SQL - V4.2.2
    • Learn OceanBase SQL
      • Before you begin
      • Build a Java application
      • Build a C application
      • Build a Python application
      • Build a Go application
      • Scalable OLTP
      • Try out operational OLAP
    • Video tutorials
        • Create an external table
          • Transaction idle timeout, error code ERROR 6002
        • Server configuration
          • Add a server to the resource pool
          • Deploy an OceanBase cluster with two replicas and an arbitration service using the CLI
          • Deploy a single-replica OceanBase cluster from the CLI
          • (Optional) Check resources
    • Clean up an old cluster
      • Migrate data from OceanBase Database to a MySQL database using Flink CDC
    • Bypass import
        • Upgrade clusters
          • Upgrade OceanBase Database Enterprise Edition
            • Check upgrade results
          • Upgrade OceanBase Database Community Edition
            • Upgrade OceanBase Database by using OBD
          • Resource isolation overview
            • Configure cgroups
            • Configure cgroups
        • View tenant system variables
        • Recover a tenant
          • Modify unit configs
          • Drop unit configs
          • Add replicas
          • Remove replicas
          • Migrate units
        • Transfer a partition
            • Set the log restore source
            • Set the log recovery endpoint
          • Logon failure processing
            • Grant privileges
            • Query user privileges
            • Modify user privileges
      • Transparent data encryption
        • Enable security audit
        • View audit records
        • Audit user logon operations
        • Change the destination of archiving
        • Prepare for the backup
        • Views for monitoring backup progress and results
        • Stop backup cleanup
        • Perform a physical restore
        • Restore tables
        • Cancel table restore
            • Cardinality
              • Hash joins
              • Merge joins
          • Schema Specification
        • Locate and analyze slow queries (1)
      • Check tenant resource usage
      • Bootstrap
        • Absence of the leader
        • Transaction-related errors
        • Long-running transactions
        • Suspended transactions
          • Exceptions of SQL queries
    • System principles
            • Temporary tables
            • About indexes
            • View categorization
            • Data operations in views
            • Data access from views
            • Updatable views
            • About indexes
            • Updatable views
          • Cluster scaling
          • Tenant resource scaling
            • DCL statements
          • Weak consistency read
          • Minor compaction
          • Major compaction
        • Multi-level caches
          • Backup directory structures
          • Restore architecture
        • Configuration files
          • Dump Management Overview
          • View the details of minor compactions
          • Adaptive major compaction
        • Common memory issues
          • Drop a partition
          • Query a DBLink
          • Drop a partition
        • Design partitioned table schemas
            • CHANGE TENANT
        • User tenants (MySQL mode)
                • Integer data types
                • Fixed-point data types
                • Floating-point data types
                • Bit value data type
                • BLOB types
                • LOB type
              • SET type
                • Convert a JSON data type
                • SRS
                • Create a spatial column
                • Create a spatial index
              • Collations
              • Strings
              • Numbers
              • Datetime values
              • NULLs
            • Assignment operators
            • BINARY operator
          • Sequence pseudocolumns
              • Search JSON text functions
            • Table functions
              • Overview of TABLE FUNCTIONS
              • FILES table function
              • Spatial relation functions
              • Geometry property functions
            • Common table expressions
            • CREATE FORMAT OUTLINE
            • DROP RESTORE POINT
            • DROP FORMAT OUTLINE
              • SELECT statement
              • OVER clause
        • User tenants (Oracle mode)
          • Introduction to SQL
            • ORA_ROWSCN pseudocolumn
            • ROWNUM pseudocolumn
            • ROWID pseudocolumn
              • Rowid data types
                • Create JSON columns
                • Create an XMLType column
                • Convert XMLType data
                • Create a spatial data column
              • Data type precedence
                • Date literals
                • Timestamp literals
              • Interval literals
              • RR datetime format element
              • NULLs in SQL functions
                  • Hints related to joins
                  • Other hints
                • Reference a DBLink
                • EXTRACT(datetime)
                • ROUND(date)
                • TRUNC(date)
                • TO_NCHAR(character)
                • TO_NCHAR(datetime)
                • TO_NCHAR(number)
              • Spatial-functions
              • REGR_(Linear Regression)
              • Analytic functions
            • Table functions
            • CURSOR expressions
            • Condition precedence
            • NULL conditions
            • Simple query
            • Hierarchical query
            • Compound query
            • Join query
            • Subquery
            • DUAL table query
              • ALTER SYSTEM PARAMETER
              • Purpose
                • Set-based SELECT
                • WITH clause
          • SELECT statements
          • Table scan
          • Cache
          • Hint
          • Related specifications
          • Pagination queries
        • PL reference (MySQL mode)
            • Trigger
        • PL reference (Oracle mode)
            • Lexical units
            • Declare
            • Assign values
            • Error-reporting functions
            • BOOLEAN type
            • Sequential control
            • Records
              • Explicit cursors
              • Modify and drop a cursor
            • Privilege control
              • Application
            • PL DBLinks
            • INSTEAD OF DML trigger
            • Compound DML trigger
            • Compile-Time alerts
            • DBMS_JOB
              • BROKEN
              • CHANGE
              • NEXT_DATE
              • RUN
              • SUBMIT
              • USER_EXPORT
              • WHAT
              • DBMS_XA constants
              • ENDCREATE member procedure
              • GET* member functions
              • PIECEWISE member procedure
              • SET* member procedures
          • Reserved PL keywords
    • Multi-model API
      • TableAPI
        • Implementation
          • Implementation of TableAPI
          • TableAPI data models
        • Use the TableAPI client
          • Introduction to the client and instructions
          • Set client parameters
        • Use the TableAPI Go client
          • Create a Go client instance
          • Overview of the Go client
          • Individual API operations
          • Batch operations
          • About queries
          • Aggregation API
          • Filters
      • HBaseAPI
        • Introduction to the HBaseAPI solution
        • HBaseAPI storage model
        • Usage instructions of the HBaseAPI client
      • Deletion of expired data
      • RPC message compression
          • GV$OB_KV_CONNECTIONS
          • V$OB_KV_CONNECTIONS
          • GV$OB_CGROUP_CONFIG
          • V$OB_CGROUP_CONFIG
          • DBA_OB_SYS_VARIABLES
      • Common statistics events
      • General wait events
          • rdma_io_thread_count
          • plsql_warnings
          • kv_transport_compress_func
          • kv_transport_compress_threshold
          • debug_sync
          • ob_enable_rich_error_msg
        • 0001 - 3999
        • 4000 - 4499
        • 4500 - 4999
        • 5000 - 5999
        • 6000 - 6999
        • 7000 - 7999
        • 8000 - 8999
        • 9000 - 9499
        • 9500 - 9999
        • 10000 - 12000
        • ORA-00000 to ORA-00999
        • ORA-01000 to ORA-01499
        • ORA-01500 to ORA-01999
        • ORA-02000 to ORA-04999
        • ORA-05000 to ORA-10000
        • ORA-10000 to ORA-19999
        • ORA-20000 to ORA-29999
        • ORA-30000 to ORA-49999
        • ORA-50000 to ORA-99999
          • Generate ASH reports
          • Analyze ASH reports
          • Execution plan operators
            • JOIN
            • WINDOW FUNCTION
            • SUBPLAN FILTER
            • DISTINCT
            • SEQUENCE
            • MATERIAL
            • SORT
            • LIMIT
            • FOR UPDATE
            • SUBPLAN SCAN
            • UNION
            • INTERSECT
            • EXCEPT/MINUS
            • EXCHANGE
            • GI
          • SQL tuning practice with EXPLAIN
        • Parallel execution
          • Deploy parallel execution
            • Set the degree of parallelism
            • Set the parallel execution parameters
            • Rule-based query rewriting
            • SQL plan management
    • Performance test
      • Achieve high performance with Sysbench on OceanBase Database: deployment and troubleshooting
      • OCP Express
        • OCP Express
        • Monitor a cluster
        • Diagnostic analysis
        • Log service
        • OBShell
          • Use OBShell
            • Start or stop OBShell
          • Command line
            • Cluster commands of OBShell
            • Utilities commands of OBShell
            • OBShell API requests
            • Authentication based on public-key encryption
            • InitializeCluster
            • UpgradeOb
            • AddNode
            • Query the status of an OceanBase cluster
        • OBD
        • SQL diagnoser
            • Install SQL Diagnoser
            • Use SQL Diagnoser
          • SQL diagnoser remarks
            • APIs
        • DOOBA
        • OBLOADER & OBDUMPER
        • Partition calculator
        • CDC
          • OBLogProxy
            • Deploy and use obcdc
              • Install and deploy OBCDC
              • General obcdc parameters
            • FAQ about obcdc
          • oblogmsg
            • Install and deploy oblogmsg
      • Stress testing tools
    • FAQs
    • FAQs
  4. V4.2.2
Last Updated:2026-09-04 09:45:16
connection_control_max_connection_delay specifies the maximum lock period for an account whose number of failed logon attempts reaches the specified threshold.
Type Integer
Default value 2147483647, in ms
Effective upon OBServer node restart No
This parameter takes effect only in MySQL mode.
