SQL - V4.2.1
    • Learn OceanBase SQL
      • Before you begin
      • Build a Python application
      • Build a Java application
      • Build a C application
      • Build a Go application
      • Scalable OLTP
      • Try out operational OLAP
    • Video tutorials
        • Connect to an OceanBase Database tenant by using the mysql client
        • Create an external table
        • 200.python-of-oracle-mode
          • Python Driver Oracle Mode
        • Configure servers
          • Add a server to the resource pool
          • (Optional) Check resources
    • Clear an OceanBase cluster
      • Use OMS to migrate data from an OceanBase Database tenant to another of the same type
      • Use OMS to migrate data from an OceanBase Database tenant to another of the same type in active-active disaster recovery scenarios
    • Bypass import
    • Log on to an OceanBase Database tenant
        • Upgrade clusters
          • Upgrade OceanBase Database Enterprise Edition
            • Check upgrade results
          • Upgrade OceanBase Database Community Edition
            • Upgrade OceanBase Database by using OBD
          • Resource isolation overview
            • Configure cgroups
            • Configure cgroups
        • View tenant system variables
        • Recover a tenant
          • Modify unit configs
          • Drop unit configs
          • Add replicas
          • Remove replicas
          • Migrate units
            • Set the log recovery endpoint
          • Logon failure processing
            • Grant privileges
            • Modify user privileges
            • Query user privileges
      • Transparent data encryption
        • Transparent data encryption test report
        • Enable security audit
        • View audit records
        • Audit user logon operations
        • View the archiving parameter settings
        • Automatically clean up expired backup data
        • Stop backup cleanup
        • Perform physical restore
        • Perform table restore
        • Cancel table restore
      • Check tenant resource usage
            • Non-optimal plans
            • Cardinality
              • Hash joins
              • Merge joins
          • Schema specifications
      • Bootstrap
        • Absence of the leader
        • Transaction-related errors
        • Long-running transactions
        • Suspended transactions
        • Switchover failures
          • Exceptions of SQL queries
  • OBKV
    • OBKV-Table
      • OBKV-Table
        • OBKV-Table operation types
        • Supported value types
        • OBKV-Table data models
        • Set client parameters
        • Supported client interfaces
        • Overview of the Go client
        • Individual API operations
        • Batch operations
        • About queries
        • Aggregation API
        • Filters
      • Delete expired data
    • OBKV-HBase
      • Core features
      • Compatibility with HBase
      • Use OBKV-HBase
        • Data model
        • Data model design
        • Data operation examples
      • OBKV-HBase management
        • Monitoring metrics
      • Performance test
      • OBKV-HBase integration
    • RPC message compression
    • System principles
            • Temporary tables
            • About indexes
            • View categorization
            • Data operations in views
            • Data access from views
            • Updatable views
            • About indexes
            • Updatable views
          • Cluster scaling
          • Tenant resource scaling
            • DCL statements
          • Weak consistency read
          • Minor compaction
          • Major compaction
        • Multi-level caches
          • Backup directory structures
          • Restore architecture
        • Configuration files
        • General system parameters
        • Default production parameters
        • Minimum resource configurations
          • Adaptive major compactions
        • FAQ about memory
          • Drop a partition
          • Query a DBLink
          • Drop a partition
            • ACTIVATE
            • DELETE BACKUP
            • FAILOVER
            • LOG RESTORE SOURCE
            • RECOVER
        • User tenants (MySQL mode)
                • Integer data types
                • Fixed-point data types
                • Floating-point data types
                • Bit value data type
                • BLOB types
              • SET type
                • Convert a JSON data type
                • SRS
                • Create a spatial column
                • Create a spatial index
              • Collations
              • Strings
              • Numbers
              • Datetime values
              • NULLs
            • Assignment operators
            • BINARY operator
          • Sequence pseudocolumns
              • Search JSON text functions
              • Spatial relation functions
              • Geometry property functions
            • CTE
            • DROP RESTORE POINT
              • SELECT statement
              • OVER clause
        • User tenants (Oracle mode)
          • Introduction to SQL
            • ORA_ROWSCN pseudocolumn
            • ROWNUM pseudocolumn
            • ROWID pseudocolumn
              • Rowid data types
                • Create JSON columns
                • Create an XMLType column
                • Convert XMLType data
              • Data type precedence
                • Date literals
                • Timestamp literals
              • Interval literals
              • RR datetime format element
              • NULLs in SQL functions
                  • Hints related to joins
                  • Other hints
                • Reference a DBLink
                • EXTRACT(datetime)
                • ROUND(date)
                • TRUNC(date)
                • TO_NCHAR(character)
                • TO_NCHAR(datetime)
                • TO_NCHAR(number)
              • REGR_(Linear Regression)
              • Analytic functions
            • CURSOR expressions
            • Condition precedence
            • NULL conditions
            • Simple query
            • Hierarchical query
            • Compound query
            • Join query
            • Subquery
            • DUAL table query
              • ALTER SYSTEM PARAMETER
              • ALTER SYSTEM MAJOR FREEZE
                • Set-based SELECT
                • WITH clause
          • SELECT statement writing specifications
          • Multi-table join statements
          • Table scan
          • Transaction specifications
          • Cache
          • Hint
          • Other related specifications
          • JOIN tables
          • Pagination queries
        • PL reference (MySQL mode)
              • Overview of DBMS_RESOURCE_MANAGER
              • Overview of DBMS_STATS
              • Overview of DBMS_UDR
              • Overview of DBMS_WORKLOAD_REPOSITORY
              • Overview of DBMS_XPLAN
            • DBMS_BALANCE
              • Overview of DBMS_BALANCE
        • PL reference (Oracle mode)
            • Lexical units
            • Declaration
            • Quote identifiers
            • Assign values
            • Error-reporting functions
            • BOOLEAN type
            • Sequential control
            • Records
              • Explicit cursors
              • Modify and drop a cursor
              • Control an autonomous transaction
            • DBMS_SQL package
            • Privilege control
              • Create a pipelined function
              • Application
            • PL DBLink
            • INSTEAD OF DML trigger
            • Compound DML trigger
            • Compile-Time alerts
              • Overview of SA_SYSDBA
              • Overview of SA_COMPONENTS
              • Overview of SA_LABEL_ADMIN
              • Overview of SA_POLICY_ADMIN
              • Overview of SA_USER_ADMIN
              • Overview of SA_SESSION
              • Overview of DBMS_APPLICATION_INFO
              • Overview of DBMS_AUDIT_MGMT
            • DBMS_BALANCE
              • Overview of DBMS_DEBUG
              • Overview of DBMS_DESCRIBE
            • DBMS_JOB
              • BROKEN
              • CHANGE
              • NEXT_DATE
              • RUN
              • SUBMIT
              • USER_EXPORT
              • WHAT
              • Overview of DBMS_LOB
              • Overview of DBMS_LOCK
              • Overview of DBMS_METADATA
              • Overview of DBMS_MONITOR
              • Overview of DBMS_OUTPUT
              • docslug#/oceanbase-database/oceanbase-database/V4.0.0/DISABLE
              • docslug#/oceanbase-database/oceanbase-database/V4.0.0/ENABLE
              • docslug#/oceanbase-database/oceanbase-database/V4.0.0/GET_LINE
              • docslug#/oceanbase-database/oceanbase-database/V4.0.0/GET_LINES
              • docslug#/oceanbase-database/oceanbase-database/V4.0.0/NEW_LINE
              • docslug#/oceanbase-database/oceanbase-database/V4.0.0/PUT
              • docslug#/oceanbase-database/oceanbase-database/V4.0.0/PUT_LINE
              • Overview of DBMS_PLAN_CACHE
              • docslug#/oceanbase-database/oceanbase-database/V4.0.0/PURGE
              • Overview of DBMS_SCHEDULER
              • Overview of DBMS_SESSION
              • Overview of DBMS_SQL
              • COMMA_TO_TABLE
              • DBMS_XA constants
              • Overview of DBMS_XMLGEN
              • Overview of UTL_ENCODE
              • Overview of UTL_FILE
              • Overview of UTL_I18N
              • Overview of UTL_RAW
              • ENDCREATE member procedure
              • GET* member functions
              • PIECEWISE member procedure
              • SET* member procedures
          • Reserved PL keywords
      • Common statistics events
      • General wait events
      • Overview of parameters and system variables
        • Parameter overview
          • rdma_io_thread_count
          • plsql_warnings
          • debug_sync
          • pid_file
          • port
          • range_index_dive_limit
          • socket
          • ob_enable_rich_error_msg
        • 0001 - 3999
        • 4000 - 4499
        • 4500 - 4999
        • 5000 - 5999
        • 6000 - 6999
        • 7000 - 7999
        • 8000 - 8999
        • 9000 - 9499
        • 9500 - 9999
        • ORA-00000 to ORA-00999
        • ORA-01000 to ORA-01499
        • ORA-01500 to ORA-01999
        • ORA-02000 to ORA-04999
        • ORA-05000 to ORA-10000
        • ORA-10000 to ORA-19999
        • ORA-20000 to ORA-29999
        • ORA-30000 to ORA-49999
        • ORA-50000 to ORA-99999
          • Generate ASH reports
          • Analyze ASH reports
          • Execution plan operators
            • JOIN
            • WINDOW FUNCTION
            • SUBPLAN FILTER
            • DISTINCT
            • SEQUENCE
            • MATERIAL
            • SORT
            • LIMIT
            • FOR UPDATE
            • SUBPLAN SCAN
            • UNION
            • INTERSECT
            • EXCEPT/MINUS
            • EXCHANGE
            • GI
          • SQL tuning practice with EXPLAIN
            • Statistics collection and update strategy for partitioned tables
            • Rule-based query rewrite
              • Runtime filters
            • SQL plan management
    • Performance test
      • Achieve high performance with Sysbench on OceanBase Database: deployment and troubleshooting
      • OCP Express
        • OCP Express
        • Monitor a cluster
        • Diagnostic analysis
        • Log service
    • 1500.Components-and-Tools
        • obshell
              • Modify tenant parameters
              • Query parameters of a specified tenant
              • Fuzzy query for tenant parameters
          • SDK references
                • Query tenant parameters
            • GO
    • Products
  4. V4.2.1
Last Updated:2026-09-04 09:45:18
connection_control_max_connection_delay specifies the maximum lock period for an account whose number of failed logon attempts reaches the specified threshold.
Type Integer
Default value 2147483647, in ms
Effective upon OBServer node restart No
This parameter takes effect only in MySQL mode.
enable_clog_persistence_compress
