SQL - V4.3.1
  • What's New
    • Learn OceanBase SQL
      • Before you begin
      • Build a Python application
      • Build a Java application
      • Build a C application
      • Build a Go application
      • Scalable OLTP
      • Try out operational OLAP
    • Video tutorials
          • Connector/J
          • TestContainers
          • MySQL-connector-python
          • MySQL Connector/C
        • PHP
          • EXT
          • MySQLi
          • PDO
        • Create an external table
        • Server configuration
          • (Optional) Check resources
    • Clear an OceanBase cluster
    • Direct load
        • Reset a cluster parameter
        • Upgrade a cluster
            • Check upgrade results
            • Configure cgroups
            • Configure cgroups
        • Clone a tenant
        • Cancel tenant cloning
          • Modify a unit config
          • Drop a unit config
          • Add replicas
          • Remove replicas
          • Migrate units
        • Transfer a partition
        • Cancel a load balancing job
            • Set the log restore source
          • Specify log compression
          • Logon failure processing
            • Role management
              • Grant privileges to a role
      • Transparent data encryption
          • Enable TDE for new tables
        • Enable security audit
        • View audit records
        • Audit user logon operations
        • Prepare for the backup
        • Stop backup cleanup
        • Perform a physical restore
        • Restore data by table
        • Cancel table restore
      • Check tenant resource usage
            • Suboptimal plans
            • Cardinality
              • Hash joins
              • Merge joins
          • Schema Specification
      • Bootstrap
        • Absence of the leader
        • Transaction-related errors
        • Long-running transactions
        • Suspended transactions
        • Switchover failures
          • Exceptions of SQL queries
  • OceanBase AP
    • Core features
    • Data table design
      • Best practices
      • ETL acceleration
    • Query acceleration
      • Statistics
      • Materialized views
      • Full direct load
      • Table groups
      • Hybrid row-column storage
    • Ecosystem integration
  • OBKV
    • OBKV-Table
        • Overview of the Go client
        • Individual API operations
        • Batch operations
        • About queries
        • Aggregation API
        • Filters
    • OceanBase concepts
            • Temporary tables
            • External table partitions
            • Views in a database
            • Standard views
              • Standard views
              • Materialized view logs
            • About indexes
            • Full-text index
            • Standard views
            • Read-only replicas
          • Data balancing
            • Intra-tenant balancing
          • Cluster scaling
          • Tenant resource scaling
            • DCL statements
          • Weak consistency read
          • Columnar storage
          • Minor compaction
          • Merges
        • Multi-level caches
          • Backup directory structures
          • Restore architecture
        • Configuration file
          • View dump information
          • Adaptive major compaction
          • View merge information
        • Common memory issues
          • Column skip index attribute
          • Drop a partition
          • Exchange partitions
          • Manage standard views
          • Manage materialized views
              • Create a materialized view
              • Query materialized views
              • Drop a materialized view
              • Refresh a materialized view
          • Drop a partition
            • CANCEL BALANCE JOB
            • CANCEL CLONE
        • User tenants (MySQL mode)
                • Integer data types
                • Fixed-point data types
                • Floating-point data types
                • Bit value data type
                • BLOB types
                • LOB type
              • SET type
                • Convert a JSON data type
                • Update partial JSON data
                • SRS
                • Create a spatial column
                • Create a spatial index
              • Collations
              • Strings
              • Numbers
              • Datetime values
              • NULLs
            • Assignment operators
            • BINARY operator
          • Sequence pseudocolumns
              • OB_TRANSACTION_ID
              • Spatial relation functions
              • Geometry property functions
              • RELEASE_ALL_LOCKS
            • Full-text queries
            • Common Table Expressions
            • CREATE MATERIALIZED VIEW
            • CREATE RESTORE POINT
            • DROP MATERIALIZED VIEW
            • DROP MATERIALIZED VIEW LOG
              • SELECT statement
              • OVER clause
        • User tenants (Oracle mode)
          • Introduction to SQL
            • ORA_ROWSCN pseudocolumn
            • ROWNUM pseudocolumn
            • ROWID pseudocolumn
              • Rowid data types
                • Create JSON columns
                • Create an XMLType column
                • Convert XMLType data
              • Data type precedence
                • Date literals
                • Timestamp literals
              • Interval literals
              • RR datetime format element
              • NULLs in SQL functions
                  • Hints related to joins
                  • Other hints
                • Reference a DBLink
                • EXTRACT(datetime)
                • ROUND(date)
                • TRUNC(date)
                • TO_NCHAR(character)
                • TO_NCHAR(datetime)
                • TO_NCHAR(number)
              • REGR_(Linear Regression)
              • GROUP_ID
              • GROUPING_ID
              • OB_TRANSACTION_ID
            • CURSOR expressions
            • Condition precedence
            • NULL conditions
            • Simple query
            • Hierarchical query
            • Compound query
            • Join query
            • Subquery
            • DUAL table query
              • ALTER SYSTEM PARAMETER
                • Set-based SELECT
                • WITH clause
          • SELECT statements
          • Table scan
          • Cache
          • Hint
          • Pagination queries
        • PL reference (MySQL mode)
            • Trigger
            • DBMS_MVIEW
              • PURGE_LOG
            • DBMS_MVIEW_STAT
              • PURGE_REFRESH_STATS
              • SET_MVREF_STATS_PARAMS
              • SET_SYSTEM_DEFAULT
              • ADD_TRUSTED_CERTIFICATE
              • DELETE_TRUSTED_CERTIFICATE
              • UPDATE_TRUSTED_CERTIFICATE
            • DBMS_LIMIT_CALCULATOR
        • PL reference (Oracle mode)
            • Lexical units
            • Declare
            • Assign values
            • Error-reporting functions
            • BOOLEAN type
            • Sequential control
            • Records
              • Explicit cursors
              • Modify and drop a cursor
            • Privilege control
              • Application
            • PL DBLinks
            • INSTEAD OF DML trigger
            • Compound DML trigger
            • Compile-Time alerts
            • DBMS_JOB
              • BROKEN
              • CHANGE
              • NEXT_DATE
              • RUN
              • SUBMIT
              • USER_EXPORT
              • WHAT
              • RELEASE
            • DBMS_MVIEW
              • PURGE_LOG
              • OB_SESSION_TRACE_ENABLE
              • OB_SESSION_TRACE_DISABLE
              • OB_CLIENT_ID_TRACE_ENABLE
              • OB_CLIENT_ID_TRACE_DISABLE
              • OB_MOD_ACT_TRACE_ENABLE
              • OB_MOD_ACT_TRACE_DISABLE
              • OB_TENANT_TRACE_ENABLE
              • OB_TENANT_TRACE_DISABLE
            • DBMS_MVIEW_STAT
              • VARIABLE_VALUE
              • DBMS_XA constants
              • ENDCREATE member procedure
              • GET* member functions
              • PIECEWISE member procedure
              • SET* member procedures
          • Reserved PL keywords
          • CDB_INDEX_USAGE
          • CDB_MVIEW_LOGS
          • CDB_MVIEWS
          • CDB_MVREF_CHANGE_STATS
          • CDB_MVREF_RUN_STATS
          • CDB_MVREF_STATS
          • CDB_MVREF_STATS_PARAMS
          • CDB_MVREF_STMT_STATS
          • DBA_INDEX_USAGE
          • DBA_MVIEW_LOGS
          • DBA_MVIEWS
          • DBA_MVREF_CHANGE_STATS
          • DBA_MVREF_RUN_STATS
          • DBA_MVREF_STATS
          • DBA_MVREF_STATS_PARAMS
          • DBA_MVREF_STMT_STATS
          • DBA_OB_CLONE_HISTORY
          • DBA_OB_CLONE_PROGRESS
          • GV$OB_LS_SNAPSHOTS
          • GV$OB_NIC_INFO
          • V$OB_LS_SNAPSHOTS
          • V$OB_NIC_INFO
          • DBA_INDEX_USAGE
          • DBA_MVIEW_LOGS
          • DBA_MVIEWS
          • DBA_MVREF_STATS
          • GV$OB_NIC_INFO
          • V$OB_LS_SNAPSHOTS
          • V$OB_NIC_INFO
          • ALL_MVIEW_LOGS
          • ALL_MVIEWS
          • DBA_INDEX_USAGE
          • DBA_MVIEW_LOGS
          • DBA_MVIEWS
          • DBA_MVREF_STATS
          • USER_MVIEW_LOGS
          • USER_MVIEWS
          • USER_MVREF_CHANGE_STATS
          • USER_MVREF_RUN_STATS
          • USER_MVREF_STATS
          • USER_MVREF_STATS_PARAMS
          • USER_MVREF_STMT_STATS
          • GV$OB_NIC_INFO
          • V$OB_LS_SNAPSHOTS
          • V$OB_NIC_INFO
      • Common statistical events
      • General wait events
          • rdma_io_thread_count
          • default_table_store_format
          • debug_sync
          • ob_enable_rich_error_msg
          • plsql_ccflags
          • query_rewrite_enabled
          • query_rewrite_integrity
        • 10000 to 12000
        • ORA-00000 to ORA-00999
        • ORA-01000 to ORA-01499
        • ORA-01500 to ORA-01999
        • ORA-02000 to ORA-04999
        • ORA-05000 to ORA-10000
        • ORA-10000 to ORA-19999
        • ORA-20000 to ORA-29999
        • ORA-30000 to ORA-49999
        • ORA-50000 to ORA-99999
          • Generate ASH reports
          • Analyze ASH reports
          • Execution plan operators
            • JOIN
            • WINDOW FUNCTION
            • SUBPLAN FILTER
            • DISTINCT
            • SEQUENCE
            • MATERIAL
            • SORT
            • LIMIT
            • FOR UPDATE
            • SUBPLAN SCAN
            • UNION
            • INTERSECT
            • EXCEPT/MINUS
            • EXCHANGE
            • GI
        • Parallel execution plans
          • Set concurrent execution
            • Rule-based query rewriting
            • SQL plan management
      • OCP Express
        • OCP Express
        • Monitor a cluster
        • Diagnostic analysis
        • Log service
        • OBShell
          • Use OBShell
            • Start or stop OBShell
            • Deploy an OceanBase cluster
            • Upgrade OBShell
          • Command line
            • Agent commands of OBShell
            • Cluster commands of OBShell
            • Task commands of OBShell
            • OBShell API requests
            • InitializeCluster
            • UpgradeOb
            • AddNode
          • ob_admin overview
        • OBD
        • SQL diagnoser
            • Install SQL Diagnoser
            • Use SQL Diagnoser
          • SQL diagnoser remarks
            • API operations
        • DOOBA
        • OBLogProxy
        • OBLOADER & OBDUMPER
        • Partition calculator
        • CDC
            • Deploy and use obcdc
              • Install and deploy obcdc
              • General obcdc parameters
            • FAQ about obcdc
          • Developer Guide for obcdc
          • oblogmsg
            • Install and deploy oblogmsg
      • Stress testing tools
    • Integrations
      • Superset
      • Bytebase
      • DolphinScheduler
      • SeaTunnel
      • Linkis
      • Maxwell
    • FAQs
    • FAQ about columnstores
    • Version number guidelines
        • OceanBase Database V4.3.1
  4. V4.3.1
Last Updated:2026-09-03 07:23:57
connection_control_max_connection_delay specifies the maximum lock period for an account whose number of failed logon attempts reaches the specified threshold.
Type Integer
Default value 2147483647, in ms
Effective upon OBServer node restart No
This parameter takes effect only in MySQL mode.
connection_control_failed_connections_threshold
