V4.3.2.1
  • Technical mechanism
    • Prepare data
  • User Guide (OBLOADER)
    • Direct load
  • User Guide (OBDUMPER)
        • OBLOADER & OBDUMPER V4.3.2.1
        • OBLOADER & OBDUMPER V4.3.1.1
        • OBLOADER & OBDUMPER V4.3.0
        • OBLOADER & OBDUMPER V4.2.8.2
        • OBLOADER & OBDUMPER V4.2.8.1
        • OBLOADER & OBDUMPER V4.2.6
        • OBLOADER & OBDUMPER V4.2.7
  3. V4.3.2.1
Last Updated:2026-09-04 08:19:57
View GC information
View the installation path of JDK installed by using method 1
  • Switch to the parent directory of the path where the Java program resides. Run the ls command to view the built-in tools.
View the installation path of JDK installed by using method 2
View GC information
Run the java -XX:+PrintFlagsInitial \| grep 'CICompiler' and java -XX:+PrintFlagsFinal \| grep 'CICompiler' commands on the CLI to view the initial and final values of parameters when hierarchical compilation is used.
      • For the G1 collection algorithm, the value of ConcGCThreads is calculated by using the following formula: Value of ParallelGCThreads, rounded off to the nearest integer.
View GC information
