SQL - V4.3.3
  • V4.3.3 Change log
  • What's New
    • Learn OceanBase SQL
      • Before you begin
      • Build a Python application
      • Build a Java application
      • Build a C application
      • Build a Go application
      • Scalable OLTP
      • Try out operational OLAP
    • Video tutorial
          • Connector/J
          • TestContainers
          • MySQL-connector-python
          • MySQL Connector/C
        • PHP
          • EXT
          • MySQLi
          • PDO
        • Create an external table
        • Server configuration
          • (Optional) Check resources
        • Deploy OceanBase Database in a container environment
    • Clear an OceanBase cluster
    • Recommended configurations
    • Direct load
      • Full direct load
      • Incremental direct load
        • Add nodes
        • Reset a cluster parameter
        • Upgrade a cluster
            • Check upgrade results
            • Configure cgroups
            • Configure cgroups
        • Clone a tenant
        • Cancel tenant cloning
          • Modify a unit config
          • Drop a unit config
        • Manage services
          • Create a service
          • Query the service status
          • Start a service
          • Stop a service
          • Add replicas
          • Reduce the number of replicas
          • Migrate replicas
          • Cancel a replica task
        • Transfer a partition
        • Cancel a load balancing job
            • Set the log restore source
          • Specify log compression
          • Login failure processing
            • Role management
              • Grant privileges to a role
            • Use a proxy user
      • Transparent data encryption
          • Enable TDE for new tables
        • Enable security audit
        • View audit records
        • Audit user login operations
        • Prepare for backup
        • Stop backup cleanup
        • Perform a physical restore
        • Cancel table restore
      • Alert logs
      • Check tenant resource usage
            • Cardinality
              • Hash joins
              • Merge joins
          • Schema specifications
      • Bootstrap
        • Absence of the leader
        • Transaction-related errors
        • Long-running transactions
        • Suspended transactions
        • Other issues
          • Exceptions of SQL queries
  • OceanBase AP
    • Core features
    • Data table design
      • Best practices
      • ETL acceleration
    • Query acceleration
      • Statistics
      • Materialized views
      • Full direct load
      • Table groups
      • Hybrid row-column storage
    • Performance test
      • TPC-H benchmark
      • TPC-H benchmark report
      • TPC-DS benchmark
      • TPC-DS benchmark report
    • Ecosystem integration
  • Vector Search
      • Vector search core features
    • Generate vector embeddings
    • Store vector embeddings
    • Create a vector index
    • Use SQL functions
    • Tutorial
      • FAQ about vector search
  • OBKV
    • OBKV-Table
        • Supported value types
        • Overview of the Go client
        • Individual API operations
        • Batch operations
        • About queries
        • Aggregation API
        • Filters
    • OceanBase concepts
            • Replicated table
            • Temporary table
            • External table partitions
            • Views in a database
            • Standard views
              • Standard views
              • Materialized view logs
            • Synonym
            • Replicated table
            • Full-text index
            • Standard views
            • Read-only replicas
            • Columnstore replica
          • Data balancing
            • Intra-tenant balancing
          • Cluster scaling
          • Tenant resource scaling
            • DCL statements
          • Weak-consistency read
          • Columnar storage
          • Minor compaction
          • Major compaction
        • Multi-level caches
          • Backup directory structures
          • Restore process
        • Configuration file
          • View the dump information
          • Adaptive major compactions
          • View merge information
        • Memory issues
          • Column skip index attribute
          • Drop a partition
          • Exchange partitions
          • Manage standard views
          • Manage materialized views
              • Create a materialized view
              • Query materialized views
              • Drop a materialized view
              • Refresh a materialized view
          • Drop a partition
            • ADD REPLICA
            • ADD RESTORE SOURCE
            • CANCEL BALANCE JOB
            • CANCEL CLONE
            • CANCEL REPLICA TASK
            • CLEAR RESTORE SOURCE
            • MIGRATE REPLICA
            • MODIFY PAXOS_REPLICA_NUM
            • MODIFY REPLICA
            • REMOVE REPLICA
            • RESTORE PREVIEW
            • SERVICE_NAME
          • SHOW RESTORE PREVIEW
        • User tenants (MySQL mode)
                • Integer data types
                • Fixed-point data types
                • Floating-point data types
                • Bit value data type
                • BLOB types
                • LOB types
              • SET type
                • Convert a JSON data type
                • Update partial JSON data
                • SRS
                • Create a spatial column
                • Create a spatial index
              • Roaring bitmap data types
              • Array data types
                • Create array columns
              • Collations
              • Strings
              • Numbers
              • Datetime values
              • NULLs
            • Assignment operators
            • BINARY operator
          • Sequence pseudocolumns
                • DECODE_TRACE_ID
              • PASSWORD
              • SM3
              • SM4_ENCRYPT
              • SM4_DECRYPT
              • OB_TRANSACTION_ID
              • `JSON_TABLE`
              • Spatial relation functions
              • Geometry property functions
              • RELEASE_ALL_LOCKS
            • Roaring bitmap functions
            • Array functions
              • Array constructor functions
              • Array judgment functions
            • Full-text queries
            • Common Table Expressions
            • ALTER TABLESPACE
            • CREATE MATERIALIZED VIEW
            • CREATE RESTORE POINT
            • CHECKSUM TABLE
            • DROP MATERIALIZED VIEW
            • DROP MATERIALIZED VIEW LOG
            • REPAIR TABLE
              • SELECT statement
              • OVER clause
            • SUBMIT JOB
            • SHOW JOB STATUS
            • CANCEL JOB
        • User tenants (Oracle mode)
          • Introduction to SQL
            • ORA_ROWSCN pseudocolumn
            • ROWNUM pseudocolumn
            • ROWID pseudocolumn
                • LOB types
              • Rowid data types
                • Create JSON columns
                • Create an XMLType column
                • Convert XMLType data
              • Data type precedence
                • Date literals
                • Timestamp literals
              • Interval literals
              • RR datetime format element
              • NULLs in SQL functions
                  • Hints related to joins
                  • Other hints
                • Reference a DBLink
                • EXTRACT(datetime)
                • ROUND(date)
                • TRUNC(date)
                • TO_NCHAR(character)
                • TO_NCHAR(datetime)
                • TO_NCHAR(number)
                • Constructor functions
                • Query functions
                • Format conversion functions
              • REGR_(Linear Regression)
              • GROUP_ID
              • GROUPING_ID
              • OB_TRANSACTION_ID
            • CURSOR expressions
            • Condition precedence
            • NULL conditions
            • Simple query
            • Hierarchical query
            • Compound query
            • Join query
            • Subquery
            • DUAL table query
              • ALTER SYSTEM PARAMETER
                • Set-based SELECT
                • WITH clause
          • SELECT statements
          • Multi-table join statements
          • Table scan
          • Cache
          • Hint
          • Weak consistency read
          • Pagination queries
        • PL reference (MySQL mode)
            • DBMS_MVIEW
              • PURGE_LOG
            • DBMS_MVIEW_STAT
              • PURGE_REFRESH_STATS
              • SET_MVREF_STATS_PARAMS
              • SET_SYSTEM_DEFAULT
              • ADD_TRUSTED_CERTIFICATE
              • DELETE_TRUSTED_CERTIFICATE
              • UPDATE_TRUSTED_CERTIFICATE
            • DBMS_LIMIT_CALCULATOR
            • DBMS_EXTERNAL_TABLE
              • AUTO_REFRESH_EXTERNAL_TABLE
        • PL reference (Oracle mode)
            • Lexical units
            • Declaration
            • Assign values
            • Error-reporting functions
            • BOOLEAN type
            • Sequential control
            • Records
              • Explicit cursors
              • Modify and drop a cursor
            • Privilege control
              • Application
            • PL DBLinks
            • INSTEAD OF DML trigger
            • Compound DML trigger
            • Compile-Time alerts
            • DBMS_JOB
              • BROKEN
              • CHANGE
              • NEXT_DATE
              • RUN
              • SUBMIT
              • USER_EXPORT
              • WHAT
              • RELEASE
            • DBMS_MVIEW
              • PURGE_LOG
              • OB_SESSION_TRACE_ENABLE
              • OB_SESSION_TRACE_DISABLE
              • OB_CLIENT_ID_TRACE_ENABLE
              • OB_CLIENT_ID_TRACE_DISABLE
              • OB_MOD_ACT_TRACE_ENABLE
              • OB_MOD_ACT_TRACE_DISABLE
              • OB_TENANT_TRACE_ENABLE
              • OB_TENANT_TRACE_DISABLE
            • DBMS_MVIEW_STAT
              • CREATE_JOB_CLASS
              • DROP_JOB_CLASS
              • PURGE_LOG
              • STOP_JOB
              • VALIDATE
              • DBMS_XA constants
            • DBMS_PROFILER
              • START_PROFILER
              • STOP_PROFILER
              • PAUSE_PROFILER
              • RESUME_PROFILER
              • FLUSH_DATA
              • GET_VERSION
              • INTERNAL_VERSION_CHECK
              • ROLLUP_UNIT
              • ROLLUP_RUN
              • OB_INIT_OBJECTS
              • OB_DROP_OBJECTS
            • UTL_RECOMP
              • RECOMP_PARALLEL
              • RECOMP_SERIAL
              • PARALLEL_SLAVE
              • ENDCREATE member procedure
              • GET* member functions
              • PIECEWISE member procedure
              • SET* member procedures
          • Reserved PL keywords
          • information_schema.events
          • oceanbase.CDB_CKPT_HISTORY
          • CDB_INDEX_USAGE
          • CDB_MVIEW_LOGS
          • CDB_MVIEWS
          • CDB_MVREF_CHANGE_STATS
          • CDB_MVREF_RUN_STATS
          • CDB_MVREF_STATS
          • CDB_MVREF_STATS_PARAMS
          • CDB_MVREF_STMT_STATS
          • oceanbase.CDB_OB_SERVICES
          • oceanbase.CDB_OB_TEMP_FILES
          • DBA_INDEX_USAGE
          • DBA_MVIEW_LOGS
          • DBA_MVIEWS
          • DBA_MVREF_CHANGE_STATS
          • DBA_MVREF_RUN_STATS
          • DBA_MVREF_STATS
          • DBA_MVREF_STATS_PARAMS
          • DBA_MVREF_STMT_STATS
          • DBA_OB_CLONE_HISTORY
          • DBA_OB_CLONE_PROGRESS
          • oceanbase.DBA_OB_SERVICES
          • oceanbase.DBA_OB_TEMP_FILES
          • GV$OB_LS_SNAPSHOTS
          • GV$OB_NIC_INFO
          • gv$tenant
          • GV$UNIT
          • V$OB_COMPATIBILITY_CONTROL
          • V$OB_LS_SNAPSHOTS
          • V$OB_NIC_INFO
          • V$RESTORE_POINT
          • V$UNIT
          • DBA_INDEX_USAGE
          • DBA_MVIEW_LOGS
          • DBA_MVIEWS
          • DBA_MVREF_STATS
          • GV$OB_NIC_INFO
          • V$OB_LS_SNAPSHOTS
          • V$OB_NIC_INFO
          • V$RESTORE_POINT
          • ALL_MVIEW_LOGS
          • ALL_MVIEWS
          • DBA_INDEX_USAGE
          • DBA_MVIEW_LOGS
          • DBA_MVIEWS
          • DBA_MVREF_STATS
          • DBA_OB_SERVICES
          • DBA_OB_SPATIAL_COLUMNS
          • DBA_OB_SYS_VARIABLES
          • DBA_OB_TEMP_FILES
          • PROXY_USERS
          • USER_MVIEW_LOGS
          • USER_MVIEWS
          • USER_MVREF_CHANGE_STATS
          • USER_MVREF_RUN_STATS
          • USER_MVREF_STATS
          • USER_MVREF_STATS_PARAMS
          • USER_MVREF_STMT_STATS
          • GV$OB_NIC_INFO
          • V$OB_LS_SNAPSHOTS
          • V$OB_NIC_INFO
          • V$RESTORE_POINT
      • Common statistical events
      • General wait events
          • alert_log_level
          • global_background_cpu_quota
          • rdma_io_thread_count
          • default_table_store_format
          • spill_compression_codec
          • storage_rowsets_size
          • debug_sync
          • innodb_stats_persistent
          • ob_compatibility_control
          • ob_compatibility_version
          • ob_enable_rich_error_msg
          • ob_security_version
          • plsql_ccflags
          • query_rewrite_enabled
          • query_rewrite_integrity
        • 10000 to 12000
        • OBE-00000 to OBE-00999
        • OBE-01000 to OBE-01499
        • OBE-01500 to OBE-01999
        • OBE-02000 to OBE-04999
        • OBE-05000 to OBE-10000
        • OBE-10000 to OBE-19999
        • OBE-20000 to OBE-29999
        • OBE-30000 to OBE-49999
        • OBE-50000 to OBE-99999
          • Generate ASH reports
          • Analyze ASH reports
          • Execution plan operators
            • JOIN
            • WINDOW FUNCTION
            • SUBPLAN FILTER
            • DISTINCT
            • SEQUENCE
            • MATERIAL
            • SORT
            • LIMIT
            • FOR UPDATE
            • SUBPLAN SCAN
            • UNION
            • INTERSECT
            • EXCEPT/MINUS
            • EXCHANGE
            • GI
          • Parallel DDL
        • Parallel execution plans
          • Set concurrent execution
            • Rule-based query rewriting
            • SQL plan management
      • OCP Express
        • OCP Express
        • Monitor a cluster
        • Diagnostic analysis
        • Log service
        • OBShell
          • Use OBShell
            • obshell management
              • Start or stop obshell
              • Upgrade obshell
              • Deploy an OceanBase cluster
          • Command line
            • Agent commands of obshell
            • Cluster commands of obshell
            • Resource specification command group in obshell
            • Tenant commands in obshell
            • Task commands of obshell
            • obshell backup command group
            • Restore command group
            • obshell Trash commands
            • obshell API requests
              • InitializeCluster
              • UpgradeOb
              • AddNode
              • GetObInfo
            • Other APIs
          • SDK references
              • Initialize a cluster
              • Start a cluster
              • Upload an RPM package
              • Upgrade agents
              • Upgrade OceanBase Database
              • Scale out a cluster
              • Query the status of a node
              • Operate a task
              • Query all unfinished tasks
            • GO
              • Start a cluster
              • Upgrade agents
              • Operate a task
        • obd
            • test_io_device
            • io_adapter_benchmark
        • SQL diagnoser
            • Install sql_diagnoser
            • Use sql_diagnoser
          • SQL diagnoser remarks
            • API operations
      • Log analysis
        • oblogminer
          • Install oblogminer
        • obloader and obdumper
        • oblogproxy
        • CDC
            • Sample configuration file
            • General obcdc parameters
          • Throttling
      • Stress testing tools
    • FAQs
    • FAQ about columnstores
    • Version number guidelines
        • OceanBase Database V4.3.1
  4. V4.3.3
Last Updated:2026-09-03 07:27:31
connection_control_max_connection_delay specifies the maximum lock period for an account whose number of failed login attempts reaches the specified threshold.
Type Integer
Default value 2147483647, in ms
Effective upon OBServer node restart No
This parameter takes effect only in MySQL mode.
connection_control_failed_connections_threshold
