V4.2.8
  • User Guide (OBLOADER)
    • direct load
  • User Guide (OBDUMPER)
        • OBLOADER & OBDUMPER V4.2.8
        • OBLOADER & OBDUMPER V4.2.7
        • OBLOADER & OBDUMPER V4.2.6
  3. V4.2.8
Last Updated:2026-09-04 08:19:57
View GC information
View the installation path of JDK installed by using method 1
  • Switch to the parent directory of the path where the Java program resides. Run the Is command to view the built-in tools.
View the installation path of JDK installed by using method 2
View GC information
Run the java -XX:+PrintFlagsInitial \| grep 'CICompiler' and java -XX:+PrintFlagsFinal \| grep 'CICompiler' commands on the CLI to view the initial and final values of parameters when hierarchical compilation is used.
      • For the G1 collection algorithm, the value of ConcGCThreads is calculated by using the following formula: Value of ParallelGCThreads, rounded off to the nearest integer.
View GC information
