V4.2.5Enterprise Edition
  3. V4.2.5
Last Updated:2026-09-04 08:20:44
View garbage collection information
View the installation path of JDK installed by using Method 1
  • Switch to the parent directory of the path where the Java program resides. Run the Is command to view the built-in tools.
View the installation path of JDK installed by using Method 2
Run java -XX:+PrintFlagsInitial | grep 'CICompiler' and java -XX:+PrintFlagsFinal | grep 'CICompiler' commands on the CLI to view the initial and final values of parameters when hierarchical compilation is used.
      • For the G1 collection algorithm, the value of ConcGCThreads is calculated by using the following formula: Value of ParallelGCThreads/4, rounded off to the nearest integer.
