on the OCP Agent tab.
    If an OBProxy process is abnormal, restart it and check whether the OBProxy is normal. For details on how to restart an OBProxy process, see Start OBProxy in the OceanBase Database documentation.
monitor_exporter_unavaliable
host_ntp_service_not_exist
Alert information
Alert rule
Alert templates
Possible causes
Solutions
